#151 |
![]() ![]() Join Date: Aug 2013
Re: 1965 C20 fleet side longbed DD low budget build.
I will need to get that....The cam is out of a 290HP crate motor with break-in time + 20 miles or so. I kept the cam and lifters in order to be used in some project down the road...Its supposed to be the 300HP/327 cam from yesterday's factory muscle car design. The 290HP crate motor is a turd because the heads don't flow or even develop any compression to make power so the cam couldn't really work right. It might be right up your ally with a mild build and better heads.
Joe |
#152 |
Hmm. I'll give it some thought. I was looking for a cam with around .460 lift and 290 duration but I'll take whatever. are they roller Lifters?
Well that didn't go as planned. 1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6 |
#153 |
Its a flat tappet cam. ...remember you just wanted to keep it simple....haha
#154 |
Hahah fair enough.
#155 |
OK...fresh off the Summit website
Camshaft lift is .450 intake / .460 exhaust. Camshaft duration at 050 is 222 degrees intake and exhaust. Lobe centerline is 114 degrees. Normal engine manifold vacuum for the 350/290 HP engine is 10-12 in I think the vacuum stated is low...this one had about 15-16" on idle Joe |
#156 |
hmm. What'd it run?
#157 |
Well got the grill masked and shot with primer and then layer a bit of color. Just finished hand brushing in the edges of the letters needs a little bit of cleanup on the C and the H mainky. But turned out nice. Finish touch up then some semi gloss clear Coat. And time to install
#158 |
#159 |
Hah. Price wise. I'm sure it ran amazing. Is that the cam in your 63?
#160 |
OH!, you youngins with that fancy spellin....."Free" dude, its yours if you will use it...and we can dig through the SBC drawer for more gold
#161 |
THANKS MAN!! shoot Alright. Sounds like I will owe you a favor. When's a good time to stop by? Maybe this weekend perhaps?
#162 |
Weekend is great...call or text when you are in the area and we'll hook up.
To answer your question on my 62 cam size, Edelbrock 7102 cam kit-.486in and .510ex with a 303 duration combined with a set of Blueprint heads 64cc-195 intake runners, 2.02in and 1.60 ex valves PN-H8002k |
#163 | |
#164 |
Befor and after photos of the same motor. 292 inline 6. sooooo I put the carb and headers on because I couldn't wait. but layed some color on the engine Tonight. Everything fit together perfectly. Chose Detroit diesel alpine green. Always loved the Detroit motors and how they look. So made mine look like it. Plus chevy orange is what everyone does. I like different. on the flip side, the 4 speed and my steering knuckles are chevy orange anyway
#165 |
Well found an air cleaner for the Carb. Thinking of changing it to an oval one. goes With The Long motor Look. But just to keep things updated. I bought a can of alpine green to finish the engine... that's about all... hoping to get it tied together a bit more this weekenD. Have one solid day to work on her maybe Saturday my goal is may 9th for the annual all American car day show in my town.
#166 |
Shot some color on the oil pan. And found a small hole in the bottom of it. The motor didn't leak at all when I looked at it. Turned out there was 1/2 inch of sludge in the botto.. some spots where so thick it was the consistency of Hard clay. sheesh but welded it right up and it's good as new.. and also made another attempt at tackling the brakes again. Been having a hard time with them due to the fact of stripped Bolts. Lost parts. Springs that cannot be found at any parts store.
#167 |
Matt--what springs are you missing?
1961 chevy K10 my build is------------61K10 build |
#168 |
In the picture. The blue one on the top right. The 1/8 rod behind it. The parking brake spanning bar. the the two slotted steel pins that stick threw the rubber boots on the wheel cylinder. And the swinging arm that interacts with the adjuster that I believe is pinned up on the top or the rear brake shoe.. I'm worried they may have been thrown out. :/
#169 |
Oh and the small red spring that's a return for that adjuster arm. That one happen to be new ish from when I ulcer it apart but shouldn't be difficult to figure out a replacement. I found that a 1971 C20 had 90% of the correct springs. And only a few are a tad shorter. This is the closest Iv found for a "complete hardware kit"
#170 |
Sorry didn't get the picture uploaded until now. It needs a lot of TLC but the drivetrain is all original and seems to be in working order. I have a '65 ton that will take the place of this mangled sheet metal. The '65 has 66K original miles on it. Also will give me a spare 292 and 4speed for the K20. Your truck is coming along nice. I hope to get to this project one of these days. I have several on my plate towork on.
#171 | |
#172 |
Well today was a parts picking up /ordering day. But got two engine mounts. Big bag of shinny new grade 8 bolts. two weld on D loops. A clutch kit. intake gasket. Oil pan gasket. And put the oil pump on order. It'll be in by 7 tomorw.
![]() Back to trucks.. got the motor ready to instal tomorrow if the rain clears any time. Pulled off intake&exhaust. Along with front grill and core support. Pulled the old 292 out with the cracked block. And found my long lost flywheel. ![]()
#173 |
Oops forgot pictures..ok well pictures would t load other than 2. I'll post the rest whenever it loads again. Other than that. Enjoy the 2 that did haha
#174 |
![]() Join Date: Mar 2013
Hoping to see that thing in tomorrow.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#175 |
![]() Join Date: Jan 2013
Truck looks good.
Aaron 1964 K10 1964 C10 1965 Suburban 2005 Yukon |
