Old 12-14-2013, 12:40 AM   #51
ricott
Re: My Wife's 55.2 Carryall / Suburban build
Here is the link to the build. Look at post 317. His troubles began when he went to coilovers. http://67-72chevytrucks.com/vboard/s...d.php?t=368649
ricott is offline   Reply With Quote
Old 12-14-2013, 07:37 AM   #52
ghettoluxury
ghettoluxury's Avatar
He used the stock stamped steel K-Member, this is why he had the flex.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-14-2013, 10:55 AM   #53
fabguy
Elev8r Man
fabguy's Avatar
Thank You sirs, I read the thread and see that you are right ghettoluxury, it was due to using the stock K member.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 12-14-2013, 11:01 AM   #54
Baldeagle SR
I am glad you found the thread. Rich
Baldeagle SR is offline   Reply With Quote
Old 12-14-2013, 11:24 AM   #55
fabguy
Elev8r Man
fabguy's Avatar
thank you for pointing it out and giving me the heads up. lol, man i was worried for a lil bit there but its all good now.
I am going to head over to the shop and work on the frame a little bit more today. ( grind down the welds etc on the boxing plates)
I am also going to try to fix the pulling of the frame end.
1939 2 door sedan
Old 12-14-2013, 06:33 PM   #56
fabguy
Elev8r Man
fabguy's Avatar
Here is a picture of the boxing plate I made for this. It is out of 3/16" plate that I had laying around. It is of the same plate I used for the front. Since the picture was taken I have welded it up and ground it down.
I couldn't for the life of me try to figure out what would look best connecting the dog bone bracket to the frame so I had a W.W.B.D. moment and came up with this.
It is made out of 1/8" plate that I had left over from an order I just did this last week.
I had bent it up in my metal Brake.
Then I decided to close it in. I am going to add some more gusset plate to it to sturdy it up. I might even do a few dimples in it to dress it up a bit. I might also cut an inch out of the right side plate (facing) and bend the top/bottom cover plate to give it a little dress up although am not too sure yet.
I think it looks a little goddy but am not sure yet.
It is a few inches away from the factory dog bone bracket as I am going to use 5/8" rod ends and some D.O.M. tubing for a custom 4 link setup, and so it is fully adjustable later.
1939 2 door sedan
Old 12-15-2013, 02:09 AM   #57
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-15-2013, 11:17 AM   #58
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
These may help provide some ideas!
ChuckDriver is offline   Reply With Quote
Old 12-15-2013, 01:35 PM   #59
fabguy
Elev8r Man
fabguy's Avatar
Thank you Kim,
Thank you ChuckDriver, and for the pic's. I like those ideas there.
1939 2 door sedan
Old 01-24-2014, 11:39 PM   #60
fabguy
Elev8r Man
fabguy's Avatar
Well, its been a little while since I was able to get on the burban. Today I was able to get the front crossmember tack welded in and suspension mocked up on it. Yesterday I was able to weld in the boxing plates and almost all of the way ground down.
So, happy to back on it again.
woo hoo
1939 2 door sedan
Old 01-26-2014, 10:41 PM   #61
fabguy
Elev8r Man
fabguy's Avatar
heres a lil progress from the last couple days.
Also found out I will have 5-1/2" under the rockers, hope its not too low for the wife.
1939 2 door sedan
Old 01-26-2014, 10:52 PM   #62
xpickup
xpickup's Avatar
Fab guy, looks great. The suburban should be fun to drive with that suspension.
Shannon
xpickup is offline   Reply With Quote
Old 01-27-2014, 12:49 AM   #63
Flames97
Flames97's Avatar
Nice!! I bet that's gonna look good at that ride hight.
-Aaron
Instagram - aaronmcoe
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 01-27-2014, 07:35 AM   #64
fabguy
Elev8r Man
fabguy's Avatar
Thank you very much xpickup and flames97.
I am hoping to set the body on for mock up soon although still need to work on the rear first.
1939 2 door sedan
Old 01-27-2014, 09:48 AM   #65
Kim57
Kim57's Avatar
Real nice fab work.
Kim
My build thread
Old 01-27-2014, 11:35 AM   #66
ChuckDriver
Looking good, I like it!
Old 01-27-2014, 11:16 PM   #67
fabguy
Elev8r Man
fabguy's Avatar
Thank you very much Kim57 and Chuckdriver.
A little progress today on the rear as I started removing the leaf spring brackets so can start to weld in the 4 link brackets.
1939 2 door sedan
Old 01-28-2014, 01:37 AM   #68
hp1957
hp1957's Avatar
fabguy, Very cool suburban!!
Harvey
1957 Chevy Stepside
1958 GMC C4 build thread:http://67-72chevytrucks.com/vboard/s...=535686&page=4
hp1957 is offline   Reply With Quote
Old 01-28-2014, 07:29 AM   #69
fabguy
Elev8r Man
fabguy's Avatar
Harvey
1957 Chevy Stepside
Thank you hp1957.
1939 2 door sedan
Old 01-29-2014, 08:41 AM   #70
fabguy
Elev8r Man
fabguy's Avatar
Well I managed to start attaching the rear 4 link brackets on. I also cut and tack welded the bracket that holds the front of the rear end or the pumpkin nose. I also had to re fabricate the wing mounts as the holes were slightly off by 3/32" total. I finally got those done and tack welded in also.
Today I am hoping to finish welding up the 4 link brackets as my heim joints should be here by this Friday. Pictures to follow, soon as I get the rear section welded up.
1939 2 door sedan
Old 01-29-2014, 11:17 PM   #71
fabguy
Elev8r Man
fabguy's Avatar
update,
I was able to cut and weld in the Front C-Notches today for the Rack & pinion.
Here are a few pictures of it:
This is an inside view of what it looked like.^
for those interested, I used a 4" hole saw to make life easy.
1939 2 door sedan
Old 01-30-2014, 01:11 AM   #72
lowrodderchev
lowrodderchev's Avatar
You do some real good work fan guy can't wait to see the finish product
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 01-30-2014, 08:43 AM   #73
xpickup
xpickup's Avatar
fabguy, looks great. When I did the one on the 51, I added tubing from the front of the crossmember and tied it into the bottom of the radiator support. That way it would triangulate the area and put some strength back in. I just did not like that the frame was notched out for the rack that much. I figured if you hit something with the bumper it would fold the front of the frame easily.
Shannon
Old 01-30-2014, 06:43 PM   #74
Ozzy2013
Ozzy2013's Avatar
Absolutely awesome work you should consider building them full time!
Ozzy2013 is offline   Reply With Quote
Old 01-30-2014, 10:16 PM   #75
fabguy
Elev8r Man
fabguy's Avatar
Thank you, yeah me too
Shannon
I like that Idea, that is a GREAT thought too. I am going to look into doing just that now. That weak point from the front C notch bothered me also although didn't cross my mind about an accident.
Thank you, That would be great but, my shop is set up for doing general fabrication (when work comes in anyway).
As for the work on this frame, I don't think it's worthy of that yet. I am my own worst critic though.
1939 2 door sedan
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
