04-14-2014, 04:40 PM | #101 |
Re: Pic Request: Rally wheels on a dropped truck
275/60R15,275/70R15 is the biggest & widest you can go safely or without it looking funny on an 8" wide wheel.
What size are you running & what size are you looking to move up to? |
04-14-2014, 05:00 PM | #102 |
Ok, I know you've heard 100's of suggestions...
So, here is mine: Front - Truck Rallye 7" wide Rallye w/ 225/75R15 tire 28.25 tall or w/ 225/70R15 tire 27.4 tall Rear - Truck Rallye 8" wide Rallye w/ 265/70R15 tire 29.6 tall or w/255/70R15 tire 29.05 tall or w/275/60R15 tire 27.99 tall This has always been my set-up of choice... FYI... the stock 235/75R15 tire is 28.87 tall Where to Find Rallye Wheels 5 lug 7" wide - 73-late 80's Van only 8" wide - 73-late 80's 2wd pickups & some Van's 6 lug 7" wide 73-late 80's 4x4 Blazer only 8" wide 73-late 80's 4x4 Pickup & some Blazer's .
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red Last edited by 67 cst swb; 02-05-2023 at 08:08 AM. |
04-14-2014, 05:17 PM | #103 |
X2
That's the same tire set up I'm running 225 front 275 rear |
04-14-2014, 10:39 PM | #104 |
Im running 225/75-15 front in back right now.. Im ok with the fronts but I want some more width in the back. Im thinking 275/60-15 in the rear... but maybe ill go 275/70's instead to keep them as tall as the fronts
1977 K10 shortbox Scottsdale 4x4 1988 C30 Crewcab Silverado 1987 K10 longbox Silverado 4x4 1969 GMC 1500 4x2 |
04-14-2014, 11:13 PM | #105 |
Here is my 71 gmc with chrome 15 inch rallies
04-14-2014, 11:26 PM | #106 |
I wanted to same look on my 68, so I made it so a month or two ago. I bought Corvette Style, 7" up front, 235/70/15 and 8" in the back, 275/60/15. The derby caps are Metal. Love the results!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-14-2014, 11:33 PM | #107 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Got Corn?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-04-2014, 01:38 PM | #108 |
new tires
06-04-2014, 01:58 PM | #109 |
Give you any ideas?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
06-04-2014, 07:31 PM | #110 |
Nice truck
06-04-2014, 08:53 PM | #111 |
I was referring to the sign above the truck!
06-04-2014, 11:12 PM | #112 |
2.5" drop spindles, 4" rear 15x8" 4" backspacing 255/60 fronts & 15x10" 5" backspacing 275/60 rears.
20x10 & 20x8.5" Billet Rally's on order!! Cant wait |
06-05-2014, 09:12 AM | #113 |
I do like that Burb.
06-05-2014, 12:25 PM | #114 |
Cheap, 15 X 8 Chrome Rallys (Discount tire) with 4 inch back space 2-1/2 front drop, removed a coup[le of leafs outta leaf springs in back. Free hub caps, no beauty rings
275-60-15 BFG radial TAs
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
02-02-2015, 04:38 AM | #115 |
Will 15x8 rally wheels rub the lower control arm with 2 1/2" drop spindles? I'd like to convert my '68 to front discs. I have 2" front drop springs already (not installed) but read they aren't the ideal way to lower the front. I'm thinking of running 255/70 all around. It seems I've read the LCA interferes with rallies but that might have been when I was looking to put them on my '94.
02-02-2015, 05:26 AM | #116 |
70+ ( Old Skool Club )
I called ECE a while ago with the same question as I had 255/70 15's on 15 x 8 rallys on all 4 corners on a stock height long box truck. I asked Mark at ECE if I put a 2 1/2 inch droppd front spindle up front with a 4 inch drop spring in the rear would the front tires rub on turns, and he said they may or may not. If you used a 245/60 15 up front or all the way around I am 99 % sure there would beno rubbing issues.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-02-2015, 09:41 PM | #117 |
heres mine. still under construction. my junkyard rally wheels. 8,s on front and back
02-02-2015, 11:24 PM | #118 |
BigBlockBobby
also under construction
Bob |
02-03-2015, 12:39 AM | #119 |
BFG 275/60-15's all around on a 4-4 drop...
02-22-2015, 05:44 PM | #120 |
70 GMC Serria Grande Short 70 Chevy C/10 Short LS Powered 72 Jeep J2000 4X4 86 El Camino (22k original miles) |
02-22-2015, 06:02 PM | #121 |
That sir is amazing ⬆
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
02-22-2015, 06:15 PM | #122 |
Whoa , that's nice. Never seen that one before
02-22-2015, 06:18 PM | #123 |
laying low
x2. That is a good look right there. Different color combo and the wheels.
02-22-2015, 06:45 PM | #124 |
I like Red but have to say that color is pretty sweet!!
02-22-2015, 07:45 PM | #125 | |
Thank you Tommy
Thank you Jon Quote:
