04-03-2015, 09:42 PM | #1 |
Re: Restoring 1980 C10 big ten.
As for the rest of the drive train that is where I started and then it sat for some time in that state.
383 stroker world s/r torqer heads ported/polished decent cam (can't rem the specs right now) summit 750 cfm carb 5.7" I beam rods with the cap screws for clearance on the crank SCAT crank flat pistons (federal mogul I think had a lightning bolt cut out of the special coating on the side) and if I remember correctly about a 10:1 comp ratio Premium gas is required anyway. Had the deck blocked, honed, magna fluxed and all that other good stuff at the local machine shop. put a shift kit in the th400 and added an aux tranny cooler Ran braided lines for tranny cooler and fuel - will get close up pics of that when I move the front clip over. |
Tags |
big 10, c10, frame off, restore |
