11-28-2016, 08:39 AM | #1 |
Squarebody Trailing Arm Conversion
Some progress on the install of my PB Fab converison kit.
I did have to pull the gas tank so I could add clearance holes in the trailing arm crossmemeber mount and I will also have to add one in the front gas tank hanger. This could be due to the way I mounted the tank when I shortened the frame though. I thought I used a factory location but I honestly cant remember. All the suspension stuff is going out for powder today but I'll try and get a picture of what I had to do on that bracket.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
11-29-2016, 01:54 AM | #2 |
Re: Squarebody Trailing Arm Conversion
Looks good so far.Let me know how it handles after you get it all good to do.
12-15-2016, 11:41 AM | #3 |
Progress is being made just not much that is picture worthy. Axle is cleaned up and painted, everything is back from powder coat and ready to install. At the front of the notch the bolts are to short so I'll be picking up some longer ones today at lunch to fix that. I'm not sure if they sent longer ones and I lost them or what. I had some issues early on with this kit that lead to me packing it back up for a bit because I got frustrated so I could have misplaced them then.
12-17-2016, 08:39 AM | #4 |
12-17-2016, 05:03 PM | #5 |
Looks good Paul!
12-17-2016, 10:50 PM | #6 |
Looking good so far,What are you going to do to the front ?
12-18-2016, 02:31 PM | #7 |
I have the stage 1 kit for the front. Cups, plates and shock relocators
01-01-2017, 11:40 AM | #8 |
Work has been crazy with our winter shutdown but I've managed to get a little bit accomplished on my swap the past few days.
New wheels seals, locker an the larger drums installed on the axle. Then put the trailing arms an axle on the truck. Today I got the bump/steering stop removed from the front a arms. Put on the lower shock bar an the shock studs. Next week I still need to order a nice aluminum cover for the axle an new brake hardlines to go to the wheel cylinders....
01-02-2017, 04:51 PM | #9 |
Passenger side front stuff is done, just need to do the bag plate and shock mount on the dr side now.
01-13-2017, 01:14 PM | #10 |
Well I'm making some progress but its frustratingly slow. I spent quite a bit of time clearancing the rear bag mounts for my air line fittings, after they were powdercoated
I got my air tank mount made and then went to install the front bag assemblies and the bolts are to short, so I had to order more. Ordered new prebent brake lines to go across the rear axle to the wheel cylinders and they had to be tweaked to fit. I also got a nice LPW low profile support cover but it is really close to the panhard bar and it might not work either. Then bolts that came with it are to long and it didnt even come with a gasket! I had hoped to have it sitting back on its suspension after my two days off this week but nothing worked out like I wanted it to. At about 3 pm yesterday I threw in the towel for now because I was just getting too aggrivated with it all. I'll try and grab a few pictures at some point, it doesnt look to much different right now though
01-14-2017, 04:36 PM | #11 |
driving is in my blood
This is cool, I didn't even know they made something like this.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-14-2017, 05:26 PM | #12 |
Porterbuilt, CPP and Hot Rods to Hell make coversion kits. HTH might not be around anymore though, I havent checked in on them lately.
01-15-2017, 10:37 PM | #13 |
Here's a few updated pics.
Clearance added for fittings Rear mostly together, tank mounted, swapped to 84+ parking brake cables. Front mounted up, I still have to swap out the bolts for the upper bag plate. Air line ran Hopefully it's all smooth sailing from here....
01-24-2017, 10:21 PM | #14 |
Well that last sentence above came back to bite me. I've been off the past few days an been cranking on this thing. Yesterday I got to the point where I was just about ready to throw the tires back on it an let it off the stands. Jacked the rear axle all the way up into the notch to check travel an the driveshaft hits the trailing arm crossmember with around 2" of up travel left. I ran it all the way up first then checked when it hit so I hope I didn't bend it with that first test.
So I fired off an email, then went to bleed the brakes. (All new rear axle lines an new braided stainless lines front an rear). Stripped a front bleeder screw, threw a wrench or two then quit for the day. I swapped out the caliper an finished up the brakes this morning an then took most everything on the rear back apart. I have a few plans of my own but I'm waiting to see what direction PB wants to go. My show deadline is in serious jeopardy now..... Looks like I never mentioned the show in here, I'm trying to have it ready for Run to the Sun in Myrtle Beach this March.
01-24-2017, 11:06 PM | #15 |
Hi.....new to the squares.....I'm in Australia... they'res not many around that people work on.....soooo..I'm trying to work it out......why are you swapping to This style rear setup and not a 4 link( which seems the common way to go if have leaf Spring rear truck)...is it easier way to bag?...different?
01-25-2017, 12:01 PM | #16 |
I saw in your earlier pics that the cross member was hanging below the frame rails. Is there anyway you can just raise it up? The factory style cross member just goes right in the middle of the rails is the porterbuilt unit a direct replacement? I don't know if you remember but I contacted you a while back on this conversion for my Suburban. I still haven't started but Im hoping to have it completed by Powertout this year. The difference is I'm using a factory cross member and have a 2 piece drive shaft
I'm watching this for sure |
01-25-2017, 01:16 PM | #17 | ||
A suburban will be a different process all together I'm sure, so all I can say there is good luck on your swap. Hopefully it goes alot smoother than mine has.
01-25-2017, 04:04 PM | #18 |
Any reason you don't just notch the cab and raise the crossmember?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
01-25-2017, 05:22 PM | #19 | |
The CPP kit gets the conversion done with no mods to the floor of the cab so there is no reason for this kit to requrie a large hole to be cut in the floor in my opinion...
01-25-2017, 05:58 PM | #20 |
That cross member hit the floor too? It looks like you put the top bar on top of the top frame rail and the lower rail on the inside of the c channel
01-25-2017, 09:49 PM | #21 | |
02-01-2017, 08:53 PM | #22 |
So I havent let the driveshaft issue hold me back. I've been emailing with porterbuilt about it and they want to build another crossmember that is basically another 3/4" higher. I have a show I want to make so I took it all back apart and made a little modification of my own for the time being....
02-01-2017, 08:54 PM | #23 |
I worked on that off an on all week along with a little bit of the plumbing and mounting for my "air command center"
Put it all back together today and I have plenty of clearance now... Threw the wheels back on it and let it back on the ground for the first time in probably two months And a quick dirty hookup of everything to the shop air just to see it work.... click the picture or this link if it doesnt work http://vid644.photobucket.com/albums...pskxntx7j6.mp4
02-02-2017, 05:06 AM | #24 |
Lookin' Good! What wheels / tires are you running? I notice they're different than your older thread and I like the look of 'em.
02-02-2017, 08:46 AM | #25 | |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
