Old 05-17-2015, 11:19 PM   #1
Larry.sisk
1972 C10 Trans swap
Just got the truck on the road after installing a doner engine(1985 350 with a Th350 trans ) it drives ok but it seems to sway and lean out in the corners soft suspension at 55 mph it feels and sounds like the truck needs to up shift question 1. How to ID my diff and its gear ratio . Question 2 are any of you guys running overdrive granny's like a 700r4. Question 3 what is a good combination of trans and diff for normal town and highway driving?
Larry.sisk is offline   Reply With Quote
Old 05-18-2015, 08:55 AM   #2
cdowns
cdowns's Avatar
Re: 1972 C10 Trans swap
tranny has nothing to do with the ride quality you are complaining about// check your suspension shocks springs balljoints as well as sway bars can have all the effect on ride quality
Old 05-19-2015, 01:07 AM   #3
68shortwide
68shortwide's Avatar
You can pull off your diff plate and turn it until you see numbers on the ring. Post those numbers on here. Second, 700r4's are a popular swap, and a 350/700r4 with 3.73 gears would be a great combo. Sway bars would help control the body roll you're speaking of.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 05-19-2015, 12:53 PM   #4
67 chevelle
67 chevelle's Avatar
alot of times the gear ratio is writin on the inside glove box door , also a code is stamped on an axil tube that tells the ratio , it needs to be deciphered , many came with 3.73 gears , your engine will wind out at highway speeds with this gear or 4.11s . a 2004rtrans will fit in the same spot as your turb0 350 , with some modification , and has overdrive
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-19-2015, 02:01 PM   #5
70blackfish
350/ 700r4 and 3.73 great combo. a lot of these truck didn't come with a sway bar, find one off a 1ton mid 70 early 80's truck at the junk yard. i got mine there 1 1/4 dia.
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
