Old 03-21-2014, 10:20 PM   #276
Dustinmk4
Re: What did you do yo your truck today??
Originally Posted by Red88 View Post
Did the passenger side door hinge pins and bushings this past weekend. Thanks to Cape Codder for the suggestion to use a 2x4 to bind the hinge and bring the door back into alignment. Worked a charm!
More on this suggestion????
Dustinmk4 is offline   Reply With Quote
Old 03-22-2014, 06:32 PM   #277
Red88
Red88's Avatar
The post is on the previous page of this thread. I just stuck a 2x4 into the open bottom hinge as he describes.
http://67-72chevytrucks.com/vboard/s...&postcount=266
'88 K1500 Scottsdale
5.7 TBI, 5spd MG5
Red88 is offline   Reply With Quote
Old 03-22-2014, 11:02 PM   #278
ss454lemy
thas what i did today 454ss
ss454lemy is offline   Reply With Quote
Old 03-30-2014, 04:18 PM   #279
54 jimmy
54 jimmy's Avatar
changed the leaking power steering hose. an replaced the pcv valve. it was the original ac rodchester 168,000 miles not bad. tomorrow is coolant flush.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver)
1996 chevy k1500 reg cab 4x4(daily driver/wife's winter beater)
2002 gmc envoy xl (wife's daily driver)
54 jimmy is offline   Reply With Quote
Old 03-30-2014, 05:08 PM   #280
Blue97
RUNSWITHBEER
Blue97's Avatar
Installed a new Delphi fuel pump........
Blue97 is offline   Reply With Quote
Old 03-30-2014, 09:27 PM   #281
Cape Codder
Cape Codder's Avatar
Blue 97 did you drop the tank or lift the bed? My pump is pretty loud but has been working fine and I'm not sure if it can be trusted.
Cape Codder is offline   Reply With Quote
Old 03-30-2014, 09:34 PM   #282
Jerbou71
Jerbou71's Avatar
Well i got my rims on today and here she is.
Jerbou71 is offline   Reply With Quote
Old 03-30-2014, 10:04 PM   #283
Blue97
RUNSWITHBEER
Blue97's Avatar
No I just slid the bed back enough to get to it... My fuel pump whined for three years..... I just thought that's the ways its supposed to be......
And then , it just quit.......new pump is so quiet at first I thought it wasn't working then all of a sudden my truck starts ..... still trying to get used to a quiet Fuel Pump haha......
Old 04-03-2014, 12:56 AM   #284
rickpilgrim
Pulled my 98 k3500 project truck out of the 4' of snow with the dually and put her in the shop
rickpilgrim is offline   Reply With Quote
Old 04-10-2014, 09:24 PM   #285
dragginmetal
here, just not logged in
dragginmetal's Avatar
Put some drop shackles on today. Stock shocks will not work with a 8" drop. It doesn't matter how you position them, or if you have shock extenders. The shock is to long. Needs to be 14.5" collapsed or less for a 8" drop.
dragginmetal is offline   Reply With Quote
Old 04-16-2014, 02:06 AM   #286
c10sport
c10sport's Avatar
Got a front trans seal and a rear main seal in hopes it quits leaking. Fixed a couple of other leaks now it isn't peeing all over my garage floor.
Jay
1989 GMC Sierra SLE Indy 500 Support Truck
1991 S10 Blazer 4x4
1995 Olds Silhouette - soon to be Supercharged
2009 model Chihuahuas x2
c10sport is offline   Reply With Quote
Old 04-17-2014, 05:12 PM   #287
kcHotRodtrk
kcHotRodtrk's Avatar
put er on craig's list!
http://batonrouge.craigslist.org/cto/4424430175.html
kcHotRodtrk is offline   Reply With Quote
Old 04-21-2014, 02:44 PM   #288
kcHotRodtrk
sold... dang, too easy, the guy then paints it walmart rattle can flat black OVERNIGHT! n texts me a picture. although this truck was not quite what I was looking for as a starting point... I kinda have seller's remorse...
Old 04-27-2014, 11:49 PM   #289
dragginmetal
I changed the rear end oil. Also started messing with the instrument cluster. All the blot holes were cracked. Pick up one from a junk yard awhile back but it wasn't any better. So I figured I try to fix it for free before I buy a good one. I broke some plastic off one. Then cut the cracks on the other one with a hot knife. Next I took a small butane touch and melted the cracks. At the same time I melted the plastic I got from the other cluster with a hot knife and pushed it in the cracks like puddy. Once it cooled i sanded it with 220 grit. It seems to be working pretty good. It's kinda ugly but what can I expect from a poor mans plastic welder. lol
Old 04-30-2014, 07:13 AM   #290
Cape Codder
I did some tailgate repairs. My truck came with a bed liner and tailgate protector when I got it. I don't like stuff flying around the bed so I replaced the bed liner with a rubber bed mat as soon as I got it. I kept the bed protector as I do use my truck as a truck. The bottom of the protector hooked over the bottom of the gate and has worn the paint in a few spots. First I had to strip the decals.
I then stripped the rust from the bottom of the gate inside and out and fixed a few little dings.
Old 04-30-2014, 07:24 AM   #291
Cape Codder
Then I primed and painted and cleared in my nice clean paint booth
Sanded buffed and reinstalled with a new emblem to replace the decal.
I also built and installed the headboard rack since I last posted. I am an amateur boat builder and need to carry long bits of lumber for projects.
Old 04-30-2014, 05:37 PM   #292
Very nice job on both project Cape Codder.
1981 GMC High Sierra SWB Stepside
"Whitey" 2002 Chevy Silverado 1500 SWB W/T
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 04-30-2014, 06:54 PM   #293
Jerbou71
Jerbou71's Avatar
I dont know how many pictures got messed up.
Took me bed off a couple days ago.
94grounddweller
My build thread.
http://www.gmt400.com/forum/showthre...ild-on-22-quot
Old 05-01-2014, 11:44 AM   #294
ss454lemy
4in cowl induction waiting on the wheels
Old 05-01-2014, 11:47 AM   #295
ss454lemy
sick!
Old 05-01-2014, 12:20 PM   #296
Cape Codder
SS454lemy
Very shiney I like
Old 05-01-2014, 01:41 PM   #297
ss454lemy
thank u! cape codder she shines up well and even better in pictures. but i will be painting it over soon.
Old 05-15-2014, 04:21 PM   #298
ss454lemy
got mt aem and n20 today
Old 06-06-2014, 03:39 AM   #299
tom32
waiting for some one help me find down A/C on my 96 Chevy.....TOO HOT CAN NOT DRIVE ANY WHERE
tom32 is offline   Reply With Quote
Old 06-14-2014, 02:36 PM   #300
MaritimeDragRacing
MaritimeDragRacing's Avatar
Replaced the rusty top section of all eight body mounts on my ECSB 94 Chevy with some heavy steel plate. All it took was two 2" hole saws, a roll and a half of MIG wire and MANY hours work cutting, fitting and bending. Bending was the hard part with that heavy plate but it had to be done because the frame mounts are not 100% flat as seen in the second photo below.
And lots of rust paint after the grinding and welding....
Took the front clip off and jacked the cab off the frame about 6" one side at a time to make the welding easier
Also put on new front fenders, inner fenders, radiator support, Y-pipe and gaskets, catalytic convertor and a couple of patches on the cab floor with 18 gauge steel(easier to weld) All in all it took 120 hours from May 6 to June 5 and was all done home in my gravel driveway in between the rain(and snow) days.
http://www.maritimedragracing.com
Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information.
MaritimeDragRacing is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
