Old 04-13-2015, 07:06 PM   #1
tim's68gmc
tim's68gmc's Avatar
black tar/glue under windshield rubber
Any idea's on what i can use to clean all the black sticky junk from around the wind shield opening?
vehicle's I own 1968 gmc 3/4 ton camper special
1972 gmc jimmy
1972 Chevrolet nova
1947 ford 1.5 ton dully
1997 f-350 1 ton
2007 Chrysler 300 with hemi
tim's68gmc is offline   Reply With Quote
Old 04-13-2015, 07:12 PM   #2
GMaholic
GMaholic's Avatar
Re: black tar/glue under windshield rubber
3M makes a cleaner that removes the nasty 3M adhesive, won't hurt paint, I'd try that first.
GMaholic is offline   Reply With Quote
Old 04-13-2015, 07:13 PM   #3
tim's68gmc
tim's68gmc's Avatar
Thanks i will look for it.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-13-2015, 07:51 PM   #4
REEDS 72
REEDS 72's Avatar
Try some paint thinner.
REEDS 72 is offline   Reply With Quote
Old 04-13-2015, 08:46 PM   #5
tim's68gmc
tim's68gmc's Avatar
Ok thanks
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-13-2015, 09:17 PM   #6
11SECSS
11SECSS's Avatar
You could also try using a wire wheel on a drill might make more of a mess so cover everything up.
1971 C10 SWB ...project in the works
2000 Camaro SS....weekend warrior/racecar
2005 Caddy EXT....Tow rig
11SECSS is offline   Reply With Quote
Old 04-13-2015, 11:13 PM   #7
leadfoot067
horsepower junkie
strongest solvent you can find,brake cleaner works,laquer thinner,carb cleaner...scrape off what you can first,then chemicals for the rest
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline   Reply With Quote
Old 04-14-2015, 02:57 PM   #8
bollybib
bollybib's Avatar
Acetone works well but go easy when you get down to paint level because it will take it off.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
