03-29-2016, 02:46 PM | #1 |
small and big bearing hubs
Question--can you replace dana 44 1973-76 1/2t small bearing spindles with big bearing spindles and hubs?
1961 chevy K10 my build is------------61K10 build |
03-29-2016, 07:23 PM | #2 |
Re: small and big bearing hubs
Yes, you will also need a 3/4 ton backing plate/caliper mount
03-29-2016, 08:05 PM | #3 |
kwmech--I thought you might know! thanks for posting. new parts are disappearing and the big bearing spindles and hubs can be found new. the small stuff is after market even avl.
03-30-2016, 01:07 PM | #4 |
the 3/4t backing plate have a bigger center hole?
03-30-2016, 03:21 PM | #5 |
1/2 ton will work too.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
03-30-2016, 04:31 PM | #6 |
No, same hole, but the 3/4 ton rotors are larger in diameter than the 1/2. So you need the 3/4 ton plate so the caliper will sit on the rotor in the correct place. If you use the 1/2 mounting plate the caliper will rub on the rotor.
03-30-2016, 04:32 PM | #7 |
03-30-2016, 04:49 PM | #8 |
I replaced the small bearing spindles on my 72 d44 with big bearing spindles from a 1977ish 1/2 ton. I used the spindles, rotor/hub assembly and caliper mount. Everything went right together. 1/2 ton 6 lug
03-30-2016, 05:09 PM | #9 |
Yeah, my bad, I get so used to people converting from 1/2 ton to 3/4 I associated with the big bearing. Same spindle on the 1/2 and 3/4 in the later years. So yes the same 1/2 ton backing plate, either small or large spindle
03-30-2016, 10:31 PM | #10 |
Just did this myself. Big bearing spindles on D44 under 1/2 ton truck. Still using stock 1/2 ton 6 lug rotors/ Calipers/ and everything else stock but the brains and seals- they are different.
03-31-2016, 12:53 AM | #11 |
Actually the seals and outer bearings are the same. The inner bearing changes from a 603049 to 104949. Depending on the year, there may be a difference on the back of the spindle.
11-25-2021, 12:25 PM | #12 |
Sorry to revive this thread
But I have a question and I can’t seem to find a definitive answer. Background: I have a 73 (small bearing hub) Dana 44 1/2 ton blazer. It has the V shaped caliper mounts. I want to replace the hub/rotor/spindle assembly with the later model big bearing hub assembly, which I see in countless places is a direct swap. My question: Can I use the 73 calipers and V caliper mounts with the post 77 spindle/hub/rotor? Or will I have to source different backing plates to mount the calipers? Thanks Reid
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi Last edited by ky-donzi; 11-25-2021 at 02:19 PM. |
11-25-2021, 03:03 PM | #13 |
11-25-2021, 03:29 PM | #14 |
Awesome! That makes my life easy!
Napa has new hub/rotor assemblies cheap. All I have to do is buy the plentiful large bearing spindles and new inter bearings Thanks so much,,,happy thanksgiving!
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi Last edited by ky-donzi; 11-25-2021 at 04:42 PM. |
