![]() Join Date: Mar 2014
Positives and Negatives of wheel spacers?
Considering using wheel spacers to push my tires away from my tie rod a bit. Is anyone running them and what, if any, are the benefits? I'd like to hear both sides, negative and positive reviews. Thanks folks!
Re: Positives and Negatives of wheel spacers?
Other than putting your wheels out, everything about them is negative. It puts too much strain on the front end components and drastically changes the original geometry of the suspension. The biggest problem is that it increases your scrub radius which will make you feel every bump in the road. Here in Ontario, wheel spacers are now illegal as of July 1st 2016. Wheel adapters are still legal, but IMHO it will only be a matter of time before these are outlawed too. If you need to resort to using spacers or adapters, then it means that you are running components that are not compatible, and this is just a band-aid to make them work.
#3 | |
SO you have a 4wd? Definite no-no. You can use spacers to find out what the offset should be on the wheels you are going to buy to make things right...but I would never run them on a ride. I could go on with a list of why but it would be too big and bore you.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Yes 4x4. Thanks for the input! Much appreciated, have already purchased new wheels as of this post. Thanks again, guys.
You need rims with either less backspacing OR rims with a larger diameter to clear the tie rod ends.
Thanks. Yeah, I bought some with a different offset from summit. These ones..
