Old 03-20-2017, 12:34 PM   #1
Franks 72
Franks 72's Avatar
Chrome mirror supports -
Did these camper trucks ever come with chrome support bars ? The dimensions seem a little different than my chrome Suburban ones.
Franks 72 is offline   Reply With Quote
Old 03-20-2017, 02:49 PM   #2
tdangle
tdangle's Avatar
Re: Chrome mirror supports -
My 70 had chrome supports. All rusted now. I've switched to the sport mirrors.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 03-20-2017, 03:18 PM   #3
FirstOwner69
FirstOwner69's Avatar
Yes. Actually all pieces except the elbows are stainless. Posts 13 and 14 in this thread may help.
http://67-72chevytrucks.com/vboard/s....php?p=7646102
FirstOwner69 is offline   Reply With Quote
Old 03-20-2017, 03:33 PM   #4
Franks 72
Franks 72's Avatar
Thanks for the speedy response ! If I wanted to post in "wanted to by" , what would I call them? Is anyone making repros ?
Old 03-20-2017, 05:59 PM   #5
FirstOwner69
The stainless version was option code DG4. The painted version was option code D29. The literature and most SPIDs called them below eye line mirrors. They were first used on '69s and were listed on the SPIDs as west coast juniors, which, in reality, is a misnomer.
From what I've read, the repros are less than desirable and may not match the factory holes.
The picture below may be helpful.
Old 03-20-2017, 07:05 PM   #6
samkost
samkost's Avatar
Question Re: Chrome mirror supports -
Questions for you guys:
How do you distinguish between the original DG4's and the after market tow mirrors?
Any stampings/part # on them?
I have a set of stainless mirrors identical to the ones on the blue truck posted.
I want to say they are aftermarket because of their great condition.
Do the originals have a different back side shape and acorn nuts mounted to the arms? Mine, like the mirrors posted, don't have the acorn nuts.
I will try to get a better photo them later.
Thanks, Sam
samkost is offline   Reply With Quote
Old 03-20-2017, 07:25 PM   #7
FirstOwner69
Yours look aftermarket, but a close-up would help. If the top brace to the door is a flat strap as it appears, they are aftermarket. You can also compare the screw spacing on yours to the picture in my post above. The mirror heads on yours also look questionable. While some factory mirror heads (such as my originals) had the mounting brackets offset vertically from center, most were centered. The stamping on the head stainless may also vary from original. The originals used acorn nuts attached to studs on the elbows. However, the acorn nuts rusted to the studs and could snap off when someone tried to remove or tighten the nuts. Most replacement elbows from later trucks were tapped for bolts.
Old 03-20-2017, 07:37 PM   #8
randy500
Thanks, Sam
Your look original but close up will tell.
Later model DG 4 mirrors are not the same as 69-70? Not sure of the change year but like most things is probably 69-70 series and then 71-2 series. The later arms on bottom 2 points are shorter and the upper mount is just below the glass.
Factory mirror heads are stainless with small round rivets.
randy500 is offline   Reply With Quote
Old 03-20-2017, 07:45 PM   #9
FirstOwner69
72s were different. Refer to the link in post 3. It has pictures of the 72 style also.
Old 03-20-2017, 07:46 PM   #10
samkost
samkost's Avatar
Great information.
Yes, my top arm bracket is a flat bar....so as I assumed, they are indeed aftermarket mirrors. Strike one!
I see what you mean about how the mirror head is center mounted to the arm.
Mine are mounted above center and higher. Strike two
Strike three: Mine are in beautiful condition
Thanks for the clarification and again great info here.
Old 03-20-2017, 08:36 PM   #11
FirstOwner69
Great information.
Here's a picture of one of my original '69 mirrors with the offset head.
