Kid's Mechanic
6.2 diesel to a 350 small block
I haven't done this before so hang with me
Will the manual transmission flywheel from the 6.2 work on a 350 small block ? |
![]() ![]() Join Date: May 2015
Re: 6.2 diesel to a 350 small block
Curious what your plan is..i would think sbc flywheels are still plentiful...but...The way I read this it won't fit..http://www.yesterdaystractors.com/cg...talk&th=520672
NO.
The bellhousings and trans parts will work. But not the flywheel. You need to get the correct one for your main seal set up and clutch size. But the 6.2 flywheel is a unique beast.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors Last edited by D13; 03-22-2017 at 06:24 AM. Reason: can't spell. |
