![]() Join Date: Sep 2011
I have a 72 CST and the bottoms of the doors are completely rusted out. I'd love to replace the doors completely with new shells and hardware.
I'm curious. Has anyone here bought new shells? Know anyone who has? Is it worth the price? Do the 72 shells have the hole for the screw underneath the wing window? I just replaced the carpet with new stuff from stockinteriors.com, bolted in new Corbeau Baja XRS seats, put the USA-630 radio, amp, and speakers in, got the dash cluster in the mail from Bowtie Bits, fabricated the rear interior panels from drawings I got here on the board and carpeted them, and replaced the weatherstripping for the doors. Two months ago I had both axles, the tranny, and transfer case rebuilt. Here's the kicker though... Tomorrow She goes in for a new heart. 330HP Chevy crate motor, HEI ignition, and Holley Terminator throttle body fuel injection. Yee haw! So, anyone ever bought new door shells? That's the last thing my Wife will let me buy... though I might not have to beg after selling the old buckets and dash cluster. Thanks in Advance! Chris |
![]() Join Date: Apr 2006
Re: Has anyone bought Blazer door shells?
I bought new shells a few years back and they were pretty nice. I can't remember if the had the holes under the vent window. From what I remember everything fit well and they fit like the originals.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
#3 | |
I'm trying....
![]() Join Date: Oct 2013
If you or anyone else could comment more on your experience with repop Blazer doors and the manufacturer...I'd appreciate it too. |
I can't remember who they were from but from research most sheet metal are all basically from dynacorn. That's what the boxes said when I bought them. AMD makes some of their own parts but not all so you have to ask otherwise it will be dynacorn. They can be hit or miss. I have an aftermarket fender on my chevelle and while it fits decent it doesn't fit as well as original. I have even found another original fender to replace it. I bought a tailgate and a hood back then and the tailgate was a joke. The hood fit great so you never know.
I thought it would be a great idea to get repro doors it would save a ton of time fixing mine. $800 later and they don't fit. I can't get a gap on the latch side. The problem is visible on where the metal is formed at the hinge mounting area on the new doors, there is about a 1/4" difference.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
And.....
I'm trying....
69-72 who manufactured the doors you got? Did you get the pre-cut "Blazer" doors?...and thanks for taking time to post pics.
Brad |
One is a Tri-Plus I think, the other was from AMD, might be a Tri-Plus as well I will check later. One was a Blazer door and the other a truck door I cut down. Just hope I can sell these things somehow.
Yup both Tri-Plus
I'm trying....
Thanks for the info. Gonna stay on the hunt for some clean OEMs then.
If its just the lower side you can do lower door skins. I got mine from lmc and they fit good. Just got to measure and make sure You are Correct before you cut the lower off your doors. I did outer and inner skins on my drivers door.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
I'm not liking how this thread is going..
1972 Chevy Blazer ![]() Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=560741 |
I've never bought anything from them but I've been hearing good thigs about gmc Paul's. maybe look into their stuff. Brothers trucks I've bought from too and haven't had a problem with their stuff yet.
Almost all repo parts are dynacorn with a different box thrown on them. It can be hit or miss with these parts since they are lower quality than the originals. They just never fit the same. A good body man can make stuff look good but you are going to pay for that unless you know someone. I'm fortunate and have a good friend who is a great body man. The skins are one of the best ways to go since you can just weld them in and basically have a new door.
#15 |
A bit of a thread revival-- what's a set of OE blazer doors worth?
#16 |
Condition dictates 95% of value. Amount of rust, dents, bondo, etc. The year they were manufactured can also play a role. 1972 Blazer door shells were a one year deal with the recessed screw below the vent windows.
#17 |
I didn't like the thought of having to redo the internals in mine. So I went with doorskins instead of complete doors. It worked out well but I needed to reinforce the door hinge area more than what the skin could provide. Usedsome 1/4 inch plate on the inside and ran bolts with nuts through instead of just the original bolts to hold the hinge on tighter.
#18 |
As to a set of oe complete doors. I've seen them go for 500 apiece if they are in very good usable condition.
#19 |
K5drive
Orig parts best choice . After market is crap ? Do all measurements before painting after market parts best advice you can get if your buying them to save time . But eventually you'll be restoring to orig parts and swapping them out . I have purchased all kinds of after market parts and haven't found a good source for any yet !
#20 |
I have a 72 and i quickly found out that these doors are kinda special,so i ended up fixing the cracked hinge areas and doing door pins and replaced all the lower sheetmetal...done!
