Old 09-17-2014, 12:43 AM   #1
full foot notch
Grove in center of both front brake rotors ?
Was working on the truck and was trying to see if the spindles on my truck were CPP or not since there's a CPP spring kit all around. I noticed this grove on the rotor and first thought was aww F I've gotta take apart this truck to replace the pads and rotor, so I looked and saw that the pad has plenty of meat on it. I ran my finger nail over it and it seems to be a machined groove and not something akin to a bad pad. I checked the passenger side and it too had an identical groove in the rotor, I tried getting digital calipers between the wheel and rotor and seems about 1 inch down from the outside edge. I've heard of slotted rotors but not with a single groove. And since it's identical locations on both front rotors my mind tends to eliminate that it's bad pads , the second appearing line nearest the hub is just where the cast part of the rotor meets the machined surface , it's not a line at all
Here's a pic of the rotors
full foot notch is offline   Reply With Quote
Old 09-17-2014, 01:04 AM   #2
Mikeeal33
Mikeeal33's Avatar
Re: Grove in center of both front brake rotors ?
Yes it is supposed to be there. No worries run it!
1972 Driver SOLD
Mikeeal33 is offline   Reply With Quote
Old 09-17-2014, 01:24 AM   #3
full foot notch
Any idea who makes the rotor ?
Old 09-17-2014, 06:57 AM   #4
PGSigns
PGSigns's Avatar
Looks like a 5 lug wheel so it is a stock 73 to 87 rotor. Could be from any auto parts store.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-17-2014, 12:35 PM   #5
Mikeeal33
Mikeeal33's Avatar
What year is your truck? Mine is a 72 with front discs, and that groove is there so I don't agree with it being a 73-87 rotor. When I was looking at stock replacements they all had the groove in em.
I don't know any particular manufacturer, but I do agree that they can be had at any of the parts stores.
1972 Driver SOLD
Old 09-26-2014, 07:52 PM   #6
NovaBrad
My 72 C10 has the same groove\rotors and I believe my 72 Nova also has the same groove as well.
NovaBrad is offline   Reply With Quote
Old 09-26-2014, 08:40 PM   #7
full foot notch
Mines a 72 also. And glad to know I'm not going insane over this
Old 09-27-2014, 11:21 AM   #8
66 C10 383
Most stock style rotors have that groove. I've been told it's to show the rotors thickness, as in, if the rotors are turned past the point the groove is gone, the rotors need to be replaced. So you basically can visually check the thickness rather that checking with micrometers.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 09-27-2014, 01:17 PM   #9
full foot notch
See my thought would of been maybe the groove was there for assisting brake pad gasses so that the pad doesn't float
Old 10-01-2014, 10:05 AM   #10
ERASER5
ERASER5's Avatar
That too, but in the days of turning rotors, that groove was a simple visual cue. Groove gone and the rotor not smooth yet? Replace. No question about it.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-14-2021, 03:07 PM   #11
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
ah, so glad about this posting. I was checking my rotors and thought darn that can't be good, then noticed the same grove on the other side! Guess if the grove is nice and deep - rotor are in good shape!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 01-14-2021, 09:13 PM   #12
kwmech
I don't think they about the gasses back then
Old 01-15-2021, 01:40 PM   #13
SCOTI
SCOTI's Avatar
I remember just the early 71-72 rotors having that groove.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
