03-17-2017, 11:56 PM | #1 |
NV4500 conversion questions: X-member/Seat
I'm going to swapping a nv4500 into my 85 K20 that currently has a turbo 350.
I got two questions that I'm hoping someone can answer: 1. Transmission X-member-are they different? How so? 2. Does the factory floor shifter clear the bench seat? Thanks for any help. Mike |
03-18-2017, 09:09 AM | #2 |
Re: NV4500 conversion questions: X-member/Seat
I just did this swap in my truck, but mine is 2wd, yes the shifter clears, I have heard that you can use the same crossmember, I did, but again, mine is 2wd
"DON'T TOUCH THE TRIM!!"-Early Kyler |
03-18-2017, 09:12 AM | #3 |
[/URL]
Plenty of room!
03-18-2017, 10:54 AM | #4 |
i swapped my sm465 for a nv4500..its 2 wheel drive as well..shifter clears fine and I reused my crossmember but had to move it back 1 1/2" ...which means shortening driveshafts.. measure case length of both trans to give you an idea..
03-18-2017, 01:40 PM | #5 |
I had to move my crossmember forward about 2 inches, and have my driveshaft lengthened, I went from a t400 to a nv4500 though
03-18-2017, 10:21 PM | #6 |
Thanks Meat & Mongo,
So the 4500 fit within the trans tunnel? You just had to move the shifter opening forward or back, correct? Thanks, Mike |
03-18-2017, 10:48 PM | #7 |
Yes ..I had to move my shifter hole back from where it was original and mine has the high tunnel and it had plenty of clearance
03-18-2017, 10:54 PM | #8 |
Hey Mongo, what year is your truck? Where is your speedo gauge get fed from? Is it cable or sensor generated.
Thanks |
03-18-2017, 10:58 PM | #9 |
Gots to stuff this in here somehow. lol!
03-18-2017, 11:07 PM | #10 |
Mines a 81..on the speedo I wanted to keep my original as my truck only had 22600 verified miles on it when I bought it a couple years back (came from local fire dept) and the trans was pulse speedo so I had to use a Dakota digital convertor box on mine.
03-18-2017, 11:08 PM | #11 |
Good looking and clean trans and transfer you got..
03-19-2017, 08:27 AM | #12 |
I had to put a high trans hump in mine since it was 2wd auto
