Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-03-2016, 10:16 PM   #26
raggedjim
raggedjim's Avatar
Re: 1972 GMC Jimmy Build.
That part is this...
http://www.classicheartbeat.com/cata...%20support.htm
I think I have one I made laying in the back of the jimmy but it won't be as nice as Wes'
If I can find it I'll send it to you, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 12-03-2016, 10:43 PM   #27
Tekamah72GMC
Does this look even close to what it should look like
1972 GMC Jimmy - The wife HATES it!
1973 Chevy Camaro - The wife HATES IT MORE!
1994 Chevy Suburban - Never getting rid of it.
2005 GMC Yukon Denali - That's the wife's.
2012 Chevy Silverado 1500 Z71.
2005 Chevy Tahoe (May use this for a 5.3 Swap)
Tekamah72GMC is offline   Reply With Quote
Old 12-04-2016, 01:48 AM   #28
raggedjim
raggedjim's Avatar
Check this thread, he's working in the same area. The whole thread is a good reference.
http://67-72chevytrucks.com/vboard/s...=341224&page=6
Roger
'70 GMC Jimmy 2wd
Old 12-04-2016, 01:33 PM   #29
Tekamah72GMC
That was a good thread. Thank you for the link. I searched B Pillar repair last night as well.
I am going to move a head with my patch panels that I am going to make. see how that works.
After the start of the new year maybe I could justify spending another 400 to 500 dollars on those patch panels.
Old 12-04-2016, 06:58 PM   #30
jaros44sr
jaros44sr's Avatar
Did you look at page 5,6,7 on my build, might give you some ideas of what is store for you, JMHO, but I think "B" pillar is the most difficult area
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-04-2016, 07:42 PM   #31
Tekamah72GMC
Ok I have looked in a bunch of threads. How did you guys get out the bolts that are circled on the picture below.
Then did you reinstall or weld them in?
Old 12-05-2016, 02:00 PM   #32
raggedjim
raggedjim's Avatar
A tough decision. You can cut into the b pillar and hope you can turn the bolts out and replace them (See the pic of the holes from the top side inside the b pillar) or you could weld it (I'll never tell...)
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 12-06-2016, 12:50 PM   #33
Tekamah72GMC
Well decided to remove the Pillar Panel. Used the Blue wrench to remove the two bolt heads.
So this is an attempt to remake a part that Was just a bit too rusty for my liking.
Old 12-06-2016, 01:42 PM   #34
raggedjim
raggedjim's Avatar
Nice work, you did it the right way.
Rg
Roger
'70 GMC Jimmy 2wd
Old 12-07-2016, 06:12 PM   #35
jaros44sr
jaros44sr's Avatar
I think mine are still in there, pardon the rust, just surface, ordered parts from Wes, should be here in a week
Nice work
this was still some of the PO's work, I'll have to get in there and freshen things up
SAFETY FIRST
AS usual, off topic
Jim
Old 12-07-2016, 07:04 PM   #36
Tekamah72GMC
Well this is my first attempt, Just trying to take a good long look at what I want. This is bolted in, the piece I made. It does not have the breaks and I am still thinking about ordering the parts. But this is 16 ga. and right now has 4 bolts. In a bit it will have five then the three along the rocker box end cap.
Old 12-08-2016, 10:10 PM   #37
Tekamah72GMC
Frustration, nothing but frustration today...
Old 12-08-2016, 11:20 PM   #38
jaros44sr
jaros44sr's Avatar
LOL, don't worry, you'll have plenty more of that, but then there is the fun part when all the pieces fall in place
SAFETY FIRST
AS usual, off topic
Jim
Old 12-10-2016, 07:03 PM   #39
Tekamah72GMC
Cut out some more rust and moved to the front A pillar. Really it is in pretty decent shape only about the bottom three inches are going to need to be replaced.
Feel free to give me any pointers on these pictures. I think that the gap between the rocker and the backing plate are close to right. I didn't have much to go off of besides page 23 of the assembly manual. It looks like there should be 3/8 inch gap.
I will put the door back on this week and see how my gaps are lining up.
Old 12-10-2016, 07:06 PM   #40
Tekamah72GMC
Forgot the pictures.
Old 12-11-2016, 08:13 AM   #41
tristan
I admire your workmanship and courage, hang in there. It gets less grotty and more interesting once you are past the rust repair.
tristan is offline   Reply With Quote
Old 01-02-2017, 01:36 PM   #42
Tekamah72GMC
Happy Holiday's to everyone! I hope everyone had a great Christmas!
Some pictures of the work that I have gotten done since my last post. Been struggling on a couple of items fitment of the front Cab Floor Brace. I feel that I go it right now. The door and rocker panel fitment. New door hinges threw everything off that I had fit up to this point. Got those issues solved.
Old 01-02-2017, 01:41 PM   #43
Tekamah72GMC
I thought I had some more pictures. I will take some of the rocker fully welded in, and the rocker box welded in. I feel like the passenger side is almost complete. Going to start the driver side this week.
Old 01-02-2017, 05:28 PM   #44
raggedjim
raggedjim's Avatar
It's looking great! I hate to say it but I really struggled with the rocker panel on the driver's side. It took a lot of cutting and welding to make it fit at the a-pillar.
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 01-05-2017, 02:16 AM   #45
lks dcvn
lks dcvn's Avatar
You are making great progress - been there - done most of that work as you could tell from my build thread. To do it right takes a bunch of time and patience. Keep the pictures coming.
lks dcvn is offline   Reply With Quote
Old 01-06-2017, 11:16 AM   #46
jaros44sr
jaros44sr's Avatar
Nice work.....
SAFETY FIRST
AS usual, off topic
Jim
Old 01-25-2017, 08:13 PM   #47
Tekamah72GMC
Been a bit busy but here are some pictures of progress that I have made. The Rocker is fully welded in place. Replaced the Lower kick panel. Rebuilt the Back B pillar. Repaired the Lower Front Quarter Panel. Found a lot of bondo in the wheel well. Thinking that I am going to order a patch panel that goes up and over. Really wondering why i didn't replace the entire bedside. I may yet, after I catch up from Christmas. I was going to buy those two parts from Classic Heartbeat. When I redo the Bedsides I will and replace that I made.
Old 01-25-2017, 08:45 PM   #48
Tekamah72GMC
A Couple More Pictures. I have learned a lot for the drivers side. There are somethings that I will be doing differently for obvious reasons. The door gap is still to wide for my liking bought a set of shims form Amazon. if anyone has a link or photos of how to shim a door please reply.
Old 03-04-2017, 11:16 PM   #49
Tekamah72GMC
Been A little while since I have been on the board. Job, Family, Life all seem to conspire to keep me from working on the Jimmy.
I ordered a set of parts from GMC Paul's to do the fix on the drivers side. The right way, they should be here Monday.
I hired a Babysitter tonight so that I could get some work in on the Jimmy.
Mocked up a bunch of parts tonight. Feel pretty good about the fitment so far.
I made a smoker, fired it up yesterday held 225 degrees for a little over 10 hours on one bag of charcoal. It is a reverse flow design that I found on a smoker website. Tasty.
