Does anyone use this?
I am looking for the heater hose fitting like shown except I want one that is 90 degrees instead of straight. Does anyone know where I can find a 90 degree fitting the will thread into this hole. I would like to find one that looks good too, (not brass)
Thanks. |
Re: Does anyone use this?
Steve, dont want to high jack your post, but what booster are you using on your m/c? Looks smaller and tight to the firewall. I'm looking for an upgrade. Thanks Lou
Figure out what you want--then figure out what you are willing to give up to get it. |
You can get AN style elbows then adapt your hose. Here's an example.
Look on Summit too! http://www.mechanicsupport.com/Fittings.html |
Summit Racing has many, straight, 45s, & 90s.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 07-15-2013 at 05:56 PM. |
Isnt a 90 going to hit your valve cover?
![]() Join Date: May 2010
Here's a short 90 degree chrome fitting at Summit that I bought. Nice piece.
http://www.summitracing.com/parts/gar-j9001 |
Thanks Lee and FirstOwner, just what I needed.
Jaros44sr, I am going to angle īt more towards the front so the hose wraps around the cover. Geezer, thanks for the tip but I like the silver ones from Summit a little better. Lou Boffa, I believe it is from MPbrakes.com. p/n = BM1755 Posted via Mobile Device |
#8 | |
Thanks for the offer Jaros44sr, but I am kinda digging those ones at Summit so I think I am going to go that route.
Youre welcome, but that style may not become tight at the angle you want. Thats why a swivel works better...good luck, hope it works out for you
