03-16-2016, 03:57 AM | #326 |
K5drive
Re: Softop installation no Holes
Damholl check you inbox
03-16-2016, 10:34 AM | #327 |
PITbut
Rob, are you seeing my messages? I emailed, twice, pm'd a couple times and posted here. I would really like one.
Please let me know how i can get a hold of you.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
03-16-2016, 05:25 PM | #328 |
Has anyone got there's installed execpt the designer?
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
03-17-2016, 12:30 PM | #329 |
curious on this as well.....
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
03-17-2016, 10:44 PM | #330 |
I installed mine a few weeks ago
03-18-2016, 04:28 AM | #331 |
K5drive
Lyric there maybe some technical issues with my system as my inbox is alway full and very difficult to manage and for that I appauligise . You can reach me at srpenner@hotmail.com where I don't have a limit on data . Its hit and miss here on he best of days and I'm trying to get it straightened away but need more time. For anyone else looking to purchase or even just questions ,suggestions or even to say hi . Please contact me without technical disappointment at srpenner@hotmail.com
Wondering when I get to see more pics of installs and maybe some Blazer up my way for a weekend getaway regards Rob |
03-18-2016, 05:48 AM | #332 |
K5drive
In this picture you see a dotted line where I trimmed the header down so It doesn't contact the bottom of the rain gutter. If this is contacting it means that the area around the 5/16 bolt through the visor is not mating the surface together and as such will cause stress cracks with repeated cycling on and off at the bolt. Carefully trim this area down till it does not contact when bolted down. Hope this helps Regards Rob.
03-18-2016, 06:01 AM | #333 |
K5drive
JackB your install looks great but the question above appears to apply . I may be wrong but have a close look and let me know if my eye has detected what I think I see. I aim to get every one a perfect install. Also it's a matter of preference to use the screw that goes through the seal as it serve to remove the Header quickly without that screw. I sometimes remove the Header with softop attached and pull it through to behind the seats using the roll bar as in like a "t" top rig . I can bungy the header to the bow poles at the inside of the top so I can still use review mirror. Haven't gone on the hyway like that yet but I think it's ok
Regards Rob |
03-18-2016, 06:19 AM | #334 |
K5drive
This picture shows how I take the header with softop per attached and fold it back behind the seats around the roll bar bungy chording it to the underside of the top with tension pulling to the back towards the rear bow poles . If that makes any sence lol.
03-18-2016, 09:05 AM | #335 | |
Thanks so much for the info.
03-18-2016, 09:07 PM | #336 |
I'm up out of the gutter slightly.
03-19-2016, 12:35 AM | #337 |
K5drive
That's awe sum cause the 5/16 bolt will be pulling together where it can put the correct pressure onto the seals when and if you chose to implement the seal. Great install. Will likely be quite invisible when top is on . Great job !
03-20-2016, 10:48 PM | #338 |
Here are a few of mine showing the trim Rob shows with the dashed line. A few of of a couple other odds and ends. I used pop rivets for mine, and I covered them on the backside with rubber backed canopy take to avoid any scratching.
03-20-2016, 10:51 PM | #339 |
Try #2 for pics.
03-20-2016, 10:56 PM | #340 |
Try #3
03-20-2016, 10:58 PM | #341 |
Try #4
04-23-2016, 02:49 PM | #342 |
K5drive
Looks good GibberHow do you like the it over all ? Now I have found some nuts anchored in plastic to remove the header without tools. Then I sometimes take the Header and softoppers front and fold it back behind the bucket seats and bungee chord it to the roof line inside to make the truck look like "t"top and you can still use the rear veiw mirror that way. . It works really well when you are close to getting rained on but not sure how bad for easy cover up . LOL.
05-16-2016, 03:05 PM | #343 |
I would like one of these. Let me know how to get one please.
05-17-2016, 02:47 PM | #344 |
try emailing him... srpenner@hotmail.com
05-25-2016, 10:58 PM | #345 |
Hey Rob,
Overall I'm very happy with it. Had a friend come by to help out with the fit up, we took our time and I think it turned out great. Now that the top is down most of the time I'm going to pull it off, get it sanded down and painted. Gibber |
11-02-2016, 11:23 PM | #346 |
Got mine in the mail about a month ago. Looks good. Probably going to need advice on install. Thanks Rob for making this possible
11-07-2016, 03:08 AM | #347 |
K5drive
Very good just take your time . The Header fits pretty snug so any seals installed under the header will work fine so making it sit as low as possible is the best fit you can get . Good luck and happy building can't wait for more pictures .
11-19-2016, 03:23 PM | #348 |
That looks great. I put a soft topper on my 71 as well. When the front windows are rolled all the way up, does yours have a gap of about 1" from the top of glass to the fabric of the top?
12-13-2016, 03:28 AM | #349 |
K5drive
Yes close to that . I've been working out a way to close that gap with a peice of 4" black abs pipe, cut a strip out length wise (about 1/3 of the abs pipe) to attach to the fwd mounting position would be the top of the windshield post and the other at the aft of the window but mounted perhaps off the roll bar and poles from the softopper mounting hardware . If some put their talents together you could probably seal the hole window with little effort making you Blazer essentially leak proof and I don't know about you but I like that idea.
2nd note I have a good head start on a redesigned pop up camper for my 1st gen Blazer . I hope to be showing it off to you this coming summer |
12-13-2016, 04:47 AM | #350 |
K5drive
