Old 09-10-2016, 04:18 AM   #1
yoshi
yoshi's Avatar
Brake setup issue
Hi all, a friend of mine is sorting out his 49 & has come across a problem. He's messaged me & ive said I'll visit him this afternoon. He said that he's fitted a Heidts front end & 2" dropped spindles but when he tried to fit the discs they are hitting the caliper bracket & steering arm. I suggested he may have the wrong rotors, they are 11" & Chevy lug pattern. I know I had a few problems & learnt a lot from you guys so hopefully we can sort this too, thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 09-10-2016, 11:46 AM   #2
yoshi
yoshi's Avatar
Re: Brake setup issue
These are the rotors that he has, the M2 bearings fit but the dust seal is a little loose. He's been told that they're not Heidts as they don't sell vented & grooved. The inside of the rotor just touches the caliper bracket. Can anyone give me any info about these rotors from this? Thanks
yoshi's 49 project
Old 09-10-2016, 11:48 AM   #3
yoshi
yoshi's Avatar
Rotors
yoshi's 49 project
Old 09-10-2016, 12:17 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
That looks like something that came from RodPartsDealer or GearHead Enterprises. If it is I don't think its a heidt's MII kit it just looks like one or they have added those rotors. He needs to go back to the seller and see what's up.
Old 09-10-2016, 12:24 PM   #5
yoshi
yoshi's Avatar
Bit of a long story with getting ripped off & waiting over 6 months to get some of the parts he ordered so isn't able to go back to supplier hence me trying to help
yoshi's 49 project
Old 09-10-2016, 01:12 PM   #6
mr48chev
mr48chev's Avatar
On the seal, he should be able to source a proper seal locally by measuring and fitting the seal to the hub and spindle.
I've got a set of the same caliper brackets and don't think there is a left and right but he might compare them and see if they are made to only go on one side for a good fit.
Did he buy all the parts from the same source or did he mix and match parts?
My ongoing truck projects:
Old 09-10-2016, 01:41 PM   #7
yoshi
yoshi's Avatar
He didn't get all the parts he ordered so had to go to a good supplier to get the rest. So unfortunately it is a bit of a mismatch
yoshi's 49 project
Old 09-10-2016, 02:18 PM   #8
mr48chev
mr48chev's Avatar
Where does the rotor hit the steering arm and the caliper bracket? A bit of grinder smoothing on the bracket and arm may give enough clearance and or a slight modification to the inner lip of the rotor on a lathe might help if it is making contact.
Old 09-10-2016, 02:54 PM   #9
yoshi
yoshi's Avatar
That was something we discussed, he's done a bit of grinding since I've left him. It seems he may have to live with it. On a separate note is there anywhere he can buy motor mounts to fit an sbc350?
yoshi's 49 project
Old 09-12-2016, 08:23 AM   #10
cyclonewade
You can buy motor mounts just about anywhere.
Here are a few starter sites.
speedwaymotors.com
https://www.summitracing.com/
DYI starter
http://welderseries.com/blog/#!/Chev...=0&sort=normal
Cheers!
cyclonewade is offline   Reply With Quote
Old 09-13-2016, 07:43 PM   #11
Coupeguy2001
Coupeguy2001's Avatar
Those rotors look like GM G body rotors.
I would start with Speedway motors.com. They have 5 or 6 catalogs, early iron, classic, truck, racing, etc. I would go to the racing catalog, and look for a 1/8" spacer to push the rotor out if the spindles are long enough. Then I would see if the 78-87 seals fit those rotors.
If those spindles are a brand, call the manufacturer's hot line, and tell them what you are facing.
They could tell you what the spindle -rotor matchup would be.
All of those designers look for parts thatyou can buy locally at a parts house, and design the spindles, tie rods, etc. to facilitate them making kits as cheaply as possible while maintaining strength.
Coupeguy2001 is offline   Reply With Quote
Old 09-13-2016, 09:32 PM   #12
mr48chev
mr48chev's Avatar
What design of Motor mounts does he want to use Yoshi?
Do to your being in the UK (yes folks YOshi lives in the United Kingdoom and shipping costs a big chunk) Fabricating some mounts and locally available rubber biscuits (think Hockey puck with a hole in the middle) and get out with the cost of the metal and rubber pieces.
If you study this a bit you see that it has a triangular shaped plate that bolts to the side of the block and a leg that comes out from that that sets on a pad fastened to the inside of the frame rail. This would not be real hard to make and the cost would be real low. http://www.ebay.com/itm/Transdapt-47...hVV6SR&vxp=mtr
Another option would be a tube crossmember that uses factory style 68/64 Chevy motor mounts. Those are real simple to use and not too expensive.
Old 09-14-2016, 04:45 PM   #13
yoshi
yoshi's Avatar
Thanks coupeguy, we'll look into that. Mr48chev I don't think it matters what style of mounts he uses as long as they work. He said to me " every time I ask someone about motor mounts they reply make some but I don't know where to start!" He can weld & do some fab work
yoshi's 49 project
Old 09-14-2016, 07:17 PM   #14
mr48chev
mr48chev's Avatar
We will have to find him some drawings of how to do them then.
This is the tube style that is popular and very easy to install. http://www.jegs.com/i/Trans-Dapt/969/4840/10002/-1 Probably the simplest setup to put a V8 in an early pickup. I've used several of them over the years.
Front and rear crossmember and mounts here for a fair price https://www.performanceonline.com/19...mber-Kit-with-
Old 09-14-2016, 07:48 PM   #15
dsraven
is he looking for motor mounts alone or mounts and a crossmember?
if the whole shebang, and he can cut and weld, and he wants to fab them himself, just grab a pair of standard mounts for a camaro or whatever,get the engine where he wants it, bolt on the mounts to the engine and fab a crossmember. easy peezy. make sure the exhaust is in place along with steering so he has clearances for that stuff.it would also be nice if the crossmember bolted in. you can box the frame up there for extra support if he wants.send a pic so we can see what he is working with.
Old 09-15-2016, 01:06 PM   #16
yoshi
yoshi's Avatar
Ok thanks, I've spoken to him via text & he says he's got some mounts now but not sure if the other part welds to the mustang cross member!
yoshi's 49 project
Old 09-15-2016, 03:19 PM   #17
_Ogre
_Ogre's Avatar
typical sbc motor mount looks like this one and uses a long 3/8'' bolt to attach to just about anything
these are mine in truck: just some 3/8'' tube and 1.25'' square tubing
my fatman mustII x-member is pretty heavy wall
if you have a lighter x-member you can use 10 ga plate and come off the frame
another with square tubing coming off the frame
shop air compressor timer
Old 09-16-2016, 01:40 AM   #18
yoshi
yoshi's Avatar
Many thanks ogre I'll pass these on
yoshi's 49 project
Old 04-17-2017, 04:11 PM   #19
yoshi
yoshi's Avatar
He's been busy - https://youtu.be/Mttfhghnx3E
yoshi's 49 project
