Old 07-05-2015, 06:14 PM   #1
toms68cst
toms68cst's Avatar
Power Steering pump pulley loose
The power steering pump pulley (Off a 72) is loose and pretty floppy when the belt is off. I can't tighten or loosen the retaining nut more than a few degrees. Is there a key in the pulley and or nut? How does one go about tightening up the pulley to the pump?
It's noisy (Squeaky and rattly) when the engine is running it. The noise goes away when the PS belt is off.
Thanks, Tom
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 07-05-2015, 08:14 PM   #2
rustrunner
Re: Power Steering pump pulley loose
Pump pully has a key, but if it is floppy, then either the pulley is worn, or the pump shaft is worn. Straight shaft. As far as tightening the nut, it is most likely a lock nut and will be hard to turn. May have to replace the complete pump.
1970 Custom Camper/20
1959 Morris Minor 1000
1953 Dodge B-4-KA
1953 Fruehauf 30' Lowboy
1928 Cat 30
1939 TORO Bullet Tractor
rustrunner is offline   Reply With Quote
Old 07-05-2015, 11:29 PM   #3
davischevy
davischevy's Avatar
I just had the same problem. A new (different) pulley fixed it.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 07-06-2015, 01:00 AM   #4
leddzepp
Moderator
leddzepp's Avatar
Look at it from above while it is running. If the pulley "wobbles" it is bent and needs replacement. Some are bent so bad they will throw a belt. They are usually bent because of improper installation/removal using a three jaw puller and a hammer.
If it doesn't wobble and just screams while running you need a new pump.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-06-2015, 11:31 AM   #5
toms68cst
toms68cst's Avatar
Thanks everyone. That gives me a few things to check.
