Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 12-14-2013, 02:39 PM   #1
BigRed76
BigRed76's Avatar
Z06 Corvette Exhaust Manifolds
I've got 2 sets of exhaust manifolds. Also have a 5.3 oil pan & pickup tube, and a new lower rad. hose that are from a 2000 truck.
Open to offers, prices are plus shipping.
2008 Z06 LS7 Corvette exhaust manifolds (I believe technically they are headers) $150
2000 5.3 truck exhaust manifolds $50
2000 5.3 oil pan & pickup tube $50
2000 5.3 lower radiator hose $10
I can get pictures upon request
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 12-15-2013, 10:42 AM   #2
lowlife4life
lowlife4life's Avatar
Re: Z06 Corvette Exhaust Manifolds
Are the z 06 manifolds symmetrical?
lowlife4life is offline   Reply With Quote
Old 12-15-2013, 03:14 PM   #3
BigRed76
BigRed76's Avatar
Yes they are, exit location is exactly in the middle.
Zach
Old 12-15-2013, 09:05 PM   #4
stevenbear72
stevenbear72's Avatar
Can I get photos of the zo6 manifolds
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 12-15-2013, 09:39 PM   #5
BigRed76
BigRed76's Avatar
Pictures of the Z06 manifolds...
Zach
Old 12-17-2013, 05:35 PM   #6
SIETEDOCE
work in a 67 c10?
SIETEDOCE is offline   Reply With Quote
Old 12-17-2013, 10:32 PM   #7
BigRed76
BigRed76's Avatar
Originally Posted by SIETEDOCE View Post
work in a 67 c10?
That would depend on your motor mount setup.
Zach
Old 12-17-2013, 11:33 PM   #8
BigRed76
BigRed76's Avatar
work in a 67 c10?
If you use a motor mount setup like this, that uses adapter plates to put the motor mounts in the stock SBC location, then these manifolds would work.
Zach
Old 12-18-2013, 11:31 AM   #9
crazy longhorn
Fabricate till you "puke"
One thing to think about is clearance around the heads, @ the firewall....that engine is set in 1" forward from the I 6 position. However, the firewall was clearanced for a BB Olds that was run in the mid 90's (it fits pretty tight at the rear). To move the engine forward much at all , may cause problems on the bottom for clearance on the pipes/cats ? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-18-2013, 11:35 AM   #10
faribran
do you have the short collecter and bung for O2 sensor ?
faribran is offline   Reply With Quote
Old 12-18-2013, 03:19 PM   #11
BigRed76
BigRed76's Avatar
No I don't have any collectors for them, just the manifolds.
Zach
