12-19-2015, 11:14 AM | #1 |
Cutting Plexiglas
Does anyone know an easy way to cut plexiglass in a circle ,I want to cut a piece to cover a 15 inch tire where the wheel goes just over the lip ?
12-19-2015, 02:16 PM | #2 |
Equal opportunity joke ofender
Re: Cutting Plexiglas
If your looking for a perfect circle, get a measurement of what you want then see if any of your local sign shops have a CNC router, most will cut it out for you pretty reasonable. If perfect is not required just grab a hand held sabre saw with a fine blade that the teeth point straight forward or worse case point up. dont use any that point down because if the plastic heats up and grabs the blade it will break the plastic when the saw comes back in contact. A hand held router would work as well if you wanted to cut a jig out for it.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
12-19-2015, 10:15 PM | #3 |
Thanks for the tips ,when I get my plexiglass I will see what happens .
12-19-2015, 11:20 PM | #4 |
ALso keep in mind there are different types of plex. There is G, MC, optix and others and they all do not cut the same. Some of them do not cut as nice as others and will melt back together as you try to cut thru them. If that happens just keep on cutting and make a 2nd pass. If you have a deep throat band saw that would also work nice as long as it is not a coarse wood blade in it.
12-20-2015, 12:41 AM | #5 |
Old member
I use my Roto Zip to cut with. It is one of my best tools.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-20-2015, 11:52 AM | #6 |
Andy ,where did you buy that tool at ,looks useful for many different projects ?
12-21-2015, 08:40 AM | #7 | |
Old member
It can cut just about anything but metal. I have cut through nails though!
12-21-2015, 10:43 AM | #8 |
Andy,I just ordered a kit like yours off Amazon for about $70 shipped ,should be here before Christmas ,thanks for the info.
John |
12-22-2015, 07:48 AM | #9 |
Old member
Your welcome. They have all kinds of different bits. They will cut holes into solid surfaces. You just angle it a little and start into the surface and it will cut a hole. I installed 15 sets of golf cart head lights in half a day one time for a local cart shop.
12-22-2015, 08:25 AM | #10 |
We used a bandsaw.
After marking the radius, it cut a perfect circle
Happy as a pig in mud |
