Old 09-03-2015, 11:00 AM   #101
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: K30 Downgrade to Cummins Project
Well I'm overdue for an update. Hope you all have had a great summer. I have been swamped at work, at with remodeling projects and windmill projects. Since I'm so busy I had Ryan (dieselwrencher) take the engine a month ago. He is going to open it up and help me determine if we should rebuild it or just regasket and make the appropriate fuel and air system mods. Any update on that Ryan?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 09-04-2015, 05:53 PM   #102
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I have removed the injectors and exhaust manifold. I have to finish the comp check and then I will yank the head to give you the report. Hopefully I will be calling you Sunday Jud.
Ryan
1969 Chevy milk truck
Old 09-08-2015, 10:46 PM   #103
Vintage Windmills
Vintage 4x4s
Ryan, sounds good keep me posted, hope you had a good holiday weekend!
Old 10-27-2015, 08:47 PM   #104
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed !
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 01-22-2017, 12:58 PM   #105
maxx442
maxx442's Avatar
What ever happened on this build?
maxx442 is offline   Reply With Quote
Old 02-23-2018, 08:51 PM   #106
Vintage Windmills
Vintage 4x4s
Life happened. I am back on the forum now. Awhile back Ryan (dieselwrencher) rebuilt a sweet engine for me that should perform really well for this application. The one I had internal damage and cracked head. Starting to think about this one again, I don't want the engine to sit too long. Busy with my ochre K20 though at the moment.
Old 03-24-2018, 12:09 AM   #107
Peanutbutter
Hi. we have 2 single wheel K 30s in the family so I'm watching your build, but for right now I'm wondering if you know where theres a 16 foot wheel and tail for Aermotor. Found the head in New Mexico, we already have 8 ft but this 16 ft is huge.
Peanutbutter is offline   Reply With Quote
Old 04-08-2018, 11:37 PM   #108
Vintage Windmills
Vintage 4x4s
Cool! I don't see many SRW K30's, you are fortunate to have a couple.
As for the Aermotor, the wheel and tail won't be cheap for that size of mill but I can give you some names to check with, shoot me a PM. The 16 footers are massive machinery. Did you know they made a 20 ft?! Those are monsters too.
Old 01-09-2019, 06:00 PM   #109
Vintage Windmills
Vintage 4x4s
Hi all, I got some other projects out of the way and the shop cleaned. That said, after a 4 year hiatus I pulled the truck into the shop and am entering the engine install phase!!
Anyone still subscribed out there? Seems pretty quiet around these parts of the forum lately.
Old 01-09-2019, 06:45 PM   #110
Vintage Windmills
Vintage 4x4s
Pics. Picked up a used 2 ton hoist off Craigs. Cut the engine x member carefully and now it looks like I need to cut the one just behind the core support. Hoping to get by without a lift, but just a set of Airlift airbags on front axle. Rear already has Airlift. I just don't want a tall tow rig and it sits fairly high already with the tall 1 ton frame and 285/75/16's I'm planning on.
Wheels on engine hoist are crap, need to upgrade them before I do much more. Have to kick it side to side or put a pliers on them to get them to swivel.
Old 01-10-2019, 12:46 AM   #111
COS399
COS399's Avatar
Well that is one way to stab a motor. keep us posted.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 01-10-2019, 01:40 PM   #112
6BT 56
6BT 56's Avatar
You have mounts that let it go diecctly on to the Factory crossmember ? I do t know if I have seen that . Keep us in the loop now that your moving fwd. if you have a few cool windmill pics thro one or two up. I'd love to have a nice old one around the farm. I bet there not too easy to come by these days .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 01-10-2019, 02:38 PM   #113
Vintage Windmills
Vintage 4x4s
Thanks, will do. Core support was junk anyways and this allows me to mock up fits without fighting it
One option uses upgraded BBC style mounts with the crossmember dropped a few inches. Below is a pic of that mount.
Also a pic of the other way I'm tempted to go which is a fluid mount that the 4BT guys like for its smoothness. I'm not sure if just one per side will take the torque of my 6BT but I could do 2 per side maybe.
Old 01-10-2019, 04:38 PM   #114
Dieselwrencher
Did you decide against building your own cross member? I'd go with the poly clam shells over those fluid filled ones IMO. You could do 2 per side but if you're going to do that, why not use a t bushing and DOM and build your own?
Ryan
Old 01-10-2019, 07:29 PM   #115
Vintage Windmills
Vintage 4x4s
Hi Ryan, glad you dropped in. Haven't given up on building my own xmember. I really just need to position it where I want it to clear trans tunnel and rear rocker cover to firewall and see where things sit. I just don't want to lift it more than Airlift system can do. Are you aware of any Tbushings that are fluid filled? Just hoping to get the advantage of hydraulic damping to take some vibration out.
Old 01-11-2019, 07:27 PM   #116
Dieselwrencher
Jud, I don't know of any liquid filled t bushings. I have auto world's poly first gen mounts in my 72 and I have no complaints with them. I don't feel they allow the engine to vibrate much at all. In fact they feel better than the oem 2nd gen ones. They are far superior than a rubber first gen bushing.
