Old 12-05-2016, 06:08 PM   #401
raggedjim
raggedjim's Avatar
Re: What did you do to your Blazer/Jimmy today?
Originally Posted by Big Block View Post
Put new gas tank on my 71 2 wheel drive Jimmy.. Aftermarket tank with short filler neck. That was a real treat. 5 hours later and a lot of cursing it's on and the gas gage works but bounces around while driving it. Why didn't they just use a stock filler neck? I know it can be used for other applications but it would be a lot easier to cut it to fit rather than being short and ending up hitting the top edge of the frame rail. What a pain. Finally got the frame rail modified enough to clear the neck.
Did you take any pics when you did this? I'm gonna have to do the same thing eventually, and I threw out my old tank already...
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 12-09-2016, 02:35 AM   #402
Beau2a
Beau2a's Avatar
Finally got the rear wheels. Wasn't sure if I'd ever get my Coys. Customer service is something else.
Beau2a is offline   Reply With Quote
Old 12-09-2016, 10:11 AM   #403
timski69gmc
timski69gmc's Avatar
Looks awesome! Those wheels are perfect!
timski69gmc is offline   Reply With Quote
Old 12-10-2016, 12:54 PM   #404
BLT-NT-BOT
Got some metal work done.
BLT-NT-BOT is offline   Reply With Quote
Old 12-10-2016, 06:11 PM   #405
Chulisohombre
Chulisohombre's Avatar
No more flu stones floor. Lol. Looks good
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 12-22-2016, 01:55 PM   #406
OldBalls
OldBalls's Avatar
Took my best girl to Lowe's yesterday to buy an air compressor. Thought I'd snap some "action" shots while waiting
Got home and started sanding down the top.
OldBalls is offline   Reply With Quote
Old 12-22-2016, 04:52 PM   #407
TonyJohnson
TonyJohnson's Avatar
Great looking truck. I just unburied mine from a foot of snow and drove it around the countryside for awhile.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 12-22-2016, 06:25 PM   #408
OldBalls
OldBalls's Avatar
Oh nice. Luckily here in California I can still drive around a little in the winter w/out freezing my face off. I like the look of your white body / white top, still debating on whether to paint my top white or black.
Old 12-22-2016, 06:59 PM   #409
vanislejimmy
Pulled the motor to replace gaskets,clean everything up and paint the frame and engine. Got the motor pulled, but didn't get any pictures.
vanislejimmy is offline   Reply With Quote
Old 12-22-2016, 07:14 PM   #410
Beau2a
Beau2a's Avatar
Today I machined a billet aluminum cup holder insert for my console.
Old 12-22-2016, 09:50 PM   #411
raggedjim
raggedjim's Avatar
I'll bet that made a lot of chips! I like it, Rg
Roger
'70 GMC Jimmy 2wd
Old 12-22-2016, 09:57 PM   #412
dirish
dirish's Avatar
Wow!, that's nice!
dirish is offline   Reply With Quote
Old 12-22-2016, 10:56 PM   #413
jaros44sr
jaros44sr's Avatar
Nice, CNC or manual?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-22-2016, 11:36 PM   #414
TonyJohnson
Mine came with a black double wall top and it looked fine. I found the white single wall top and liked it better. In Colorado, the white top worked better temp wise (I suppose...) The extra UV also fades everything there, so I left it white. Now I'm in Northern Michigan and I'm thinking that once I get all the body work done, I may go back all gun metal gray... Too much white around here. I'm getting cabin fever.
Tony Johnson
Old 12-22-2016, 11:58 PM   #415
Beau2a
Beau2a's Avatar
Cnc. Haas tm2
Old 01-14-2017, 01:39 AM   #416
SoCoC10
SoCoC10's Avatar
Pulled this stuff out of my 71 CST. The center consol has 4 speakers and in it and two subs. The two amps were under the front seats. Wiring was a cluster f**k from the firewall to the rear bumper. Fixed the intermittent no start and wouldn't turn off issues. Turns on and off with the key like it should now!!
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 01-14-2017, 05:59 AM   #417
Chulisohombre
Interesting center console the p. O. Had in there.
Old 01-14-2017, 10:58 AM   #418
Big Block
Big Block
Big Block's Avatar
That's pretty sweet.
Big Block is offline   Reply With Quote
Old 01-18-2017, 10:48 PM   #419
SoCoC10
SoCoC10's Avatar
Consol and amps are in the Blazer parts for sale area now.
Horrible wiring job by PO was back feeding voltage from the ACC side of igintion switch causing the engine to run with the key in the off position.
Old 01-18-2017, 10:59 PM   #420
Chulisohombre
Po Wiring is not Fun. I had to Go Through and do the same thing with mine. So Many wires going To nowhere and cuts and Splice to half The dash. None of the gauges worked either. Is still like romeomeday require the truck as you have. It would Be much easier than trying to remember all the shortcuts I hadn't to fix and Still rig some places to get a strait looks bE wire Where it Was Supposed to be.
Old 01-23-2017, 10:47 AM   #421
Beau2a
Beau2a's Avatar
Restored my console this weekend. Before picture
Old 01-23-2017, 10:48 AM   #422
Beau2a
Beau2a's Avatar
And after
Old 01-23-2017, 10:51 AM   #423
Beau2a
Beau2a's Avatar
Also installed a Camaro tach.
Old 01-23-2017, 10:56 AM   #424
Chulisohombre
Good job beau. Looks like that tach belongs there.
Old 01-24-2017, 10:09 AM   #425
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
And after
What did you use to paint your console? How about a quick 'this is what I did' post.
Tom Vogel is offline   Reply With Quote
