06-08-2014, 09:29 PM | #76 |
Re: 83/84 swb stepside long time build
Thank you. Wood isn't really an option for the notch and bridge. Just trying to be a little creative.
06-09-2014, 10:32 AM | #77 |
If you wanted you could maybe have the rear air control components, as shown in picture above, covered in a subfloor with hinged top. Leave them as shown in picture, and add a cover that hinges at the front of box. Just a thought- stealth, or having them exposed is nice too, show off your hardware.
Les |
06-09-2014, 09:20 PM | #78 | |
I thought about that and even mocked it up a few pics back. Wife and friends asked why I would cover up all that money that is shiny. Thinking about getting the air tank plated with that spectrum chrome stuff. Truck is going to be mostly black, a few chrome ascents here and there won't be bad. LOL |
06-10-2014, 08:24 AM | #79 | |
06-10-2014, 09:02 PM | #80 | |
06-20-2014, 08:13 PM | #81 |
Got the rear cross member moved back a couple of days ago.
06-20-2014, 08:16 PM | #82 |
Had to notch the top frame rails about 3/8 inch to allow room for tank to go between frame rails.
06-20-2014, 08:19 PM | #83 |
Used Eastwood's weld through primer on skid plate parts.
06-20-2014, 08:22 PM | #84 |
Used their rattle can. It was so so. Had to hold the can sideways at a 45 degree angle to prevent it from spitting.
06-20-2014, 08:27 PM | #85 |
Probably could have mounted tank in a better way. But, this was the best I could figure right now. Decided to bolt most the brackets together. This way I could level it better later when I get final stance where I want it. Here is the front main support for the rails that will hold the tank weight. Bolted it to the bottom section of the C-notch.
06-20-2014, 08:28 PM | #86 |
the top right picture was to side mounts for the skid plate .
06-20-2014, 08:32 PM | #87 |
Here is the bottom skid plate. I think it is 9 gauge steel. I think it's thick enough to fend off anything medium size that might go under the truck. Just felt like it would be safer with some defense under tank. Have another piece to cover front part of tank as well.
06-20-2014, 08:34 PM | #88 |
did some small tacks. Had to make sure I could get it out after tacking together.
06-20-2014, 08:38 PM | #89 |
And here is I feel like a dumb arssh. Went to remove and a few of my tacks broke. I for sure thought welder had enough to tack sheet metal to 1/8 angle. But, while tacking noticed to just pooling up and not burning in. I *****ed and yelled and said let me look at the dam polarity again. Well this was the fifth time looking at the polarity settings and noticed I had it backwards this whole time. DUH!!!! Flipped them and it was was sizzling.
06-20-2014, 08:42 PM | #90 |
Got the skid plate out and sat down on threw some beds on it and mounted the front strap bolt downs. My welding is ugly. But I got them burned in good enough for me. I have a grinder and paint. LOL
06-20-2014, 08:43 PM | #91 |
Got the bottom skid plate back in. Had to oval a few bolt holes. Got little hot with some my welds. Moved the plate around a little.
06-20-2014, 08:47 PM | #92 |
Mounted some angle on the rear cross-member to support and level the angle thats going to level and hold the weight from front to back.
06-20-2014, 08:48 PM | #93 |
hers is the rear bar that the tank straps will mount to.
06-20-2014, 08:49 PM | #94 |
picture front skid plate
06-20-2014, 08:53 PM | #95 |
tank in place. Will be pulling everything apart and coating with rust protector for a later black paint. When I assemble for final. Will use some rubber between tank and any metal.
06-20-2014, 08:55 PM | #96 |
here is one of the tank straps. As it currently sits, will only have to raise the front and rear bed floor 3 inches. Of course the C notch will need to go up more.
06-20-2014, 08:56 PM | #97 |
Tomorrow is my B-Day and wife and kids are going to leave me alone till tomorrow night. Should be able to finish tank mounts and hopefully clean and get rust paint on.
06-24-2014, 07:15 PM | #98 |
Got all the suspension finished and everything off the frame. Going to start cleaning and prepping for paint this week.
06-24-2014, 07:16 PM | #99 |
Question . Should I clear coat the frame after I use chassis black?
06-30-2014, 07:59 PM | #100 |
Well the cleaning process really sucks. Tired all kinds different wheels and its taking forever. also put the frame up on a rotisserie. It works pretty decent.
