Old 08-14-2016, 09:27 PM   #1
hagenkustoms
hagenkustoms's Avatar
1952 Chevrolet 3100 on s10 frame with LSX- build thread
So I figured I might as well make a build thread. I started out with a 1984 single cab long bed S10, a front clip, a cab from a 52, a short box from a 49 and a 1999 4.8 litre and a 4l60e. I paid 300 for the s10 delivered, 800for the clip and cab and title, and 300 for the 49 box. The truck will be matte bright white with gloss black grille, bumper, door handles... All the trim. Cab is sound deadened with fat mat. I have Dakota digital vhx gauges, vintage a/c, stern beast 20" wheels, tanks Inc fuel tank and set up, psi wiring harness... And a bunch of other nice parts for it, I designed custom hood emblems also. Pics coming!
Here is the 52 parts hat I started with .
Here are the truck parts
4.8 with 120,000 on it
My build thread for the bagged 91
http://67-72chevytrucks.com/vboard/s...d.php?t=654179
Build thread for the slammed 52
http://67-72chevytrucks.com/vboard/s...=1#post7683427
hagenkustoms is offline   Reply With Quote
Old 08-14-2016, 09:34 PM   #2
hagenkustoms
Re: 1952 Chevrolet 3100 on s10 frame with LSX- build thread
I read everyone else's posts and changed he measurements a little because I want my truck on the ground but with no air ride... So here are some of the mounts I made
Some weld action
I made some panels and brad rolled them for the firewall
Seat installed and column mocked up
Old 08-14-2016, 09:40 PM   #3
hagenkustoms
In having a local upholster do my seat, door panels and headliner kind of similar to this
These are the wheels I have 20x9 Stern Beast wheels. I wanted a somewhat modern resto mod type look
These are the headlights which I think will be awesome against the matte white
Old 08-14-2016, 09:45 PM   #4
hagenkustoms
Trans painted
Motor painted, did the valve covers matte white. I used a 1970 gm fleet bright white and then sprayed a matte clear on top
Intake cover, it rid of the vortec
Here are the logos I designed and had a friend cut them out with a cnc laser, these will be gloss black on the sides of the hood
Old 08-14-2016, 09:48 PM   #5
hagenkustoms
Hand made trans crossmember, it's now bolted through the side and the top
More weld action
Frame painted with chassis saver-I'm gonna drive this thing !
Old 08-14-2016, 09:55 PM   #6
hagenkustoms
Dash primed after I filled some holes and built a small cubby hole
Had to check one of the gauges out !
After I had it mostly mocked up
I did 3" drop lower control arms and 3" blocks in the black
Most of he body work done, I hand made the front part of the floors and trans tunnel as well as shaved the hole for the fuel fill
That's all for now.. Should have my interior back in a week or so and I'll use it painted and hopefully done in a month, maybe a little longer.
Old 08-14-2016, 09:58 PM   #7
mongocanfly
Looks like a good start to a great build..love the new hood emblems..what's your ride height? That looks mighty low..that wouldn't work where I live..haha
Old 08-14-2016, 10:01 PM   #8
hagenkustoms
Thanks ! I'm going to stain the wood black also.. And do gloss black steel
strips in between the wood. I've never seen a matte white with gloss black trim 47-53... Ever. So I hope it turns out like I'm hoping
Old 08-14-2016, 10:03 PM   #9
hagenkustoms
At the front of the running boards it's right around 5 inches off the ground. I think it looks lower in the picture than in person.
Old 08-14-2016, 10:04 PM   #10
mongocanfly
Old 08-14-2016, 10:07 PM   #11
hagenkustoms
What do the dots mean?
Old 08-14-2016, 10:27 PM   #12
mongocanfly
Sorry bout that..everytime I post and hit my back button it will double post my original..it didn't use to do that but here lately every time I post I have to go back to the home page or it will double up...so if I catch it in time I just hit edit and put dots in it cause I can't erase it..
Old 08-14-2016, 10:30 PM   #13
hagenkustoms
Oh haha no problem
Old 08-14-2016, 10:31 PM   #14
mongocanfly
Yep it looks lower than 5"..I'm shooting for 5-6 in on mine..yours looks like 3 or 4..
Old 08-14-2016, 10:58 PM   #15
HUSSEY
HUSSEY's Avatar
Looking good man. I'm interested to see how your firewall came out with your custom bead rolled panels.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 08-14-2016, 11:09 PM   #16
hagenkustoms
I will snap a pic tomorrow
Old 08-14-2016, 11:09 PM   #17
BlueJeep
BlueJeep's Avatar
Looks really good! I'm at 5.5" under the front of my running boards and 3700 miles into it the closest it's come to hitting anything was pulling on to the 4 post hoist for the alignment.
build threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=384736
http://67-72chevytrucks.com/vboard/s...=1#post8149268
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 08-14-2016, 11:17 PM   #18
hagenkustoms
That's awesome ! I like them low. The last truck I built I did air ride, and it was cool but I didn't think it rode the way I thought it should. I did a manual valve setup on it. If I did it again I would do electric valves and height sensors so it stays at ride height no matter what when you set it. I drive quite a bit. I live a hour away from friends and family so the stuff I build has to be reliable. I did the LSX because I wanted the power, reliability and gas mileage .
Old 08-14-2016, 11:26 PM   #19
joedoh
joedoh's Avatar
great work! looks amazing
New Project! Project: KECHI
my L35 4.3 4L60E S10 49 chevrolet 3100
http://67-72chevytrucks.com/vboard/s...d.php?t=782525
Old 08-14-2016, 11:47 PM   #20
oldman3
oldman3's Avatar
Looks great, I'll hang around for more updates...Jim
oldman3 is offline   Reply With Quote
Old 08-15-2016, 03:45 AM   #21
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice build!
ChuckDriver is offline   Reply With Quote
Old 08-15-2016, 07:22 PM   #22
hagenkustoms
Upholsterer sent me a picture of one of my door panels today
Old 08-25-2016, 05:06 PM   #23
hagenkustoms
Seat finished, just have to pick it up !
Doors painted bright white and matte clear coated
Old 08-25-2016, 08:26 PM   #24
YahamaR1
YahamaR1's Avatar
Looks good, Will be following this build
YahamaR1 is offline   Reply With Quote
Old 08-25-2016, 08:32 PM   #25
hagenkustoms
Thanks ! Hoping to have it on the road in a month or so
Copyright ©2000 - 2019, vBulletin Solutions Inc.
