Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 02-16-2015, 09:33 AM   #51
Hart_Rod
Hart_Rod's Avatar
Re: DBW pedal mounting bracket
Originally Posted by 4x4k30 View Post
do you have a bracket for the 73 up ? I got a 77 with a 6.0 dbw pedal mine sets to high
OK guys. I just picked up a clean one owner 86, so now I have a guinea pig to build a bracket. Who's still interested?
Hart_Rod is offline   Reply With Quote
Old 02-16-2015, 09:46 AM   #52
Houston Ben
Houston Ben's Avatar
I am!
Houston Ben is offline   Reply With Quote
Old 02-18-2015, 01:05 AM   #53
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Rob, I'm not sure what pedal I want to use yet for my LS3 swap. I'm considering using the Corvette pedal for my 71 because of the similarities with the stock pedal. I'm also considering Lokar pedals, but big $$$$. Will your mounting bracket work with any of the Lokar DBW pedals? If so, do you know which ones?
~ Dan
My Chevy Pics:https://app.sugarsync.com/iris/wf/D7...115878_6210284
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 4 spd, PS, PB, AC, AM/FM
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-18-2015, 09:16 AM   #54
Hart_Rod
Hart_Rod's Avatar
Dan - I think the LOKAR pedal mounts very close to the way the Corvette pedal does, but I haven't ever used one. If it were me, I would just go with the corvette pedal. You will save yourself about $500.... Let me know.
Rob
Old 02-18-2015, 10:52 PM   #55
derotoreut
derotoreut's Avatar
Rob
OK Rob, you convinced me. I think I'll take your DBW bracket for my 71 LS3 swap. My pedals should match up pretty well with the 05+ Corvette pedal. Can you PM me payment details. I will reply with my contact info and ship address. Thanks.
~ Dan
Old 02-19-2015, 09:16 AM   #56
Hart_Rod
Hart_Rod's Avatar
PM sent.
Old 02-21-2015, 03:51 PM   #57
Houston Ben
Come on all, I can't be the only square guy that wants one!!!
Old 02-28-2015, 03:26 PM   #58
derotoreut
derotoreut's Avatar
Rob,
I received the Gen IV throttle bracket. It's a nice idea, but I was disappointed that the holes didn't line up. Hopefully this is a once only situation.
Here is my 71 throttle pedal compared to the Gen IV pedal.
Name:  Gen IV LS Throttle Bracket - 1.jpg
You can see when the original pedal bracket is placed on top of the new one, it doesn't line up. Bottom hole in line… Top ones don't match
Name:  Gen IV LS Throttle Bracket - 2.jpg
The holes would have to be re-drilled or re-worked some how. Top left hole in line… Others don't line up.
Name:  Gen IV LS Throttle Bracket - 3.jpg
Top right hole in line… Others don't line up.
Name:  Gen IV LS Throttle Bracket - 4.jpg
~ Dan
Old 02-28-2015, 05:59 PM   #59
Hart_Rod
Hart_Rod's Avatar
That's strange Dan. I've sold almost 40 of these and haven't had any problems with the holes not lining up. The dimensions of your pedal are the same as 73-87 pedals. Here's some pictures of my 86. If you don't think it will work for you, please return it and I will refund your money.
Old 02-28-2015, 10:05 PM   #60
derotoreut
derotoreut's Avatar
Rob - That is strange. My truck is an original 71 swb built in California and spent its life in Arizona. Did the 71 & 72 year trucks have nuts welded on the outside of the firewall, in order to bolt the original throttle bracket assembly to, from inside the cab? Mine is set up like that. This is my first 71, so I am not familiar with it. I have a 69 & 70 to, but their pedal assemblies were different. I'm just wondering because the only thing I could think of is unless someone changed it. It doesn't appear to be the case because when I took it all apart, everything appeared to be original.
I appreciate your consideration in allowing me to return the bracket. I will let you know if I'm able to use it or not. I want to smooth my firewall anyway, so I would be looking for a different way to attach the bracket. Thanks.
~ Dan
Old 02-28-2015, 11:05 PM   #61
Hart_Rod
Hart_Rod's Avatar
That's really crazy Dan. As far as I know, all of the years of trucks, 67-72, had the nutserts welded in that pattern on the outside of the firewall. I've had people with all of those years use this bracket, so I'm at a loss. If your truck was a 72, I would say maybe they ran out of 72 brackets and started using the 73's . Who knows. Just let me know what you want to do, and my apologies for the aggravation.
Old 03-01-2015, 11:03 AM   #62
TKulak
I have an 01 5.3 motor from a Yukon. Can I use the Corvette pedal if I repin it as shown in earlier post? Thank you
TKulak is offline   Reply With Quote
Old 03-01-2015, 11:48 AM   #63
Hart_Rod
Hart_Rod's Avatar
I don't think you can convert the 01 to a Corvette pedal. Did you see my adapter brackets for the truck/SUV pedal here:
http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Old 03-03-2015, 03:15 PM   #64
Houston Ben
Hi Rob,
Any update on the 86'
Old 03-03-2015, 05:26 PM   #65
roushinator
roushinator's Avatar
I got mine. Thanks Rob!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 03-29-2015, 10:42 PM   #66
Ikarus
Rob, I'll take one as long as it fits the 73-87. I've got a Corvette pedal ready to install.
Thanks,
Chris
Ikarus is offline   Reply With Quote
Old 03-30-2015, 08:37 AM   #67
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Houston Ben View Post
Hi Rob,
Not yet....
Thanks!
Thanks,
Chris
Chris, unfortunately I haven't had time to mess with the 73-87 pedals yet. Plus, I haven't had a lot interest in those specific ones. I'll let you know if something changes.
Old 05-06-2015, 09:40 AM   #68
travlinman
I would be interested in 1 for my 91 r30 crew cab (still 73-87 cab) with a 04 suburban 5.3
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 06-12-2015, 11:28 AM   #69
jessemthompson
Purchased this from Hartrod. I got it installed with my Vette pedal today. The fittment is perfect. Thanks for putting a good product out there Hartrod. This was one less hassle to deal with during my ongoing swap.
jessemthompson is offline   Reply With Quote
Old 06-12-2015, 08:48 PM   #70
jessemthompson
Here is a picture of it installe.
Old 06-17-2015, 10:13 AM   #71
Hart_Rod
Hart_Rod's Avatar
Looks Awesome!
Old 06-20-2015, 02:54 PM   #72
Rich84
Rich84's Avatar
I want one for my '84..but my pedal is from an Isuzu NPR..2005
Rich84 is offline   Reply With Quote
Old 06-22-2015, 01:40 PM   #73
Hart_Rod
Hart_Rod's Avatar
I'm not sure what that pedal looks like. Can you post some pics?
Old 06-25-2015, 07:38 AM   #74
Rich84
Rich84's Avatar
This is the pedal I have..
Sorry about the picture quality..Little too much wine last night.
Old 06-25-2015, 08:44 AM   #75
solidaxel
solidaxel's Avatar
What engine is installed in a Isuzu NPR 205 ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll ZZ4 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red 327
340hp 4spd 3:36
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wifes cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions Inc.
