01-25-2015, 06:45 PM | #1 |
1st 500 mile oil change on Chevy crate 350/290
I'm coming up on the initial 500 mile oil change for my new engine. It has flat tappet cams, so I need with a zinc formulated oil or a synthetic oil with a day zinc addative. Not sure which way to go, so I am looking for some advice. Where I live, full synthetic Royal Purple, Lucas Oil, Valvoline, etc.. are available, but can't locate Red Line, Joe Gibbs, Rotella, etc.. Also, as far as filters are concerned, I was thinking either Wix, Napa gold or ACDelco.
1967 Chevy C10 Stepside SWB - 350/700r4 |
01-25-2015, 08:57 PM | #2 |
Re: 1st 500 mile oil change on Chevy crate 350/290
A little off topic,but what color is that ? Paint code ?
84 step side 87 swb |
01-25-2015, 08:59 PM | #3 |
Rotella is a diesel oil, try a truck stop/shop.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-25-2015, 09:04 PM | #4 |
why did you want the flat tappet? just curious.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
01-25-2015, 10:04 PM | #5 |
Parts and more parts
Frank |
01-25-2015, 10:10 PM | #6 |
01-25-2015, 11:49 PM | #7 |
Use a good oil with a zink additive. Use Wix, Napa, or Carquest, filters. They are all the same & the best brand.
01-26-2015, 12:07 AM | #8 |
The color is a medium deep maroon with black top. Not sure the paint code, it was already painted when I bought it 4 months ago. As far as the flat tappet cams, the engine took a crap on me 10 days after I bought it. I put in a new Chevy Performance crate 350/290hp and that's what it came with. Since this is my first truck, I know more now than I did then...LOL
01-26-2015, 12:37 AM | #9 |
I run brad Penn in my trucks. U can buy it by the case on eBay and it already has adequate zinc in it. Its really the same price as oil at a parts store and this way u can stock up for a few oil changes at a time. I've always run wix filters.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
01-26-2015, 03:12 AM | #10 | |
I'm a retired mechanic who worked at Cadillac during the 80's. We replaced so many cams on the HT4100! I got so many extra bottles of cam lube as we were instructed to only coat the cam not to put it in the crankcase. I'm down to about 3 bottles myself so I've been using that every oil change but soon I'm going to be in the same boat. |
01-26-2015, 02:01 PM | #11 |
Vintage 4x4s
It looks like it may be close to the early 90's GMC crimson red metallic. Here is one, I have a 90 GMC just like it I could get the paint code off of.
http://allamericanautomobiles.com/car/36767435-4.html
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
01-26-2015, 02:10 PM | #12 |
Mobil 1 15w50 used to have zinc levels over 1000 ppm, but now the document showing that is gone. I am unsure if the formula has changed or if they just removed the document online.
Whichever oil you chose, it should state on the bottle somewhere if it has a high zinc level, otherwise use an additive. |
01-26-2015, 03:35 PM | #13 | |
01-26-2015, 06:11 PM | #14 |
I broke my 89 350 w/flat tapper cam in with rotela diesel per the mechanics advise. Even he was unsure if it would be sufficient at the time but that's what the engine builder told him. Since then I've added the blue stp bottle (from Walmart) to every oil change with mainly castrol oil. I was curious if anyone else uses the stp stuff? Also I just picked up some Quaker state oil (from Wal mart)that stated it had high zinc levels.
Knock on wood. |
01-26-2015, 08:25 PM | #15 |
I use Valvoline 10-30 synthetic with Hy-per lube zinc replacement I bought at Autozone. I use to have a list of high zinc oils but I can't find it. You can check the website bobstheoilguy for all info needed on oil and oil additives. Hope this helps
Cheers
72' C10 Custom/delux SWB West Coast Engines stage 2 crate 350 335 hp/383tq roller rockers/roller cam TH350 Sanderson Headers 71' C10 SWB ECE 4/6 drop kit: SOLD |
02-10-2015, 04:16 PM | #16 |
Coach,
Oils with Higher levels of ZDDP are recommended for engines with flat tappet cams. We recommend that you check with the manufacturer of the engine on the proper oil viscosity. Shell Rotella T multi-grade oils (SAE 15W-40, 0W-40 5W-40, 10W-40, 10W-30) contain approximately 1,200 ppm of phosphorus. This includes Shell Rotella T conventional, Shell Rotella T5 synthetic blend and Shell Rotella T6 full synthetic engine oils. You can visit www.Rotella.com for more information and to find a retailer in your area at http://www.shell.com/rotella/locator.html -The Shell Rotella Team |
02-10-2015, 04:56 PM | #17 |
Here is what I use. I spoke with Comp Cams before making the choice as I'm running their 268 cam kit.
Amazon.com: Competition Cams 1590-12 10W30 Engine...
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
02-10-2015, 05:54 PM | #18 |
I'm using Valvoline 10w-30 conventional with a bottle of Rislone ZDDP additive bottle # 4405.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
