Old 10-18-2013, 02:19 AM   #401
ZUBZ
ZUBZ's Avatar
Re: How about some pics of Static Dropped C-10's
Originally Posted by mikes61 View Post
Heres my static 72 custom/10
mikes61 your truck is the bizzniss man, what is your static setup because until I can afford bags I am going static.
ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa
My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560
ZUBZ is offline   Reply With Quote
Old 10-18-2013, 09:40 AM   #402
mikes61
Thanks! The front is 2.5 drop spindles with 3" lowering springs and the rear is 5" flip kit with 2" blocks and 1" rear shackles.
mikes61 is offline   Reply With Quote
Old 10-18-2013, 09:44 AM   #403
ZUBZ
ZUBZ's Avatar
What is a flip kit?
Old 10-18-2013, 09:54 AM   #404
mikes61
And yes definetely will remove the window vents ..and already have an appointment at the exhaust shop.
Old 10-18-2013, 09:55 AM   #405
BigDaddyV
BigDaddyV's Avatar
It is a kit that moves your rear axle on top of the leaf springs. vs. being under them.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 10-18-2013, 09:59 AM   #406
ZUBZ
ZUBZ's Avatar
ok thanks, so this is for pickups with leafs in the rear. I have coils in the rear.
Old 10-18-2013, 10:11 AM   #407
BigDaddyV
BigDaddyV's Avatar
yup. For you, you can do lowering springs and blocks, if you want to keep the springs. if you go more than 4" I would suggest c-notch and an adjustable track bar.
Old 10-18-2013, 10:18 AM   #408
ZUBZ
ZUBZ's Avatar
Thanks for the advice BigDaddy....
Old 10-18-2013, 10:44 AM   #409
ksshane
ksshane's Avatar
Mike.. Im working on doing the same set up on my truck. What size wheels are you running?
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 10-18-2013, 05:40 PM   #410
mikes61
20x8.5 front
20x10 rears
Old 10-18-2013, 07:30 PM   #411
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Updated pic of mine from OS during "CTC 2013"
(Left of my Buddy Wynne's 70 SB Show Truck)
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-18-2013, 08:32 PM   #412
ksshane
ksshane's Avatar
Both are awesome
Old 10-19-2013, 01:34 PM   #413
s11sean11
I think I have posted here but heres and updated picture of my 62
s11sean11 is offline   Reply With Quote
Old 11-05-2013, 11:13 PM   #414
chevy-fun
chevy-fun's Avatar
4.5/4 drop
2.5" mcgaughy spindle 2" spring / hanger shackle out back
Showwheels Streeter 20x8.5, 5.25" BS, 245/45/20
Showwheels Streeter 20x10, 5.5" BS, 275/40/20
chevy-fun is offline   Reply With Quote
Old 11-10-2013, 05:53 PM   #415
ksshane
ksshane's Avatar
2.5 spindles 3" springs
Flipped Leaf Springs in the rear
Old 11-13-2013, 04:17 PM   #416
True 67
okay ..please help..i must ask this question..i have a 71 and bought the Wilwood big brake kit front/rear and plan on running 20" wheels.. i also have the 2.5" cpp drop spindle for up front. i only want to do a 2.5" front and 4" rear drop as i will be more than likely loading up my bike that weights around 700lbs..So i'm looking for shokcks to compliment what i want.. do i go with a stock shock for front/rear and get the 4" drop spring for the rear or what?
True 67 is offline   Reply With Quote
Old 11-13-2013, 05:40 PM   #417
ksshane
ksshane's Avatar
I have leafs in the back so I cant really answer that question..... Dont quote me on this but I think you can just buy front shocks and use them on the rear with a 4" drop... But Im not 100% sure.
Old 11-14-2013, 11:23 AM   #418
knomadd
knomadd's Avatar
I think you need drop shocks for the rear. Just looking at CPP's shocks on their website says they have a shock for stock height, a 2-4" drop shock and a 5" drop shock for the rear. I would recommend shock relocators for the rear.
I do know that stock shocks will work up font if you're only using a 2.5" drop spindle. The spindle doesn't change your suspension height at all. It simply moves the wheel location as it relates to the suspension.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-14-2013, 07:56 PM   #419
elf w/capital T
Question Re: How about some pics of Static Dropped C-10's
Originally Posted by knomadd View Post
....using a 2.5" drop spindle. The spindle doesn't change your suspension height at all. It simply moves the wheel location as it relates to the suspension.
Then how come everywhere they are...are called 2.5 drop spindles??? I know they helps with the...camber...?? Or whatever its called..... ugh im drawing a blank...
elf w/capital T is offline   Reply With Quote
Old 11-15-2013, 09:32 AM   #420
68Stepbed
68Stepbed's Avatar
I lowered the rear another inch for a 4.5/6.75 total drop.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-15-2013, 10:36 AM   #421
JWall
Frequent Flyer
JWall's Avatar
- Justin
1 Owner 1976 SWB
Old 11-15-2013, 12:47 PM   #422
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Wow JWALL that thing is gorgeous!
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 11-16-2013, 01:45 PM   #423
Boost2Bags
Boost2Bags's Avatar
JWall, that is one gorgeous truck! Just how I like them. Stock body dropped on big wheels.
NEED TO BUY STREET TRUCKS ISSUES 1/08 5/09 1/12
PM ME IF YOU HAVE THEM
1978 C10 SWB bagged - PB Dropmember/ Kp cantilever 4-link
2017 Silverado CCSB LTZ Z71 Midnight edition
1950 Chevy 3100 5 window - all original
Boost2Bags is offline   Reply With Quote
Old 11-17-2013, 05:25 PM   #424
knomadd
knomadd's Avatar
Drop spindles actually lower ride height by moving the wheel higher on the spindle (higher in the wheel well). No change to overall suspension height (springs and shocks) because nothing behind the spindle is changed. Ride height is obviously lower by the amount of spindle drop, usually 2.5".
-Duane
Old 11-17-2013, 05:28 PM   #425
knomadd
knomadd's Avatar
Wow JWall! I haven't been a fan of square bodies, but I think that one might change my mind. Very nice!
-Duane
