03-08-2014, 01:46 AM | #1 | |
Re: 1970 One Owner Short Step
Update. So a lot has happened since I last posted. The sheet metal has been blasted and primed so body work can begin. The bedsides are good, but I had to replace all of the cross sills and the angle brackets (the brackets that attach to the bedsides for the wood bed). I found a donor cab, but unfortunately I will have to replace the floor, cab corners and rockers. Big money here we come (unfortunately). I have my LY6 and 6L90 in the shop and will be test fitting everything next week. I should have the harness back in two weeks and hopefully by then I will have a rolling chassis to drop everything into. I have a powder-coated frame and front cross member. I converted everything to 5 lug and disc brakes. The spindles are Early Classic 2" drop spindles. I bought a set of abandoned (new) rear disc brakes that I am working out placement on the rear-end. I ordered a set of hidden bolt strips from Mar-K and received them yesterday as well as a radiator and trans cooler from Speedway. I am still deciding what wood I will be using for the bed...synthetic that I don't have to worry about tearing up vs. oak. I want to be able to use the bed when I need to, but I really like the look of hardwood. Fortunately I will have time to make this decision. I will be using Jeremy from LSX Unlimited in DFW for my harness and initial tune VAT/Emission delete.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
