Old 09-09-2014, 04:53 PM   #1
oem4me
Painting grill letters ..the easy way!
Did a quick search on this, and to my surprise I found nothing. Maybe because it's too easy? Or everybody already knows?
In any case, after staring at a blah grill for the year or so since buying my '66 Custom Camper, I finally gave it the front-end detail it has so badly needed. The job was so fast and easy, and came out so well, I feel stupid for not having done it sooner.
Now, normally I would not re-touch an authentically aged survivor part like this, but I'm thinking this grill was re-plated at some point by a previous owner, so no sacrilege there.
I'll try to keep it simple so you can follow along.
This will apply to a bright aluminum grill, but with a basic understanding of various paints and solvents, it should be nearly as easy for a painted grill.
You will need:
A piece of cardboard
Spray paint of choice. - don't use junk. I used Duplicolor acrylic enamel, semi-gloss black
An appropriate solvent for that paint. quicker drying is better. I used Acetone.
An old T-shirt or other nap-less, lint-free rag. NOT terry cloth!
A block of wood 1x3x6 ish. I used a paint stick and a rubber sanding block, but a plain wood block would be just as good, if not better.
A pump or spray bottle
Thats it.
Ok, let's get started.
First, clean the grill. Remove all wax, oil, and traces of old paint. Carb cleaner and a tooth brush works fast for removing paint.
Next, cut a rough mask for a single letter out of any stiff paper or thin cardboard you find laying around. Tape will make the hole smaller if you cut the hole too big to start.
Now spray the paint. I did mine one letter at a time for simplicity. Spray light even coats until the whole letter is covered. No runs or heavy pools. If you are struggling at this point, you might want to consider another hobby, or hire the job out. Ha ha, just kidding.
Let the paint dry a bit.
While the paint is drying, cut the T-shirt into several 1 foot long x 6 inch wide strips. Fold a strip in half (double layer) and tightly wrap it around the wood block, pinching and stretching the material from behind with your hand to maintain a wrinkle free face. This is by far the most critical aspect of this job, as loose material or wrinkles will ruin the result. If you can't hold even tension with your hand, then staple the darn rag on there (backside). In the picture I used a paint stick, but a block would be better.
Next take a spray bottle with your chosen solvent and wet the face of the rag/block. Immediately get to wiping the excess paint surrounding the letters off the grill, leaving color in the recess. Again, I did one-at-a-time to maintain simplicity and control. When the rag gets loaded with paint, turn to a clean part and reapply. Clean rag and clean solvent = clean results.
Old 09-09-2014, 04:56 PM   #2
oem4me
Re: Painting grill letters ..the easy way!
Some may already be happy with the results as-is. I personally thought the letters still looked too fat or heavy, so I went in with a rag and my finger tip to fine-tune. If you can't control your shaking hand, have another drink or skip this step. I suppose one could experiment with more layers of material on your block, creating a spongy effect, which would "reach into" the recesses a little deeper, but you risk blowing the whole thing this way.
Now stand back and admire that professional looking detailed grill. What was that, like about a half-hour? Sheesh, too easy!
Before and after
Old 09-09-2014, 05:01 PM   #3
C/10 King
C/10 King's Avatar
Very nice!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 09-09-2014, 05:04 PM   #4
texasld
texasld's Avatar
Great Write-up! I'll be trying this trick with my 69 grille when i get my new one. I have seen the difference in price between the painted letters and non painted letters be astronomical!
Good Looking truck, too!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 09-09-2014, 05:13 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Looks good!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-09-2014, 05:14 PM   #6
Jasons65
Jasons65's Avatar
Looks great and good write up, used this technique on my Nova's grill to give it a "billet" look.
1965 SBFS BBW Soon to be Restomod Daily Driver
1972 Chevy Nova-Pro Touring
Jasons65 is offline   Reply With Quote
Old 09-09-2014, 05:15 PM   #7
steveb64
Active Member
steveb64's Avatar
Excellent, that grill looks great.