Ryan
Old 01-13-2019, 10:39 PM   #117
Vintage Windmills
Vintage 4x4s
Got the trans/tcase/gearvendors fitted in. I have the engine at 4 degrees (front higher than rear) and the rear pinion angle is about 4.5 so its pretty close. Its all shoehorned it but I think there is enough clearance for everything, but top two tranny bolts will be a pain unless I can drop the tranny crossmember and count on the engine mounts flexing a little...
I need to figure out where to mount the AC compressor, the low position beneath the water inlet won't clear the frame and crossmembers since my engine needs to be low in the frame. I was reading that one from freightliner application may work but need to find where to purchase but need to first confirm it will work.
As for the radiator to engine - with the BBC 3 core rad in factor position, there is 3 inches to the tip of the threaded shaft where the mech fan would mount. I don't have a mech fan handy to measure, can someone tell me if that would fit? I'm betting no and that I need to run efans. Probably good anyways since this truck won't be used in town or traffic much. Mainly a highway truck and highway tow rig.
I am fighting to log into the site on my iphone, I don't think there is an app for this site? apparently Safari doesn't work with the site.. So its a pain to get photos on
here.
Ryan, good to hear the poly 1st gen ones aren't too bad. Trying to see if they'll sell me just the isolators. Do you have just two isolators under your engine or 2 per side? They are saying a quad mount is recommended for 400+ HP.
Old 01-14-2019, 03:38 AM   #118
garmar
garmar's Avatar
Glad to see your project is moving along again. Been following this one for a long time. Nice truck and that engine stand is amazing!
garmar is offline   Reply With Quote
Old 01-14-2019, 12:14 PM   #119
Vintage Windmills
Vintage 4x4s
Thanks! Glad to know more people look at this and its more than a notebook for a couple of us!
Old 01-14-2019, 12:18 PM   #120
Vintage Windmills
Vintage 4x4s
Here is the engine sitting approximately where I want it. Trans is only 1/2" from tunnel in a few spots!
I am fighting the turbo drain tube, its right where I want the mount....
Tranny was a remain and it looks really great inside but I'm not a trans expert. I'll try to get more closeups for you guys. I don't think i need to touch it - drove well in the old crusty dodge. Anyone able to decipher a date code from it?
Old 01-14-2019, 02:17 PM   #121
dieseldude4bt
Third gear and it's blocking ring look realy worn, did it have any problems shifting into or jumping out of third?
These are common problems with the G360 trans.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 01-14-2019, 02:34 PM   #122
Vintage Windmills
Vintage 4x4s
It shifted and held like it should for a few miles of driving. I will try to get some better pics, there was oil all over the parts (trans still full) that makes it unclear. Will be a few days before I slip it out after the mock up phase here.
Old 01-14-2019, 11:01 PM   #123
Bdb68
I'm happy to see this thread hasn't died. Hopefully you get this truck done soon so I can steal ideas for my 86 CCSB Cummins project.
1955 Chevy 210, 6.0ls supercharged
1968 C10 original paint, 2wd, swb, 6.0ls/ 4l80e
1968 Custom Camper 4x4 Duramax Build Site.
1972 Crew Cab Project
Bdb68 is offline   Reply With Quote
Old 01-16-2019, 11:31 AM   #124
Vintage Windmills
Vintage 4x4s
Nope I'm motivated to get this running and its winter so I have some time
I'm hung up on the AC compressor, need to figure out if I can put it just above the coolant inlet and under the Alternator. The alternator is definitely too low for that currently but I see there are some high mount kits available but I'm not sure if the belt routing or space would allow the compressor between alternator and the water inlet.
This truck has never had AC but I need it since this is a tow rig I'll be using on long trips in the summer and its got a dark red interior! I have some NOS thermo king Auto AC units I could add but they were for R12 and I would have to find a condenser that would couple with them. It may be easier to buy a vintage air unit but I need to research them. I'm not sure how hard it would be to get the factory AC system from a squarebody and swap into my truck? Anyone know if they are just as many components and as complicated as a 67-72 AC system?
Old 01-16-2019, 08:15 PM   #125
Dieselwrencher
Auto world will sell the poly isolators separate last I knew. I hope so because they have the patent on them and are the only ones building them as far as I know. I only have 1 per side in my truck. It makes well over 400hp, I've towed 25k and higher and not had any issues with them.
From what I can see on your engine position, you are still way too far forward. I can also tell you, for a tow rig you want a mechanical fan. You will want to jump up to the dodge radiator too and ditch the stock BBC radiator. My truck has a stock BBC radiator and it does just fine towing 15k on an open trailer. Hook an enclosed trailer or 5th wheel camper on it and she gets warm. I don't have a shroud on it but I don't believe putting a shroud on it will be the cure. I feel a larger radiator is the cure. So, with that being said, I'd just modify your core support and put a 94-02 dodge radiator and intercooler in it and be done with it.
I realize you're trying to get by with not much lift but I don't think you will get there without putting the engine a little farther down and back more. If you want I can send you a dodge exhaust manifold so your mount issues are a little easier. I probably have a dodge oil drain too. The ford bus/F700 AC mount is probably the one you're talking about. They're pretty pricey. Auto world also makes mounting brackets and a dual pulley to put ac compressors on the head above the injection pump.
Ryan
