11-10-2016, 05:02 PM | #151 |
Re: RideTech's New C10 CoilOver Kits
I have the level 2 on my 67. Total night and day difference. It rides and handles great. My question is has anyone successfully put a rack and pinion with this setup? My only concern would be clearance with the sway bar and possibly ground clearance?
11-10-2016, 06:12 PM | #152 |
I would like to know this too
12-27-2016, 10:44 PM | #153 | |
12-28-2016, 10:06 AM | #154 |
Not yet, the project has stalled / moving very slowly. I want to get all the sheet metal on the front end and get the ride height set so I can see where everything is going to sit.
I'm thinking my solution will be a tube spacer with a threaded rod. |
12-28-2016, 08:09 PM | #155 |
You guys might need to try adding mounting tabs to the upper a-arms & run the sway-bar links to them to eliminate the R&P interference.
01-03-2017, 10:06 AM | #156 |
We have not used a Rack and Pinion setup on any of our C-10 trucks in-house. I do have different lengths and styles of end links as well as some weld-on end link tabs. You could possibly relocate the end link.
01-24-2017, 06:46 PM | #157 |
I added a coupler nut and a piece treaded rod to give me some clearance. Still needs to be road tested to confirm that there is enough clearance.Not sure why this site decided to turn my picture sideways.
Does anyone know what the suggested backspace would be for the fronts using this set up? I'd like to put a 8 or 9" wheel in there. |
01-24-2017, 07:05 PM | #158 |
Pics getting flipped is usually from a cell phone setting....
01-25-2017, 10:04 AM | #159 |
That's a really good idea. Looks like it turned out nicely!
John J. Sales/Tech Direct Line: 812-481-4737 Office: 812-482-2932 JJohnson@ridetech.com Instagram: @ridetech_john |
02-13-2017, 04:30 PM | #160 |
Can everyone put in this thread what wheel and tire combo they are running with the completed coil over setup? Year of truck and if rear end has been modified? Backspacing of the rims would be nice also!!!!
Thanks!! Any rubbing issues? |
02-13-2017, 07:25 PM | #161 |
18x11 front with 5" backspace- 315/30/18 tires
18x11 rear with 4.5" backspace-315/30/18 tires Rear is narrowed but I forget how much No rubbing but I'm not using the Ridetech sway bar. It's a splined Nascar bar with the Ridetech mounting tabs cut off the arms.
Aarik Gault 1966 GMC SWB, Ridetech Suspenion 1968 Camaro autocross/track car |
02-13-2017, 11:26 PM | #162 |
Thanks. I do have the Ridetech front sway bar. Looking for a recommendation for 20's front and rear
02-14-2017, 08:20 AM | #163 |
I'm running 15x7 up front and 15x10 in the rear.
02-14-2017, 11:40 AM | #164 |
I'm running 20 by 8.5 front and 20 by 10 rear. Have the slightest rub at full lock. I have a 255 35 in the front
02-14-2017, 11:41 AM | #165 |
02-14-2017, 12:48 PM | #166 |
I love both of these trucks!
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
02-15-2017, 01:11 PM | #167 |
It is great to see so many C10 owners are now finding out just how amazing Ridetech Suspension truly is! We have been selling it for years now, primarily in the muscle CAR market and have helped bring it over to the 67-72 forum here! We sell a lot here now, one at a time, we are helping you guys achieve a gorgeous stance and an incredible ride, two things that were almost nonexistent in this market not long ago! Coilover, Air or StreetGrip, one of them is guaranteed to float your boat!
We are here to take care of your Ridetech needs! MCB
MCB - Matt's Classic Bowties 5360 Gateway Plaza Dr. Benicia, Ca. 94510 925-828-5555 www.mcbparts.com Email: forums@mcbparts.com Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts Hours: Monday to Friday 8am - 4pm Pacific We ALWAYS enjoy talking to our customers! We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking! |
02-21-2017, 10:35 AM | #168 |
Bought my kit for Matt everything went smooth!
Anyone else running 20's front and rear with this kit? If so what size tire rim and back spacing? Thanks |
03-11-2017, 04:08 PM | #169 |
5" backspace and my tires will rub the front sway bar at close to full lock.
03-11-2017, 08:26 PM | #170 | |
Matt
03-11-2017, 08:29 PM | #171 |
03-11-2017, 08:31 PM | #172 | |
When it comes to wheels, actually measuring once it's all in is the best way. We have the tool that we loan out free of cost when you are buying wheels from us. It's a $450 tool that grips the tire and bolts to the rotor face, just as a wheel would. With the ride height chosen, you can then turn the wheels with the suspension at ride height (remove coilover's). This is not a difficult or very time consuming job and it will ensure your wheels fit properly. Matt
04-02-2017, 01:04 PM | #173 |
I have clearance issues with the rear shock bridge and a wood floor. It clears with a metal floor. I wasn't expecting that. A couple hours and I fixed the issue but was disappointed I needed to do that.
.....Before and after Last edited by Trackman101; 04-02-2017 at 01:35 PM. |
04-02-2017, 01:23 PM | #174 |
04-03-2017, 10:42 AM | #175 |
