Shortbed question
Hey guys, I know this might be a dumb question but I cannot think of an answer. So in a shortbed conversion you usually take 12inches out of the middle, and chop 8 inches right off the back. that's 20 inches. But a longbed is 8ft, and a shortbed is 6.5ft. isn't the difference in that 18 inches? I could just be missing something simple,but why is it 2inches off? Thanks!
![]() Join Date: Feb 2015
Re: Shortbed question
You can use the search function and should find lots of good info on here about it.
Tim Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present". 1971 ![]() Last edited by NTIMID8R; 09-13-2015 at 11:28 PM. |
Keepin an eye out
Measure twice - cut once/
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
There are several walk through's on how to do it right.
The measurements have already been done, take it as fact and move on. |
Sorry I can't give you a walk though of personal experience cutting a frame down, but here is a link to a shortbed conversion thread you might find useful.
http://67-72chevytrucks.com/vboard/s...=peach+orchard
Scott |
![]() Join Date: Aug 2004
most long beds are 12" longer in the front and 8" longer in the rear.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I did the LWB to SWB conversion with those numbers and it lines up perfectly. Lifted the newly cut bed, rolled the truck underneath and the bolts slide right in the holes. Cab to bed gap looks good too.
Rutt Rowe,
I cut 60" out of my wheelbase and about 10' off the back (after axle). Are you saying I cut off too much? Just kidding. The 12" off the middle takes the frame from a 127" wheelbase (long) to a 115" wheelbase (short). The 8 inches off the back just works as this is up under the bed and keeps it from hitting the back rail when the bed goes back on. Like said earlier, "it's been done a lot, and these numbers work". Google shortening a long bed. There are videos of Stacy on Gears doing it. I watched those videos quite a few times before my first, and have since done a few more. Works.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
