08-10-2013, 08:11 PM | #1 |
I have a radical idea!
Found a new way to match the cluster texture on the glove box.
I love the '67 dashes more than any other year in these trucks because of the symmetrical look between gauge cluster and glove box door. The factory '67 had a textured surface with a silver outer that somewhat matched the gauge cluster grain. The factory glove box grain is not a real good match, though. I used 2 Rustoleum textured paints, and with a little experimentation, I pretty much nailed it.
Here's how I did it if anybody wants to do the same. I painted the silver outside and then taped it up. I used the Aged Iron as base because it has the bigger textured pattern and it is gray in color. The key is to hold the can about 2 feet away and dust it in light, even coats. DO NOT by any means spray it thick. Trust me - you'll have a huge mess QUICK! After it pretty much dries (about an hour), do the same thing with textured black. Spray quick, even, light coats at about 2 feet away. If you spray it heavy, or get to close it "fills in" the grain like regular spray paint will do cluster if you put it on too thick. It takes about 8 or so (I didn't count) light coats to get a good, deep, rich look. The black textured paint by itself actually matches the factory '67 glovebox grain perfectly, but I was wanting to match the cluster. The light coats also help to keep the paint from trying to bleed under the masking tape. The tape line was good and crisp because of this. Here's some pics. This is an up close pic of the glove box. This is an close pic of factory grain of the cluster. It is nearly identical to my glove box door.. Here is a pic of the 2 paints I used. Here is the door installed. I noticed after I took the pic that I got some dusty fingerprints on it. I didn't see it, but the camera did! I am going to install the gauge bezel tomorrow. I did something similiar years ago with spray in bedliner on my red '69 C-10. It turned out decent, but it didn't match like this did. http://67-72chevytrucks.com/vboard/s...d.php?t=299203
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-10-2013, 11:40 PM | #2 |
Re: Found a new way to match the cluster texture on the glove box.
Nice job looks great
Posted via Mobile Device |
08-10-2013, 11:49 PM | #3 |
I got a couple if you want to experiment for me. Since your in Bama I'm needing a road trip.hahaha
08-11-2013, 12:02 AM | #4 |
My truck came from Killen!
08-11-2013, 09:59 AM | #5 |
That's sweet!!
08-11-2013, 07:07 PM | #6 |
Great how-to! Thanks for sharing.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater. |
08-11-2013, 09:21 PM | #7 |
Looks great! What silver did you use? And what did you use to prep the bezel?
08-11-2013, 09:32 PM | #8 |
I sanded the plastic chrome off of the outer bezel with 400 grit sandpaper. Most of it was gone already anyway. I used VHT argent silver wheel paint. It was the best match to '67 glove box I had.
08-11-2013, 09:42 PM | #9 |
That's a great tip. Looks good. I did a glovebox door spraying Dupli-Color bed liner after painting the desired color for the outer rim. Looks good as well.
08-11-2013, 10:03 PM | #10 |
Awesome thank you
67 shortbed small back window turboed lq9, porterbuilt front and rear, and accuair e-level |
08-11-2013, 10:43 PM | #11 | |
No problem! I forgot add that I wiped the whole thing down with acetone to try to remove any oil or old Armor All, etc.
08-11-2013, 11:21 PM | #12 |
I got the dash cluster installed today, and it looks really nice. I'm just waiting on the new glove box emblem to come in now!
08-12-2013, 08:02 AM | #13 |
Looks fantastic. I'm sure pictures don't show much difference between the two methods. I thought you had tried that bedliner,too,so I'm thinking this looks even closer.
08-12-2013, 10:53 AM | #14 | |
Not too old to learn
I was ready to paint the glove box door blue, but this is so much better Thanks for the post.......
1968 C10 a way to long restoration. |
08-12-2013, 08:54 PM | #15 |
Thanks! The pic below was what I was going for, and I think I successfully '67'd it!
01-01-2014, 01:45 AM | #16 |
Thank you for sharing. I'll be doing my glove box and cluster this spring.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
01-01-2014, 12:46 PM | #17 |
Thanks! I've had a lot of compliments on it the cluster and glove box door. Everybody always thinks they are new. -lol
01-01-2014, 01:34 PM | #18 |
The Niner
That came out great!
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
01-01-2014, 01:42 PM | #19 |
Looks great! Maybe I can see it in person at a local car show.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
01-01-2014, 08:11 PM | #20 |
Subscribed!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
01-02-2014, 11:23 AM | #21 |
Location: Formerly MD and San Diego, now loving life in Arizona
Very neat process you shared. That might actually look good in my truck!
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
01-02-2014, 11:31 AM | #22 |
I'll be using this method in the next week or two on my '67 glove box I managed to butcher up while stripping paint.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
11-05-2014, 08:52 PM | #23 |
Thanks So much for posting.
I'm doing this method as I'm typing..
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
