![]() Join Date: Dec 2015
72 K20 unknown wire??
Does anyone know what this connection is for?? Its very short.
Re: 72 K20 unknown wire??
Sorry, couldn't get it upright. Its part of the engine wiring harness.
20' Daredevil (Ret)
![]() Join Date: May 2003
I'll be watching this thread. My truck has the exact same connector and I'm pretty sure it's never been hooked up to anything in the 39 years I've owned it.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Can't tell from the picture what color it is.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Brown, if I remember correctly
Any chance you can post a SPID pic? Could be the tie-in for cab lights, for example, but I don't know how the truck is equipped.
Easiest way to know for sure would be to follow it back to the fuse bulkhead and let us know which cavity it comes out, that way we could determine what it's most likely for. From position and color it's tough to know...
![]() Join Date: Apr 2013
I think that has something to do with the emissions on the original intake. There was a wire that ran over there from passenger side of the intake. Not 100% sure.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
Well, looking at the SPID, there is nothing indicating cab marker lights and as far as some thing from the original intake...it still has the original intake. Can't find where it would connect. It plugs in at the firewall abd is part of the engine harness.
All about them K’s
![]() Join Date: Jun 2014
My 72 K20 has that same wire unhooked. Not sure where it goes but the truck runs fine with out it so I never put much thought to it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
If it has a sunroof its probably the seat eject wire?
1972 K-20 Custom Camper 1971 K2500 Custom Camper (Sold) 2014 GMC 2500HD DMAX |
The wire is brown with a white stripe. It enters the fuse block with a larger gauge purple wire.
No indicators here |
FWIW, I found in another thread: "the brown/white wire you describe runs from the key switch to the firewall block on the diagrams I have. It is joined there by a solid brown wire that runs back to the cluster plug to pin 8 on the idiot light dash. It is used to feed the alternator field exciting circuit through the regulator.The ammeter dash does not have this wire."
If you had gauges, I'd makes a guess that that's why its not connected, but I don't think you do, so I'm still at a loss. Swing and miss for me I'm afraid!
Thanks for the input
#14 | ||
20' Daredevil (Ret)
#15 |
![]() Join Date: Jul 2010
I have that same wire on my 72 k20.
1969 chevy c10 lwb stepside 250 6 3 ott 1971 chevy c10 lwb 250 6 with power steering 3 ott 1972 chevy k20 4x4 350/TH350 automatic 1978 chevy Malibu 4dr 305 2bbl (all original) 1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver) |
#16 |
Thanks mike, that's helpful. What gauge would it have gone to?
#17 |
![]() Join Date: Jun 2009
That is where you hook it to the computer diagnosis
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#18 |
All about them K’s
Mine has gauges as well. That would make sense.
#19 |
Scrapper 1
And they call you guys Chevy guys.OK if none of you had a 1971 chey truck you probable don't know this smog option Its was the trans spark controller it has a dash pod up next to the front of the carb on the passenger side there are 2 relays on the fire wall 2-3 inches away from the driver side spring there is a harness that splits off and connects to the 2 prong relays and goes back in to the plastic wire protector comes out 2 wires with a 2 prong plastic plug to connect to the dash pod 1 wire goes from the dash pod down the engine down the trans to something.I think i have a pic of it let me check
My only problem to most of you guys trying to put your truck back to factory 98.9% of you will never go completely back to factory. That experiment was a one off wonder.Most of you PULL ALL THE SMOG parts off your trucks any ways. Now getting past that most people use that wire for a under hood light cus it has 12 volts to it until the key is turned off. Some use it for a hood light and they use it to power there electric choke for your Edalbrock or holly carbs. My pics are not that good showing it cus its something most of us GM guys don't Care about or the true GM guys do. The guy that most of you should talk to about Junk parts that should not be used on GM trucks is the LONGHON MAN There Are disconnected parts on all GM cars that where a BAD IDEA. GM DID IT CUS THE EPA WANTED IT DONE THERE WAY. We all know are government Sucks when they think metaling in are car's performance. at one time they thought headers was a smog problem.running a bigger carb was bad for are Air. THE EPA dose not talk to any one in the the Performance department on how a engine runs better then the guys that do it for a living |
#20 |
Scrapper 1
here is some more of pics of the old carb and that dash pod
