Old 04-17-2015, 11:27 PM   #1
k_n_browning
obd2 wiring?
ok hit a wall
pin 58 goes to pin2 on obd
pin 16 gets 12v battery
pin 4 Look like just a ground off the body
pin 5 is a blk/wht but I don't have this wire Where would it be on the pinout?
Check engine light pin 46 what ground would it be just blk or is it the blk/wht that I cant find or maybe remove in a opps.Thanks Kevin
k_n_browning is offline   Reply With Quote
Old 04-18-2015, 12:49 AM   #2
Robznob11
Robznob11's Avatar
Re: obd2 wiring?
I'm not positive, but I always thought the wire for the check engine is the computers way to provide a ground to a light wired to an open circuit. Lt1swap.com should have your answer s
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-18-2015, 12:25 PM   #3
ls1nova71
ls1nova71's Avatar
Re: obd2 wiring?
Both the black and black/white wires in the OBD2 port are grounds. I usually hook them together and ground them at the back of the head where the rest of the engine harness is grounded. Personally, I wouldn't hook the ground to the body.
The check engine light wire coming out of the PCM is the ground side for the light, you need to hook the other side to a "key on" ignition source.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
