Old 02-16-2017, 11:15 AM   #101
Ski-me
Ski-me's Avatar
Re: thinking about getting this in the morning
Lookin good man!!
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 02-16-2017, 11:19 AM   #102
schpeen
schpeen's Avatar
Originally Posted by Ski-me View Post
Lookin good man!!
thank you Ski
1991 K5 Blazer 4x4 "9 ball"
2019 Chevy Silverado Trail Boss 4x4
2018 Chevy Colorado 2 door ZR2 4x4
1988 23' Mako Marine
2005 Harley Davidson Road King
schpeen is offline   Reply With Quote
Old 02-17-2017, 02:46 AM   #103
68Timber
I know the pieces fit
68Timber's Avatar
Looking good!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-17-2017, 10:16 PM   #104
schpeen
schpeen's Avatar
New windshield going in
Old 02-18-2017, 04:17 PM   #105
mickeykreg
mickeykreg's Avatar
Originally Posted by schpeen View Post
welding done only rust on the whole truck was in the roof
I've got to do a similar roof rust repair on my 77 coming up. Do you happen to have any pics of the structure under the roof skin repairs in post 64? Or is it just the inner sheet metal and outer skin? Especially interested in the work you did near the A and B pillars.
Truck looks great! Thanks, Mick
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
rust repair on the '77
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
Old 02-18-2017, 08:15 PM   #106
schpeen
schpeen's Avatar
po put some kind of foam in the roof unless they all come like that? i couldn't tell you
Old 02-18-2017, 08:31 PM   #107
schpeen
schpeen's Avatar
i didn't take any pics of the cleaning all the crap out of there it was a mess we blew it out for hours then soaked it down with rust inhibitor till it ran out the bottom there is a little drain that runs out the sides to the rear of the B pillar we were careful not to clog them up when repairing everything else. once it was all cleaned out and new metal welded in we used duraglass with the fibers in it that stuff hardens like a rock man!
Old 02-18-2017, 08:32 PM   #108
mickeykreg
mickeykreg's Avatar
OK, thanks for the extra pics. Guess I'll just break into it and hope for the best. Projects like this are good inspiration. Thanks again man. Good luck.
Old 02-18-2017, 08:34 PM   #109
schpeen
schpeen's Avatar
here are a couple of the duraglass before sanding
Old 02-18-2017, 08:37 PM   #110
schpeen
schpeen's Avatar
here they are
Old 02-18-2017, 08:40 PM   #111
schpeen
schpeen's Avatar
like new!
Old 02-18-2017, 08:52 PM   #112
schpeen
schpeen's Avatar
out in the sun for the first time in a couple months!Name:  IMG_3271.jpg
Old 02-18-2017, 08:56 PM   #113
schpeen
schpeen's Avatar
a few more pics
Old 02-18-2017, 09:02 PM   #114
schpeen
schpeen's Avatar
few more just can't stop staring at her pictures aren't doing it any justice! we are amazed how nice it is coming out going to wetsand and buff before we start installing all the new goodies but couldn't resist putting on one lens!
Old 02-20-2017, 07:01 PM   #115
schpeen
schpeen's Avatar
decided to spray the undercoating on the bottom side of the truck while we have the wheels and tires off getting sprayed and before we wet sand buff
Old 02-21-2017, 02:42 AM   #116
68Timber
68Timber's Avatar
That B-pillar drain, I never knew it was there. Where does it drain from? The top seal? I think your PO added the spray foam. I had to dig in the inner cab a little recently on my 85 and it had a sticky tar-like something or other on the backsides of the metal in there.
John
74 Honda Z50 build
Old 02-21-2017, 09:20 AM   #117
schpeen
schpeen's Avatar
the way we found it was when we were cleaning the foam crap out of the roof we we were blowing the air into the cavity and you could see dust blowing out from the bottom of the b pillar on both sides of the truck so we made sure to preserve it and not clog them up my guess is they are there so if any moisture forms in there it has a way to exit ??
Old 02-22-2017, 10:44 AM   #118
schpeen
schpeen's Avatar
funny i went to install the side steps i picked up and found all the holes predrilled in all the exact locations seems the PO must have had the same steps installed at one point we sprayed bedliner to the underside of the body and up in the fender wells before we wet sand today so any overspray will get taken care of at the same time starting to look good I'm digging it! not sure why some pics get turned sideways they were straight when i attached them?
Old 02-22-2017, 12:02 PM   #119
Ski-me
Ski-me's Avatar
I have the same ones....very handy!
- Jeff
Old 02-25-2017, 08:21 PM   #120
schpeen
schpeen's Avatar
finally getting to install some parts
Old 02-25-2017, 09:04 PM   #121
cochino12
It followed me home?
cochino12's Avatar
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-25-2017, 09:08 PM   #122
eighteenninetytwo
Looks fabulous!
eighteenninetytwo is offline   Reply With Quote
Old 02-25-2017, 09:31 PM   #123
schpeen
schpeen's Avatar
thanks you're feeling it too right? i swear i can't stop staring at her.
Old 02-25-2017, 09:35 PM   #124
schpeen
schpeen's Avatar
hopefully we will get the door handles hooked back up and then all the moldings, side steps and the new bumpers.
Old 02-25-2017, 09:43 PM   #125
cochino12
cochino12's Avatar
I'm ready to see how the lower molding looks on it.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
