Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-14-2017, 02:04 PM   #2826
IronCanine
I'm trying....
IronCanine's Avatar
Re: PO has me PO'd
Ditto that...loving all the recent progress and pics. Keep it coming!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 04-14-2017, 06:43 PM   #2827
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Wow, was starting to get disheartened, glad you guys posted up....
mounted my bowtie on the grille today, not sure if there is a top and bottom
perfect patina to match my truck, also played around with my bed side rails, but I'm not sure if I'm junking up the truck. sorta like adding another window to the taj mahal, you guys let me know
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-15-2017, 10:19 AM   #2828
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: PO has me PO'd
Eyebrows ARE a *****. And it doesn't matter if they are original or re-pops.
Tom Vogel is offline   Reply With Quote
Old 04-15-2017, 04:08 PM   #2829
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I was wondering how long it would take you GMC guys, that has done eyebrows to chime in. Yes, truly a PITA
SAFETY FIRST
AS usual, off topic
Jim
Old 04-19-2017, 08:49 AM   #2830
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/ToSv6A]20170418_090436
[url=https://flic.kr/p/TPrCVj]
SAFETY FIRST
AS usual, off topic
Jim
Old 04-21-2017, 10:17 PM   #2831
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
Man. I haven't kept up well. When did a Hickey hood come into the picture??
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 04-22-2017, 04:59 PM   #2832
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/U3pAmN]20170421_113157
[url=https://flic.kr/p/U3hmwN]20170421_110031
started to fool around with the last piece of my cooling system. bought this hose to cut up for the angles
Thanks for watching AJ
I was browsing the truck side and saw it was available, had some money in my pocket, next thing I know it was on my porch
SAFETY FIRST
AS usual, off topic
Jim
Old 04-24-2017, 05:55 PM   #2833
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
finishing up coolant system
trying to make round holes in the cable bracket
[url=https://flic.kr/p/SWpMn6]
SAFETY FIRST
AS usual, off topic
Jim
Old 04-24-2017, 09:11 PM   #2834
CJM72
Re: PO has me PO'd
Looking good! Dang, I love the look of those LT1 intakes. Seems like you're buttoning up lots of loose ends.
CJM72 is offline   Reply With Quote
Old 04-24-2017, 09:23 PM   #2835
Ebully72
Re: PO has me PO'd
Hey Jim, jmo but I'm not a fan of the side rails maybe if it were part amphibious you know some place to tie it off too. Lol. I also love the tpi setup use to have two GTA trans am. Thanks for the pics
Ebully72 is offline   Reply With Quote
Old 04-25-2017, 08:48 AM   #2836
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
yeah, just trying to get it ready for the 2nd street speed, he's doing the harness, big burden off my back!!!!
Always liked the look of the TPI, but if the FI works, I'll change it out for a englese or hilabrandt
Bill, thanks for bringing that up, I've been on the fence with that one. And, you're right, doesn't quite fit the direction I want to go. Good thing I didn't buy that NOS set that is available
Maybe, I should have built an Amphicar
Well, back to work on the throttle bracket, weird, my kick down cable only moves 3/4" and my throttle cable moves 2"
SAFETY FIRST
AS usual, off topic
Jim
Old 04-26-2017, 06:07 PM   #2837
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/SXFsRS]20170426_120759
my ashtray kept falling out due to the plastic rails broken, went to my spare center section I bought years ago, and it had good rails. 4 Phillip screws later, all excess able from the front bottom, and my ashtray doesn't fall out any more.
it is easier if the radio is removed
[url=https://flic.kr/p/TE8NYj]
you can see the threads of the two screws on the left side of the bracket (top and bottom)
Maybe Wes will see this and will work for his next project
SAFETY FIRST
AS usual, off topic
Jim
Old 04-26-2017, 06:17 PM   #2838
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/Uf5ox2]20170426_181055[
some of the handy work of the PO, some people shouldn't have access to tools, but luckily the mounting buckets cover 2/3 of the hole
SAFETY FIRST
AS usual, off topic
Jim
Old 04-27-2017, 09:24 AM   #2839
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: PO has me PO'd
[QUOTE
my ashtray kept falling out due to the plastic rails broken, went to my spare center section I bought years ago, and it had good rails. 4 Phillip screws later, all excess able from the front bottom, and my ashtray doesn't fall out /QUOTE]
My Jimmy has the same plastic guides. I wish they had stayed with the old ball bearing style.
Old 05-02-2017, 12:20 PM   #2840
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I agree with you Tom
[url=https://flic.kr/p/UmGGny]20170502_09461
I have to build a kick down cable adapter,and figure out how to hook it up, then on to the cruise control
[url=https://flic.kr/p/UmGBTo]
put the last plug in the cooling system, time to fire up the electric w/p. Thick I forget gaskets on the w/p
SAFETY FIRST
AS usual, off topic
Jim
Old 05-02-2017, 06:25 PM   #2841
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
does anyone have a pic. of the actual part that the cable is swagged to, and then goes to the throttle blade? Thought I had one
SAFETY FIRST
AS usual, off topic
Jim
Old 07-02-2017, 09:02 PM   #2842
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: PO has me PO'd
Hey Jim! Done yet?
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 07-11-2017, 10:08 AM   #2843
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by Big J View Post
Hey Jim! Done yet?
sorry J for not posting up, seems I myself have been the project of late. Between my vascular surgeon, and my cardiologist, I've needed a complete rebuild... should be good to go, as I've had my surgeries done yesterday! A couple days recovery and should be back at it
Ya never know which way a project will progress, but I haven't given up yet. Hopefully, I'll have something to report in the next week or so
SAFETY FIRST
AS usual, off topic
Jim
Old 07-11-2017, 12:38 PM   #2844
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: PO has me PO'd
Glad to hear ya came out on the good side Jim! Get well soon.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 07-11-2017, 02:32 PM   #2845
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Richard
Thanks Richard for the well wishes, been quite boring around here, going from the TV, to reading books on either the front porch or the back porch, where ever the sun was coolest. But I am current, on all the authors I read.LOL
Today was a success, as I weed whacked most of the yard, which was great as I had NO pain in my legs, maybe even able to cut the grass
3-4 months of sitting on my arse, has gotten quite old
SAFETY FIRST
AS usual, off topic
Jim
Old 07-11-2017, 08:12 PM   #2846
Ebully72
Re: PO has me PO'd
Jim glad you're ok, I thought maybe you we're going to surprise us all with a brand new paint job.lol
Slow and steady usually gets done.
Best wishes Bill
Old 07-12-2017, 04:27 PM   #2847
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Best wishes Bill
Sorry, no surprises here Bill, paint is the last on my list. I'll drop off a fender or door off at Maaco at a time and call it good, my cowl came out really nice
I'd really like to fire the motor up, but still have some connections to make
SAFETY FIRST
AS usual, off topic
Jim
Old 07-12-2017, 10:20 PM   #2848
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
Jim,
been busy with seasonal maintenance and not on board much ,saw this tonight glad to hear your doing ok
Jess
zicc1835 is offline   Reply With Quote
Old 07-15-2017, 09:12 AM   #2849
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by zicc1835 View Post
Jim,
Jess
thanks Jess for the well wishes....
sux, all my pics up to page 75 gone, thanks photo bucket! I'm not paying 400.00
SAFETY FIRST
AS usual, off topic
Jim
Old 07-24-2017, 02:45 PM   #2850
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/WRsuWv]20170724_134025
still having problems mounting up rad., seems my harness is to large with the addition of wires for the headlight relays
SAFETY FIRST
AS usual, off topic
Jim
