10-18-2013, 02:19 AM | #401 |
Re: How about some pics of Static Dropped C-10's
mikes61 your truck is the bizzniss man, what is your static setup because until I can afford bags I am going static.
------------------------------------------------------ ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560 |
10-18-2013, 09:40 AM | #402 |
Thanks! The front is 2.5 drop spindles with 3" lowering springs and the rear is 5" flip kit with 2" blocks and 1" rear shackles.
10-18-2013, 09:44 AM | #403 |
What is a flip kit?
10-18-2013, 09:54 AM | #404 |
And yes definetely will remove the window vents ..and already have an appointment at the exhaust shop.
10-18-2013, 09:55 AM | #405 |
It is a kit that moves your rear axle on top of the leaf springs. vs. being under them.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
10-18-2013, 09:59 AM | #406 |
ok thanks, so this is for pickups with leafs in the rear. I have coils in the rear.
10-18-2013, 10:11 AM | #407 |
yup. For you, you can do lowering springs and blocks, if you want to keep the springs. if you go more than 4" I would suggest c-notch and an adjustable track bar.
10-18-2013, 10:18 AM | #408 |
Thanks for the advice BigDaddy....
10-18-2013, 10:44 AM | #409 |
Mike.. Im working on doing the same set up on my truck. What size wheels are you running?
71 swb 350/4sp manual 5/7 static drop |
10-18-2013, 05:40 PM | #410 |
20x8.5 front
20x10 rears |
10-18-2013, 07:30 PM | #411 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-18-2013, 08:32 PM | #412 |
Both are awesome
10-19-2013, 01:34 PM | #413 |
I think I have posted here but heres and updated picture of my 62
11-05-2013, 11:13 PM | #414 |
4.5/4 drop
2.5" mcgaughy spindle 2" spring / hanger shackle out back Showwheels Streeter 20x8.5, 5.25" BS, 245/45/20 Showwheels Streeter 20x10, 5.5" BS, 275/40/20 |
11-10-2013, 05:53 PM | #415 |
2.5 spindles 3" springs
Flipped Leaf Springs in the rear
11-13-2013, 04:17 PM | #416 |
okay ..please help..i must ask this question..i have a 71 and bought the Wilwood big brake kit front/rear and plan on running 20" wheels.. i also have the 2.5" cpp drop spindle for up front. i only want to do a 2.5" front and 4" rear drop as i will be more than likely loading up my bike that weights around 700lbs..So i'm looking for shokcks to compliment what i want.. do i go with a stock shock for front/rear and get the 4" drop spring for the rear or what?
11-13-2013, 05:40 PM | #417 |
I have leafs in the back so I cant really answer that question..... Dont quote me on this but I think you can just buy front shocks and use them on the rear with a 4" drop... But Im not 100% sure.
11-14-2013, 11:23 AM | #418 |
I think you need drop shocks for the rear. Just looking at CPP's shocks on their website says they have a shock for stock height, a 2-4" drop shock and a 5" drop shock for the rear. I would recommend shock relocators for the rear.
I do know that stock shocks will work up font if you're only using a 2.5" drop spindle. The spindle doesn't change your suspension height at all. It simply moves the wheel location as it relates to the suspension.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
11-14-2013, 07:56 PM | #419 | |
Then how come everywhere they are...are called 2.5 drop spindles??? I know they helps with the...camber...?? Or whatever its called..... ugh im drawing a blank... |
11-15-2013, 09:32 AM | #420 |
11-15-2013, 10:36 AM | #421 |
Frequent Flyer
11-15-2013, 12:47 PM | #422 |
Ridin' Dirty
Wow JWALL that thing is gorgeous!
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
11-16-2013, 01:45 PM | #423 |
JWall, that is one gorgeous truck! Just how I like them. Stock body dropped on big wheels.
NEED TO BUY STREET TRUCKS ISSUES 1/08 5/09 1/12 PM ME IF YOU HAVE THEM 1978 C10 SWB bagged - PB Dropmember/ Kp cantilever 4-link 2017 Silverado CCSB LTZ Z71 Midnight edition 1950 Chevy 3100 5 window - all original |
11-17-2013, 05:25 PM | #424 |
Drop spindles actually lower ride height by moving the wheel higher on the spindle (higher in the wheel well). No change to overall suspension height (springs and shocks) because nothing behind the spindle is changed. Ride height is obviously lower by the amount of spindle drop, usually 2.5".
11-17-2013, 05:28 PM | #425 |
Wow JWall! I haven't been a fan of square bodies, but I think that one might change my mind. Very nice!
