03-20-2017, 03:31 PM | #1 |
How are the lower radiator brackets removed and installed?
Any help appreciated, see captions please...........Thanks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-20-2017, 03:33 PM | #2 |
Re: How are the lower radiator brackets removed and installed?
I can't even remotely see those, even on my 23" screen.
If I recall correctly, you remove the rubber pad (it just pulls out) and there's 2 rivets under there. You can rivet, bolt, or screw them back in, up to you.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-20-2017, 03:44 PM | #3 |
Looks like you have the longer 4 row brackets. Just bend the lip of the core support down where it is hitting the bracket and it should lay flat as it is supposed to.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
03-20-2017, 03:44 PM | #4 | |
Sorry, 900 pixels usually works. Whoops, I didn't think to remove the pad first. How about that positioning? It's as if they're the wrong brackets. The core bushings are toast, but I wouldn't think that would be it.
03-20-2017, 03:47 PM | #5 | |
That's twice in a week I've had reason to purchase a torch.
03-20-2017, 03:50 PM | #6 |
Active Member
I modified the front so the bracket could lay flat, then riveted the new one back in place. I did not have to do this with the two row, but the new three row did exactly what you show in the picture when trying to place the mount. I took a small vise grip and bent the ridge down and it has worked well.
03-20-2017, 06:17 PM | #7 |
Torch??? As stated above, use vice grips to bend the lip toward the engine down. Generally, that's what the factory did for the 4-row radiators. Also, drill the rivets and replace them with small bolts of your choosing as stated above. I used flat head 1/4" stove bolts as short as I could go with the heads up.
03-20-2017, 06:34 PM | #8 |
Dumb question of the day (pull pad for surprise). Yeah rivets and thanks for the help.
Looks like there are two bracket position options in the core support. Mine were on the outside, so that's where I bent the core support using a crescent wrench. Crossing my fingers the new radiator doesn't want the inner. It doesn't require much of a bend, though I could go a hair more. Fits like it should as stated...........Thanks a bunch. The mess is one reason I no longer buy cheap batteries.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-20-2017 at 11:19 PM. |
03-20-2017, 06:36 PM | #9 | |
03-20-2017, 06:42 PM | #10 |
You can see from your first pic that the radiator was sitting wrong on the lower pads from the way the pads are crunched down. Good job on the fix.
03-20-2017, 06:49 PM | #11 |
Good point and thanks for the props.........Next up is the acid caked battery box. Can't find the garbage fast enough.
03-20-2017, 06:50 PM | #12 |
The factory usually beds the core support down like you did, surprised it wasn't installed correctly in the first place.
03-20-2017, 08:10 PM | #13 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
03-20-2017, 08:14 PM | #14 | |
Misspoke about junking the battery box too. I scrubbed acid off enough to justify keeping it around a while. The sides are great. I did get a one piece after-market from Manes, which is a nice box. I guess the original is three pieces. Tack welded, I'm assuming.
03-20-2017, 10:21 PM | #15 | |
The standard radiator was a 2 row. It used the narrow brackets and it also used those "inside" mounting holes your referring too. The 3 row used the narrower brackets as well (if you've seen a factory two row, they look funny because they use the same tanks as the 3 row, but have one less core, so the tanks stick out like 1/2" past the core). The three row is wider than the 2 row and uses the same "outside" bracket holes as the 4 row. The 4 row uses the wide brackets and the outside bracket holes.
03-20-2017, 11:26 PM | #16 | |
03-21-2017, 12:12 AM | #17 |
They look weird. My 67 had one. It seems they were mostly used on I6 manual trucks.
03-21-2017, 12:45 AM | #18 | |
Something else I noticed about the bottom brackets tonight. If your 46 year old dry climate bushings are shot like a certain Custom Deluxe, there's no getting a nut on the LH side. In other terms, I'd be drilling anyway. A nut would have dug into the bushing. Don't know how long the rivets are, but it probably was against the bushing.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-21-2017 at 12:53 AM. |
