Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 02-02-2017, 11:28 PM   #1
MinimalPayne
07 low oil pressure issue
I recently picked up a Diablosport intune for my truck. And after I put on one of the pre canned tunes I started getting the low oil reading on the gauge. I had this problem a few weeks ago and I replaced the sensor on the back of the engine and haven't had a problem until now. Could the new tune be causing this or do I really need to change that sensor again? Or could it be something worse?
Edit- it's the 5.3
MinimalPayne is offline   Reply With Quote
Old 02-03-2017, 06:35 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 07 low oil pressure issue
Did you change the screen when you changed the sending unit? It's common for them to get plugged up.
95 S_Trucker is offline   Reply With Quote
Old 02-03-2017, 12:19 PM   #3
MinimalPayne
No I didnt. I'll try that out next, I just found it weird that it started doing this right after I put a tune on it
Old 02-03-2017, 01:59 PM   #4
biketopia
It's not hybrid is it? I dunno if you can even tune them, but the hybrid has two OPS, one under the intake and it will give you the same message as your described. But I'd do like 95 s trucker suggested and check that screen, and if possible stick a mechanical gauge on it just to verify.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 02-03-2017, 05:44 PM   #5
MinimalPayne
OK so I put it back to the stock settings and the oil pressure issue seems to be gone. Has anyone else had an issue with the pre installed tunes in the Diablo intune?
Old 02-06-2017, 01:25 AM   #6
GM-power
GM-power's Avatar
Put a mechanical gauge and verify the actual pressure. Then post the results.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 02-07-2017, 06:19 PM   #7
MinimalPayne
It turned out to be the filter under the sensor, lesson learned replace both of those if you ever have an issue
