Old 02-22-2016, 11:59 AM   #1
biohazardbill
LS swap.... fuel tank mods?
What have you guys done with your fuel system when converting to LS or any EFI application?
Modify the stock tank?
New Tank?
biohazardbill is offline   Reply With Quote
Old 02-22-2016, 01:40 PM   #2
Bigdav160
Bigdav160's Avatar
Re: LS swap.... fuel tank mods?
I used a 40 gallon square body Suburban gas tank:
Bought a extra rear crossmember from the parts board and installed it just rear of the rear axle. The existing crossmember I moved back. These two give the square body gas tank straps something to bolt to.
Relocated the filler neck to the corner. The original filler neck is like 1 1/2" and the square body filler neck is 1 3/4". I had to glue a rubber spacer in the hose to make up the difference. I'm using aftermarket gauges so the old filler hole now has a sender in it.
Installed a ep381 fuel pump on the stock sender.
EFI line and hoses.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-24-2016, 04:32 PM   #3
1970greenburb
I purchased a aluminum tank from boyds welding. It came with the fuel pump inside and sending unit. Really nice guys to deal with.
1970greenburb is offline   Reply With Quote
Old 02-24-2016, 04:41 PM   #4
enduroride
enduroride's Avatar
I did the Boyds Welding tank with the pump and sending unit as well !
Cant go wrong with that !
Enduroride
2016 Silverado2005 GMC Sierra
2002 Chevy Slverado Extra Cab (youngest sons)
2009 GMC Denali (oldest sons)
2015 Lexus 250i (wifes)
1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY"
http://www.louisianaclassictruckclub.com
enduroride is offline   Reply With Quote
Old 02-24-2016, 08:02 PM   #5
Kevco72
I bought a new stock suburban tank and bought an in tank pump with the LS filter and line kit from Tanks Inc. The pick up has a tray so fuel sloshing will not be a problem.
Kevco72 is offline   Reply With Quote
Old 02-25-2016, 10:37 PM   #6
SIXTY9CST
Hey guys I'm looking at the boys tank for my 68 burb as well, Were you able to use the tank the way they send it? were there any modifications needed as far as the fill neck location? any other info you can think of would be greatly appreciated.
Enduroride
SIXTY9CST is offline   Reply With Quote
Old 02-26-2016, 01:13 PM   #7
1970greenburb
It all depends. Is your rig stock height or bagged. Mines is bagged so I mounted the tank on the top of the frame rails so it would have more ground clearance. When you order the tank you can have them put the filler neck any where u would like ( they charge for that). So I don't know if mounting it in the stock location if the filler neck clears the top of the frame or not, I think it would. Give them a call they are good guys to deal with, hope this helps.
