68 c-10 swb_headers???
I have a chev sb in the truck, with a 4 speed and want headers that will work with this set up. Any out there. Its lowered so Long tubes are close to ground but work. I just cant seem to find any that will work with the straight drive. Any ideas, suggestions??? thanks Mike
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom Last edited by smoked68; 10-16-2013 at 10:00 AM. Reason: mis typed |
Re: 68 c-10 swb_headers???
Awwwwwh,, ITS A 1968 not a 98, fat fingers...
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
Come on, no one running headers on a strait drive small block? Where to get them??
I am using ss block huggers. They dump out about 6" from the top of the crossmember it is a pain in the butt to hook up the collector but it can be done by a good exhaust shop I am running 2-1/4" pipe all the way back to Jeg's chambered mufflers. I ordered my headers off of ebay I think they cost around $110 shipped I will try to get some pictures of them this weekend since we are going to have it on the lift to do a rear gear swap and cam swap.
Long tubes are definitely the way to go for performance. If you can't get long tubes, I'd just run a set of the old ram horns.
Well I have long tubes now, old and beat up. Nowhere can I find headers that fit the strt drv trucks or that claim they will fit. I dont even see shorties listed for a manual truck. What to do,???
I bought these for my truck: http://www.summitracing.com/parts/su...del/c10-pickup
They fit pretty good. I had to modify the z-bar a little bit, but otherwise no issues. Pretty sure these are Summit rebranded Flowtechs.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