I did this very technique on my sail panels, works great there too.
steveb64 is offline   Reply With Quote
Old 09-09-2014, 05:37 PM   #8
Mathew21
Mathew21's Avatar
Great Write-up, It turned out great. Now you need to post more pictures of your Truck.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 09-09-2014, 07:27 PM   #9
slepysal
slepysal's Avatar
Talk about great timming !! Just swaped grills last weekend and need to paint the letters Thanks !!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-09-2014, 07:48 PM   #10
cru_zn_29
cru_zn_29's Avatar
Great cure for colorless letters and other projects. Thanks for the post
cru_zn_29 is offline   Reply With Quote
Old 09-09-2014, 08:46 PM   #11
jayoldschool
Moderator
So much better than stickers. Nice work.
jayoldschool is offline   Reply With Quote
Old 09-09-2014, 09:15 PM   #12
pimpston65
pimpston65's Avatar
darn my grill is painted, what is a good solvent to remove the excess without lifting the main body paint?
pimpston65 is offline   Reply With Quote
Old 09-09-2014, 09:39 PM   #13
TJ's Chevy
TJ's Chevy's Avatar
Thanks fer the right up! Really makes it a piece o cake!!!
Old 09-09-2014, 10:27 PM   #14
sodly
sodly's Avatar
Dang that's slick!
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 09-10-2014, 01:49 AM   #15
oem4me
Thanks for the positive feedback, fellas.
perfect!
Yep, for sure not a new trick, but why no posts about it here?
Agreed. Stickers can peel and look tacky (pun). Ha!
Depends entirely upon what the grill is painted with. If you don't know, some tests are in order. Mineral spirits are about as harmless as it gets for solvents, but still might affect the grill paint if it was done on the cheap. too many variables to say without testing first.
Some here. http://67-72chevytrucks.com/vboard/s...d.php?t=609701
Old 09-10-2014, 03:27 AM   #16
Carlitosway
wow looks great!! thumbs up
Carlitosway is offline   Reply With Quote
Old 09-10-2014, 06:09 AM   #17
pimpston65
pimpston65's Avatar
thks for the reply oem4me.
i used rustoleum auto primer and auto paint on most on the smaller parts. i'll test a small area first. i think if i wipe asap after spraying will help with overspray, so it doesnt fully dry and cause the need for more elbow grease with mineral spirits and all. thks...
Old 09-10-2014, 09:04 AM   #18
1963c-10
1963c-10's Avatar
Great write up!!!!
1964 Short bed trailer
Old 09-10-2014, 02:11 PM   #19
luvbowties
luvbowties's Avatar
Smile Re: Painting grill letters ..the easy way!
Nice job and write up, oem4me. And it looks great. And congrats on the ingenious thinking behind the process!
I especially loved those before-and-after pics; really shows the difference.
Another method: I've been using Majik Markers, regular and esp. fine points for this job. The fine points do well on cab sails too, where the lines are so small and narrow. Drawback on my method: needs re-doing about every couple of years;(
Sam
luvbowties is offline   Reply With Quote
Old 09-10-2014, 02:16 PM   #20
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks for taking the time to share this write up. Great tip!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-10-2014, 02:28 PM   #21
JWheeler331
JWheeler331's Avatar
Nice job. Easy too.
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline   Reply With Quote
Old 09-10-2014, 06:39 PM   #22
Bigru
Bigru's Avatar
Thanks for the info Bruh!!
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 09-10-2014, 08:59 PM   #23
Jeff La
I love easy, thanks LOL
Jeff La is offline   Reply With Quote
Old 01-09-2015, 01:10 PM   #24
Grizz1963
Grizz1963's Avatar
Love simple solutions.
This one is too obvious.
Thanks for sharing.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 01-09-2015, 03:09 PM   #25
Pappyx3!
Pappyx3!'s Avatar
Awesome post!
Thanks for sharing
Pappyx3! is offline   Reply With Quote
