Old 02-03-2017, 09:53 PM   #126
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: project orange crush 76 crewcab build
Nice work on your crew cab. Man, that is a raw deal on that rust but it looks like you're well on your way to getting it fixed. Is that your 67 Camaro in a couple of the pics?
Ryan
1969 Chevy milk truck
Old 02-03-2017, 09:59 PM   #127
520-k5
520-k5's Avatar
Yep definitely wasn't expecting it to be that bad all the way across. Yes I've had the camaro since I was 14 the other money pit!
520-k5 is offline   Reply With Quote
Old 02-03-2017, 10:15 PM   #128
Tetanus Express
Tetanus Express's Avatar
Originally Posted by 520-k5 View Post
So I was browsing on Craigslist again like usual and found some low back blazer seats and console for the crewcab. For a whopping 30 bucks!!!! Not sure yet what colors or theme I'm going for but I'll be changing up the interior again
Now why can't I find deals like that? Good job on the find. Really liking the way that thing is sitting. Gonna be sewer when it's done.
Tetanus Express is offline   Reply With Quote
Old 02-05-2017, 12:17 PM   #129
520-k5
520-k5's Avatar
Thanks. I just get lucky sometimes lol.
Old 02-05-2017, 12:23 PM   #130
520-k5
520-k5's Avatar
Got the brake support bracket off finally and the rest of the upper firewall off. Time to clean up the metal and see what I have to work with. Here's a test fit of the donor piece too.
Old 02-05-2017, 03:23 PM   #131
520-k5
520-k5's Avatar
Got the rest of the donor firewall off today. Still have to clean it up then Mark where I'm going to cut mine out and install the new one. More to come!
Old 03-06-2017, 02:20 PM   #132
520-k5
520-k5's Avatar
I got the majority of the firewall cut out and ready. Still need to do some more trimming behind the cowl sections. Also completely stripped the interior only to discover a lot more rust!!!
Old 03-06-2017, 02:28 PM   #133
520-k5
520-k5's Avatar
Got the cowl pieces removed too. Now I can final trim the ends and mock up the donor firewall. I also started filling unneeded holes in the donor firewall still have a few more to plug but its getting there.
Old 03-06-2017, 03:02 PM   #134
520-k5
520-k5's Avatar
I picked up a blue and white tailgate in the color scheme im going to paint the truck and a set of nicer lowback buckets and a better console too. Also thinking about switching all the 80s door panels out for 77-80 style since they'll match the blowback buckets and console better
Old 03-06-2017, 03:14 PM   #135
520-k5
520-k5's Avatar
Heres the rear rocker, pass side floor, driver side floor its going to need both front floor plans and inner rockers as well as pick panels and possibly a rear rocker too.
Old 03-07-2017, 07:35 AM   #136
LT7A
Man, I need a spreadsheet to keep track of what all you're working on. Like how the crew cab is coming together. Keep at it. In paint it's gonna be killer.
Old 03-08-2017, 04:03 AM   #137
Azryael
Can't wait to see it in that blue!
~Josh
WANTED: '73-80 K30 4x4 CCLB Manual. The closer to San Antonio, the better!! No projects. Solid running trucks, please.
Azryael is offline   Reply With Quote
Old 03-09-2017, 12:11 AM   #138
520-k5
520-k5's Avatar
Got the first mockup of the donor firewall done. Still need some final trimming but it'll be ready to weld in soon.
Old 03-09-2017, 12:16 AM   #139
520-k5
520-k5's Avatar
Thanks man. I haven't even mentioned my buddy's c10 we ls swapped and cut down into a short bed last year or the blazer I bought to flip lol.
Old 03-09-2017, 12:36 AM   #140
Tetanus Express
Looking good there dude. That firewall situation looks like a little bit of work. Looks good so far and it will be solid once your done. Keep it up!
Old 03-20-2017, 12:09 AM   #141
520-k5
520-k5's Avatar
Got the final trim done on the firewall. And the final trim done on the donor firewall it's all clamped in place and ready to weld in now. I also did a final mock up and am happy with the fit of everything.
Old 03-20-2017, 12:17 AM   #142
520-k5
520-k5's Avatar
Final fit of the donor firewall
Old 03-20-2017, 12:23 AM   #143
520-k5
520-k5's Avatar
The final mockup. Also mocked up my auto brake pedal setup no issues there either.
Old 03-20-2017, 12:27 AM   #144
520-k5
520-k5's Avatar
I also ordered both floor pans,inner and outer rockers, and both kickpanels for both sides. After I finish the firewall I'll start on the floors.
Old 03-20-2017, 12:30 AM   #145
520-k5
520-k5's Avatar
That's where I'm at as of now. Hopefully I'll make some progress this week and update as I go along.
Old 03-20-2017, 12:39 AM   #146
Azryael
Good stuff! Glad to see it coming along.
~Josh
Old 04-10-2017, 12:51 AM   #147
520-k5
520-k5's Avatar
Got the firewall primed with weld thru primer and fitted for the last time !!! Also had to weld up a patch from some previous hack work on the bottom.
Old 04-10-2017, 12:58 AM   #148
520-k5
520-k5's Avatar
Finally got it all welded up and ground smooth. You can see the overlap on the inside I'm pretty happy with it.
Old 04-10-2017, 01:25 AM   #149
520-k5
520-k5's Avatar
Here's the rest of panels I need to install. Here's a pic of my hood I stripped and primed last year with u pol dtm primer we'll that stuff was a waste of time and money. I noticed a crack,bubble in the hood the other day and was shocked at the flash rust underneath. Glad I only used that primer on the hood and tailgate they'll have to be stripped and redone again! And here's some super Cheyenne emblems I picked up that I'm thinking about using now instead of the Scottsdale emblems.
Old 04-30-2017, 06:00 PM   #150
520-k5
520-k5's Avatar
Been a while since i posted havent been very motivated to do much to it but I did get some stuff done this week. I bodyworked the weld seam and got it in epoxy primer then I sprayed the rest in weld thru primer. Got the upper firewall ready to weld on today and will be welding on the brake support here soon.
