Old 03-28-2014, 10:55 PM   #1
70K10Hunter
70K10Hunter's Avatar
Tuff Country 4" lift kit
OK I did check the search engine for my particular problem, but couldn't find a solution. I bought the 4" kit with shocks and drop pitman arm. After doing the install and setting the bed back on the frame, the rear tires are not centered in the wheel wells I took a pic of what it looks like, see if I can post it, so I double checked the installation instructions. The instructions have a special note for the rear springs to make sure the LONG side from the centering bolt to go to the rear. Man it just don't look right.....
70K10Hunter is offline   Reply With Quote
Old 03-29-2014, 07:53 AM   #2
b454rat
Re: Tuff Country 4" lift kit
Maybe once more weight is on the springs, it will put the tire in the opening. If not reverse the spring....
Old 03-29-2014, 09:06 AM   #3
CUSTOM/10
CUSTOM/10's Avatar
There's also what I believe they call a zero rate leaf / plate that has an off set hole for the leaf spring center bolt, this moves the axle closer to center of the wheel well.
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 03-29-2014, 09:08 AM   #4
CUSTOM/10
CUSTOM/10's Avatar
Here ya go ! Click on this link !
Gary
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
Gary
72 SWB 4x4
My 72 SWB Build
Old 03-29-2014, 09:11 AM   #5
Bigdav160
Bigdav160's Avatar
Common complaint. I don't think you can easily install the spring in the wrong direction.
Edit, removed my link. Gary got it.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-29-2014, 12:50 PM   #6
70K10Hunter
Well it just don't look right so I guess I will hope that they settle in, I will load the bed with some good weight to push down the suspension see what transpires but I will definately be calling Tuff Country come Monday.
Old 03-29-2014, 07:00 PM   #7
Zoomad75
K5Camper
Zoomad75's Avatar
I'd say it's not loaded. Look at your shackle. As the load is applied, the spring compresses and moves the shackle rearward. As the shackle goes to the rear so does the axle. You don't have a cab or much else on the chassis besides the bed so I don't expect the spring to be compressed much.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-30-2014, 01:16 AM   #8
chisler
chisler's Avatar
How does the driveshaft fit
chisler is offline   Reply With Quote
Old 03-30-2014, 01:25 AM   #9
chisler
chisler's Avatar
My truck...looks the same
Old 04-01-2014, 01:24 PM   #10
86454k30
86454k30's Avatar
I have a 98 K3500 with 5" tuff country rear springs. Mine sat too far back in the wheel well. I called tuff country numerous times. I pretty much got from them "it is what it is"...and "no one else has complained". Highly irritated so i just put a off road design zero rate in and moved the axle back forward. IMO this is unacceptable for as much as the springs are.
86454k30 is offline   Reply With Quote
Old 04-14-2014, 10:26 AM   #11
jasonda
I had the same problem with tuff country's 6 inch system and found that the axle location pin was over an inch offset when measuring from one eye to the pin verses the other. Not sure why tuff country chooses to do this but you can rotate the springs to achieve the look you want. When you load it I dont think you are going to find it fix your problem because the axle location is fixed by the front spring shackle which does not move. As you load the spring heavier and heavier it flattens the spring causing the spring eye to eye demension to lengthen which is compensated by the rear shackle moving in a rearward direction. the axle pin location does not move.
jasonda is offline   Reply With Quote
Old 04-19-2014, 04:42 PM   #12
1tuff71
1tuff71's Avatar
the problem is common with most lift kits in the 3"-6" range. what they do is try to move the axle forward a bit so you won't have to get a new driveshaft made with these lifts. go over 6" and will need to have a longer shaft made. ORD has the fix in the form of a 0 rate block as stated in another post
1tuff71 is offline   Reply With Quote
Old 06-06-2014, 11:55 PM   #13
70K10Hunter
Sorry for the lag in response.. I've been relocating to another state. OK so if I go with the zero rate blocks, will I have to lengthen my drive shaft?
Old 06-07-2014, 07:09 PM   #14
Mike C
Mike C's Avatar
Maybe. That's one of the reasons that the tire is too close to the front. That is standard for the lift springs and part of that is because of driveshaft length. On my Jimmy I trimmed a pie piece about 1" at the bottom and about 8" long which effectively makes the wheel well more round rather than hook nose like stock.
On my 3/4 ton axle swap, I re-drilled the spring mount on the axle in order to move the rear axle about 3/4" back to center it. But I had already had a custom CV driveshaft built and the 3/4 ton axle is longer from centerline to yoke and I needed the extra space so the driveshaft would have enough clearance.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-08-2014, 10:30 PM   #15
GU3
GU3's Avatar
I did a 6" Tuff Country lift and put in the ORD 0 rate offset block to center the axle in the wheel well. The factory driveline worked just fine with a little length left. I think if you go bigger than 6" then you would need a longer driveline.
1970 K10 Suburban
GU3 is offline   Reply With Quote
