02-21-2014, 11:03 AM | #226 |
Re: What did you do to your truck today? Chapter II
how did you go about mounting 90s gm cup holder i have been planing on doing the same thing? i already have the cup .holder from a previous trip to the junk yard
02-21-2014, 02:34 PM | #227 | |
Check out the pictures in this link. http://photobucket.com/albums/cc230/...9/CUP%20HOLDER
1970 C10 Short Stepper with 71/72 front clip. |
02-22-2014, 01:32 AM | #228 |
02-22-2014, 04:06 PM | #229 |
Rebuilt my rag joint. Feels like it tighten up the steering sitting still without the engine running. Have to test drive to confirm.
Thanks to TxFirefighter for his FAQ instructions. His tutorial with pictures was helpful. Thanks Kevin. http://67-72chevytrucks.com/vboard/s....php?p=6525292
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 02-25-2014 at 07:47 AM. |
02-22-2014, 06:22 PM | #230 |
Figured out that the dwell on my new set of points was way off. No wonder it wouldn't start. Finally started, ran strong, forward and reverse gears working good. Even brakes were working just enough to stop me. Was all excited, then I saw water coming from the block. Upon further inspection, the block appears to have a big C shaped crack on the drivers side. One step forward, a big leap back. Now I have to make a decision.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
02-22-2014, 07:06 PM | #231 | |
I tinkered with touching up some black paint in the engine bay. Figuring out the little things I need to replace. Gotta love old trucks.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
02-22-2014, 09:50 PM | #232 |
I painted the top of my dash black. I made my own antenna lead firewall grommet from a piece of fuel line & used some gorilla glue to hold the home made grommet into place. I ran all new wiper washer hoses from the washer pump to the washer jug & to the squirter nozzles. They both squirt like a charm. That is, after spending nearly a 1/2 day cleaning out those dang nozzles. I removed the looped heater hoses the PO had done & installed new heater hoses and checked for a leaking heater core. And to my amazement, the heater core is not leaking. I have yet to figure out why the PO had looped the heater hoses. Maybe because it blew hot air all the time cause I did notice that one of the levers on the AC control is broken. Thank God I do not have to change out a heater core!!
Dash before & after;
"Now all I need is a shop to go with my shop vac!" |
02-22-2014, 10:02 PM | #233 |
Weather in the 50's for the first time in months, so I gave the old girl a bath.
02-22-2014, 10:25 PM | #234 |
Beautiful day today in North Texas. Spent so time with the wifey at the Decatur swap meet. Bunches of 60-72 truck parts there. Spent $115 and got all this. The doors are "scratch and dents". The PS is the one I needed and only has 3 small dings in it. The DS needs a new skin, but I think it will buff out.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
02-23-2014, 05:48 PM | #235 |
Did drop engine and trans in, NOW everything goes back together
Motor is 2005 Vortec 5.3 from Suburban. We're using 2013 Camaro LS3 exhaust manifolds, x-pipe, dual flow masters, with K&N intake and PCM tune should be around 335-340 HP.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
02-23-2014, 05:59 PM | #236 |
Changed the rear brake pads and removed all the parking brake related brackets off the rearend/ calipers
02-23-2014, 08:25 PM | #237 |
could never make the bowtie gate fit right installed the original tale gate fit like a glove getting closer to sending her out for paint
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-23-2014, 09:12 PM | #238 |
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8 '74 Trans Am 400, '80 Trans Am Indy Pace Car Mercedes AMG S55, SLK230 Kompressor, GL450 '96 Dodge Indy Ram Official Indy Truck '99 Porsche 911 Carrera |
02-23-2014, 09:22 PM | #239 |
love them steppers
02-23-2014, 10:09 PM | #240 |
Got on craigslist this morning & found me a 68 super nice hood. little surface rust & a great price 220.00. got it home & a little cleaning & its could to go. Old hood was junk.
02-23-2014, 10:53 PM | #241 |
? what will you use for a parking brake now ? .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
02-23-2014, 11:06 PM | #242 |
RAT1968 '68 Cab/'71 Parts
Hey, Nate,
Maybe he'll use the same thing I do. I have all the stuff, butt I prefer this. Combined with parking on a flat spot:
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
02-24-2014, 12:40 AM | #243 |
Nice looking GMC, motor will look good in there too.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
02-24-2014, 02:12 AM | #244 |
Re : Park Brake
O.K. then but if you'd seen all the death and misery I have you'd never , EVER be without a park brake .
Remember this : it's all fun and games until someone gets hurt , worse yet if it's a child....... 3 TONS of old truck rolling away after the driveshaft falls out isn't fun , I know this . Makes no difference you have new U-Joints and grease them as much as I do mine . SAFETY KNOWS NO SEASON . .
02-24-2014, 05:22 PM | #245 | |
Re: Re : Park Brake
Even though there is probably no more than 400 miles on the build, I was under the truck checking torque readings on everything, greasing everything, including the spacers and wheels. Down side is, I scraped a small tree limb parking in "my spot" after the test run. Off came a little paint and a part of a pinstripe. No big deal. But the driveline and suspension are all (properly) tight as a drum.
02-24-2014, 10:10 PM | #246 |
Chevy Forever
I didn't get any work done but I did order some parts. Which includes A complete wiring harness and a plumbing kit for my tank to the fuel filter and the pump.
My first love 1971 C20 Hugger orange Getting face lift and heart transplant .30 402 BB /TH400 and GV Wifes car 1969 Chevelle SS 396 325hp/TH400 Factroy A/C Automatic w/ Floor shift console. restored. |
02-24-2014, 11:43 PM | #247 |
Finally paint! It took a while to get everything prepped, but that's 80% of painting,right? I'm super happy with the way everything turned out. I even installed the intake...that was a lil challenging, especially right next to the plenum. But I got to say the "hardest" part is over. Time to start bolting everything back on. Already received most of the new goodies.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
02-25-2014, 01:17 AM | #248 |
Stripped the frame down...getting ready for some por 15 action...
02-25-2014, 01:19 AM | #249 |
Flip.
02-25-2014, 09:44 AM | #250 |
Took the core support out of my truck... It's the wrong one so it will be going to sell.
Also stripped the core support brackets with a wire wheel and rattle caned em'. I'll be taking them to a friends shop to sand blast them, but they look ok for now.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
