01-30-2014, 02:04 AM | #76 |
Rollin' Old Skool
Re: '88-'98: What Size Tire and Wheel are You Running?
15x7 steelies with 225/70's up front & 235/60's in rear:
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
01-30-2014, 02:07 AM | #77 |
Rollin' Old Skool
18x8's with 235/55's:
02-05-2014, 12:37 PM | #78 |
TNT-MOTORSPORTS
Havent had any Issues at all. I did a little playing around last night. 22X9.5 with a 265/35/22 on the rear, fits perfect other than I would have to roll the lip a little bit. Could probably use a little more sidewall tho .... Maybe a 285/35/22 .... Gonna try one when I get some in stock . No way it will work on the front lowered this much.
02-06-2014, 05:37 AM | #79 |
[URL=http://s36.photobucket.com/user/bigjaydaddy505/media/Burban/PICT0134.jpg.html]
my 93 burb bagged on 22s with 265/35/22s debating on goin way bigger right now since its torn apart |
03-17-2014, 10:09 PM | #80 |
Basic set up:
Front end: Lowered about 4” with 2” drop spindles and drop springs Cut fender flange lip off flush with inner fender well, spot welded inner & outer back together and ground smooth. Pulled inner fender well bolt directly above tire out. Rear end: Lowered about 6’ with axle flip kit and c-notch plates. Added some air-assist air bags so he could have some adjustability on rear ride height and adjust for carrying a load or pulling a trailer. Had to do some e-brake relocating and rerouting to clear air bags and keep from rubbing the inside of the wheel and tires. Rolled rear fender flange with vise grips and shot filled rubber mallet. Then with a hydraulic-jack a 2x4 slightly widened the outer fender paying very close attention to the sheet metal as to not distort anything. Gained about 3/8” Wheels and Tires: Front: Showheels Streeters 18” x 8” with 0 offset mounted with Falken Ziex ZE-612 (235/60R-18) Rear: Showheels Streeters 18” x 9” with a +6 offset mounted with Falken Ziex ZE-612 (265/60R-18) More: http://67-72chevytrucks.com/vboard/s...d.php?t=621197 Last edited by devind; 03-17-2014 at 10:35 PM. |
03-17-2014, 10:14 PM | #81 | |
Rollin' Old Skool
03-17-2014, 10:41 PM | #82 |
Thanks,
It has been a fun little build with my son. He needed something dependable he could drive back and forth from collage. Plus he races mountain and road bikes so he built some little bike rakes to haul his bikes around in the back when he goes to races. I have always felt if and when you can give your cars and trucks a little personalty if you can. I hope some of this thinking rubs off on him. |
06-10-2014, 04:14 PM | #83 |
245/50/20 on front and 285/50/20 on rear. 3" drop in front and 4" in rear.
Love your truck, devind! |
06-10-2014, 04:22 PM | #84 |
Oh, and I DO love showing mine off
06-10-2014, 10:37 PM | #85 |
Rollin' Old Skool
That looks nice! Nothing wrong with showing it off either.
06-11-2014, 06:54 AM | #86 |
94grounddweller My build thread. http://www.gmt400.com/forum/showthre...ild-on-22-quot |
06-11-2014, 08:59 AM | #87 |
[QUOTE=Jerbou71;6715589]Im running 22"x9" and 255r30 22 tires. With quit a bit drop. Lol.
Yeah, as in ANTS have to crawl OVER your truck |
06-11-2014, 09:03 AM | #88 | |
08-11-2014, 09:03 PM | #89 |
08-12-2014, 08:01 AM | #90 |
5" front. 6" rear.
08-14-2014, 06:20 PM | #91 |
08-15-2014, 07:51 AM | #92 |
First I have to say there are many great looking trucks in this post.
On my 91 K1500 I purchased Cooper Discoverer AT3 LT265/75R16 Load Range E a little over a year ago. The truck rides and handles good for LR-E tires. Traction in winter is great. Tires are wearing well. I run the OEM aluminum wheels - 16X7. http://us.coopertire.com/Tires/Light...ERER-A-T3.aspx
Sam 2014 GMC Sierra SLE K1500 Z71 Fire Red Regular Cab Long Bed - 5.3L (325 Cu In) V8 - 6L80-E 6-Speed Auto 1991 Chevrolet K1500 Z71 Silver Regular Cab - Long Bed 5.7L (350 Cu In) V8 - 4L60 4-Speed Auto |
09-08-2017, 11:44 AM | #93 |
275/60/15 Cooper Cobra Radial G/T on 8" Rallys.
09-21-2017, 11:00 PM | #94 |
My '95 Suburban has 7" Accuride steel wheels. First I was running 255/85-16s. It needed tires this summer and the 255s were hard to find a deal on so I went to 285/75s. Looks like I have no pictures yet with the 285/75s
Tags |
88-98, size, tire, wheel |
