03-28-2014, 08:41 PM | #1 |
Tell me about these Holley Heads
Ran across a pair of sbc Aluminum Holley heads. Recently machined in great shape. Cast # is 12111. Thats all it says. Does anyone know anything about them. Are they worth the buy for $600?
I am getting ready to stroke my sbc to 383. Got my carb and bottom end. Looking for intake and heads. Wanting lots of low end torque. Have a 2wd 71 350. |
03-28-2014, 10:17 PM | #2 |
I have a radical idea!
Re: Tell me about these Holley Heads
Those are the old Holley Systemax heads and they would be great for a torquey 383. They have 185cc intake runners, which is bigger than stock, but sized great for a bigger cu in SBC like a 383. Those heads were made for Holley by Brodix, and they used to come in a package put together by Holley with their Street Dominator high rise intake and a hyd cam that made a little over 400 HP on a flat top 350. They should be well worth $600 if they are in good shape and the guides are trashed.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-28-2014, 10:22 PM | #3 | |
03-28-2014, 10:25 PM | #4 |
I mean worn out - meaning if you have to pay $600 for them and then have to have new guides put in them, its not such a good deal.
03-28-2014, 10:57 PM | #5 |
03-29-2014, 10:33 AM | #6 |
Yes, that's still a good price. Those heads are have a 20 degree valve angle to make them flow better instead a standard 23 degree angle. They work fine with normal SBC pistons unless you are running a big cam (like a race cam or roller).
03-29-2014, 12:10 PM | #7 |
bought em and they look really good. gAVE me the receipt from the shop too that went through them. Oh, can I NOT use a roller cam with these?
03-29-2014, 05:50 PM | #8 | ||
"I ain't nobody, dork."
You can... just make sure your piston to valve clearance is good. Also check to make sure the valve springs will support the amount of lift you wanna use.
Gary
