Pitman Arm the same from 67' to 72'?
I picked up my 68' just over a year ago. At some point a PO upgraded to front disk brakes with 5 lugs front and rear. Since tearing down the truck I found a mix of steering parts that has been causing me frustration. The front disks are 71'-72' but the inner/outter tie rods and center link are 68'. Looks as if the disks were an aftermarket conversion item that allowed the PO to keep all the 68' stuff.
I have since installed an ECE 4/6 drop kit. Now the tie-rods don't fit which means my center link must be changed too. If I go to a 71-72 centerlink can I keep the 68' pitman arm??
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
![]() Join Date: May 2009
Re: Pitman Arm the same from 67' to 72'?
I have the same problem but backwards. My po had the 71/72 centerlink and tie rods on my 67. If you get a new centerlink I may be interested in the 68 centerlink.
I am fairly sure that the pitman arms are the same for all years
Between Trucks...
According to LMC, pitman arms are different through the years. 67-68, 69-72, 67-72 with PS. 4 wheel drive being different as well. Don't know if LMC are correct though.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 02-28-2010 at 01:53 PM. |
Well, until I saw this I thought I figured it out. CPP is selling the same pitman arm for years 67-72 so I thought they would interchange. Now I don't know.
Between Trucks...
Just went over to Classic Parts. They list one for '67-'72 manual steering and one for '68-'72 power steering.
Beat it to fit, Paint it to match... ![]() |
No problem. I'm looking for a 71/72 so you are welcome to the 68'. It has been cleaned, painted with black rust inhibiting paint and includes the idler arm and idler support arm. I'm not sure if I'll need the idler parts. I'm waiting to hear back from someone selling the 71/72 setup. I will get back to you when I hear from him.
Between Trucks...
Over at ECE they have pitman arms for '67-'68 manual steering, '68-'72 PS, '69-'72 manual steering.
#9 | |
67-68 manual same part 69-72 manual same part 67-68 power same part 69-72 power same part 4 wheel are different Last edited by mbgmike; 02-28-2010 at 06:23 PM. |
Junior Member
Yep, what they said.
My '67 is a mixture of parts and they all work together. I have manual steering. The front suspension is from a '68 C-10. The steering box, drag link, pitman arm, idler arm, inner tie rods and adjusting sleeves are from a '67 C-20. The outer tie rod ends are from a '67 C-10. This pretty much show how the rest of my truck is also. A little off thread, but just wanted to share. We figured out every thing using our handy LMC catalog. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Yes. Pitman & idler don't have to be changed. I swapped later disc brakes to my 68 using the 71-72 drag link w/the original manual steer pitman & idler.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-28-2010 at 07:35 PM. |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I know this is an old thread, but I'm still on the search for confirmation. Some have said the 72 had a longer pitman arm. Possibly giving a tighter turning radius.
![]() Join Date: Sep 2007
when i did my steer conversion i went from manual to pwer steer from a 72 doner, changing the gearbox and the steer rack. the pitman arm from the 72 power steer rack had the same # cast on it as my 67 non power steer.
1967custom |
