Old 09-21-2013, 07:58 PM   #26
TJ's Chevy
Chevy I6 and GMC V6 Nuts
TJ's Chevy's Avatar
Re: Project two tone.
Originally Posted by 1963c-10 View Post
nice to see you use your truck too. i put a horse stall mat in the back when i want to use it. i have polished stainless & oak in the back, and its a 3/4 " thick heavy rubber mat. the fender looks to be in great shape
Thanks! The fender has its minor dents and dings, but nothing bondo can't easily fix. The guy also think he might have a carrier so I am waiting on him. All I have on the bed for wood is a 4X6, it makes it easier to wash the frame when I haul dirt cause I can slide it out.
"6 in a row makes it go!"
"I prefer a buzzin half-dozen"
Old 09-23-2013, 11:26 AM   #27
TJ's Chevy
TJ's Chevy's Avatar
Has anybody used swaybars from Early Classic Enterprises, Classic Parts, LMC?
Thinking of using that setup and wondering what is a good quality bar. Early Classic seems to have a nice one, but they only sell them for the front and Classic Parts sells them for both front and rear. Pictures would be great! Thanks. T.J.
Old 09-23-2013, 02:46 PM   #28
1963c-10
1963c-10's Avatar
Check the 67-72 classifieds here also....have seen many good deals on sway bars there and just need new bushings & mounts if not factory optioned on your truck or previously installed.
1964 Short bed trailer
Old 09-23-2013, 03:09 PM   #29
TJ's Chevy
TJ's Chevy's Avatar
I'll check around. Didn't now they would fit. Thank.
Old 09-24-2013, 10:05 AM   #30
TJ's Chevy
TJ's Chevy's Avatar
For Dillon Rock, picture 1
Old 09-24-2013, 10:07 AM   #31
TJ's Chevy
TJ's Chevy's Avatar
picture 2
Old 09-24-2013, 10:08 AM   #32
TJ's Chevy
TJ's Chevy's Avatar
Picture 3, Hope this helps. T.j.
Old 09-24-2013, 10:42 AM   #33
Dillon Rock
Thanks T.J. It does help a lot. That's a 292 innit?
Dillon Rock is offline   Reply With Quote
Old 09-24-2013, 10:53 AM   #34
TJ's Chevy
TJ's Chevy's Avatar
Yeah, 292 with Clifford intake and Clifford short tube headers. With this intake all you have to do is use 5/8 heater hose and hook it up in those locations and your done, with the offey I believe you have to us metal line and drill in the rear block to hook up one of the lines( Don't count me on it). Let me know if you need any more info. Thanks. T.J.
Old 09-24-2013, 03:02 PM   #35
Dillon Rock
Will do T.J. , The way I guessed it was a 292 was the dead give-away was the fuel pumps are in the middle of the block as opposed to to the front block like the smaller I6's. Hey if you need any good sites if I can help in any way, I'll throw them out for everyone to look at and are worth some good.
http://www.faxonautoliterature.com/
http://www.allamericanclassics.com/
The first one helped me with truck manuals so much to get a 1960-1966 full GMC/Chevrolet factory assembly manual, the full accessory manual for the corvairs, cars, truck, van etc, etc.
The second one is a junkyard just south of my base (I still have yet to go there) that has 20 acres of classic and vintage cars and trucks.
Hope it's helpful to anyone else who sees it and you as well.
- D-Rock
Old 09-24-2013, 03:54 PM   #36
TJ's Chevy
TJ's Chevy's Avatar
- D-Rock
Here's a picture of the old 2 barrel setup.....
Old 09-24-2013, 07:48 PM   #37
TJ's Chevy
TJ's Chevy's Avatar
Just another picture.
Old 09-24-2013, 09:34 PM   #38
66 C10 383
T.J. any idea of the part number on what appears to be a Lokar gas pedal? I need to convert my 66 to a throttle cable for my EFI setup. Thanks and nice truck!
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 09-24-2013, 09:44 PM   #39
TJ's Chevy
TJ's Chevy's Avatar
Catalog part number BAG-6149. I have a catalog in hand so let me know about any part numbers you want. Thanks for the compliments! t.j.
Old 09-24-2013, 09:52 PM   #40
66 C10 383
Thanks for the info and fast reply! Any pics of the install or was it just a simple bolt in? I've got access to an 81 C10 which also has a cable so I'm not sure which one I'll end up with. Probably the easiest one to install since I'm not really set up for much fab work right now.
Doug
Old 09-24-2013, 10:13 PM   #41
TJ's Chevy
TJ's Chevy's Avatar
Here you are, really not much fabbing to do, instead of spending 30 on a spacer I made one. All I had to do is drill two holes for the pedal holder and one for the cable.
Old 09-24-2013, 10:15 PM   #42
TJ's Chevy
TJ's Chevy's Avatar
Here's another....
Old 09-24-2013, 10:16 PM   #43
TJ's Chevy
TJ's Chevy's Avatar
Probably would be easier to use the lokar. Hope this helps!
Old 09-24-2013, 10:18 PM   #44
66 C10 383
Awesome T.J. thanks so much! I may very well go with one of those.
Doug
Old 09-24-2013, 10:19 PM   #45
TJ's Chevy
TJ's Chevy's Avatar
Glad to help! Let me know if you need anything else. T.J.
Old 09-24-2013, 10:30 PM   #46
TJ's Chevy
TJ's Chevy's Avatar
Here's a part number for the cable you will need, Stainless Steel Housing TC-1000HT, Black SS Housing XTC-1000HT, and Black Housing TC-1000U. You will also need a throttle cable mount. You can go on to WWW.Lokar.com for those. T.J.
Old 09-24-2013, 11:55 PM   #47
KroAutomotiveInc
KroAutomotiveInc's Avatar
Dang man! this thing is getting nice! Love the blue i always wished i had a can of blue paint in my hand when i started on my 64 lol! I think if i could do it again since i'm already doing a blue truck is satin black with a silver roof like how the white is on the 64. Then do the inside gloss black and silver. I wish i had your parts truck! my next dream is a 63 chevy 3/4 ton 2wd long bed step side with an org auto trans. Maybe then i can buy a car for a project get these dam trucks out of my system haha...
KroAutomotiveInc is offline   Reply With Quote
Old 09-25-2013, 10:16 AM   #48
TJ's Chevy
TJ's Chevy's Avatar
Thanks Man! Yeah it was hard parting out the 64, my original plan was a full resto for it, but for some reason we always need more and more of this $$$$, Why is that??? There was a 62 according to your specs for sale here 4 years ago.....Anyway I know of EVERY 60's truck in Medford, Grants Pass and Cave Junction, so I'll keep my eyes pealed. Reason beiing is I have literally called every stinkin junk yard in Oregon! HAHAH! And on our roads it is never a suprise to see one driving or one sitting. There's a 63 that's been sitting for 8 years and hasn't moved an inch and the owner still won't sell it! Believe me, if you buy a nice parts truck like the 64, you will be crying when you use it for parts!
Old 09-25-2013, 05:17 PM   #49
TJ's Chevy
TJ's Chevy's Avatar
For Dillon Rock. I don't think you will want these. Bious tires are scary brand new let alone this old, and radial tires are scary when they dry rot! And UGH! Split rims!
Old 09-25-2013, 05:23 PM   #50
TJ's Chevy
TJ's Chevy's Avatar
Put the parts truck to good use....holding its own parts!
Copyright ©2000 - 2019, vBulletin Solutions Inc.
